Old Mon 06 February 2012, 06:13
Daya
Just call me: Fabrica
Kandy
Sri Lanka
What to use to cut Melamine Board?
Hi Guy, can anyone sujject to me the best tool which I could use to cut melamine coated partical board. Info on the router rpm's and also the cutting speeds would be most welcome.
Old Mon 06 February 2012, 07:21
I used a 2-flute 3/8" "compression" cutter, which down-cuts the top surface and up-cuts the bottom surface. That down/up action reduces chipping.
Feed speed was usually about 360" per minute on my Shopbot PRT Alpha and the spindle speed was set at 12,000 RPM to give a 0.015" chip size.
When I didn't have a compression cutter, I used a down-cutter on the first pass and a up-cutter on a second pass. The effect was the same.
Old Mon 06 February 2012, 09:26
As Richards said, only compression up/down cut bit.
I once had to cut it without compression bit, offset the line, cut with plain bit, then used 12mm straight bit at 23k RPM to clean 3mm offset in one pass. this could be done only if you have a pre-cut part and don't have to cut it out of the board.
Old Mon 06 February 2012, 09:38
Fabrica!!! I thought you gave up the production stuff and went to coach cricket?
Folks, Fabrica holds serial #1 - he kept me awake with all his questions and you can thank him for all the stuff I was obliged to put on the forum for him. Please give him good advice.
Old Mon 06 February 2012, 09:46
Fabrica,
So good to hear from you again.
I, like others have noted, have good success with the up/down compression bit.
I personally use a 3/8" Onsrud compression at 13-15K RPM (as fast as my 5hp router goes) and feed rate between 190-280 ipm. I could probably go faster, but I "listen" for the groan in the sheet goods.
Best,
Old Mon 06 February 2012, 10:00
Daya
Kandy
Sri Lanka
As I have told you on numerous occassions, You gave us a challenge and I almost lived up to your expectations. But also I have told you that this is not my bread and butter. But still again after so many years I have again thought of making some use of the beast that this forum and you have created for me. Anyway thanks a lot for introducing me to other forum members in such a classy manner. I am really happy to join up with you guys again
Old Mon 06 February 2012, 11:06
Anyone who has been around here knows Fabrica! Good to see you around again.
Old Mon 06 February 2012, 18:52
normand blais
Just call me: Normand
montreal
Hey! Fabrica how you doing ,any sculpture picture?
Old Mon 06 February 2012, 21:26
Daya
Kandy
Sri Lanka
Nothing for the monment Normand, I will keep you posted of any new developments.
Old Mon 06 February 2012, 21:34
Daya
Kandy
Sri Lanka
Mike, are you sujesting something like this.
http://www.carbideprocessors.com/2-f...k-vortex-3152/
Old Tue 07 February 2012, 04:56
Thats it Fabrica, but you might find them a bit cheaper.
Old Tue 07 February 2012, 04:58
Daya
Kandy
Sri Lanka
Can you give me a link please to buy it cheaper.
Old Tue 07 February 2012, 05:06
first one I got saved is these guys
http://www.bamcarbide.com/updocosprobi.html
but the 1/2 is rather large bit, and you will need lots of power at the spindle to cut with it. Look for 3/8 (10mm) or 8mm instead. I got locally russian GLOBUS 8mm compression bits for 26$, but I must say that I have not used them much to say about durability
Old Tue 07 February 2012, 05:09
Daya
Kandy
Sri Lanka
Danilo thanks for the info. I will follow it up.
Old Tue 07 February 2012, 10:19
Daya
Kandy
Sri Lanka
Another Tool Link given below. Looks cheaper than what i found earlier.
http://www.toolstoday.com/p-5638-cnc...e-2-flute.aspx
Old Tue 07 February 2012, 16:37
Fabrica....Nice to see your back
Your part of some few whom inspired me to pursuit in my buid !!
Glad to “ Read ” ya
Locking forward for more !
Amicalement, Robert
Old Tue 13 March 2012, 22:43
timberlinemd
Just call me: Steve #66
Arizona
Best,
Sean,
Do you cut thru 3/4" melamine in one pass with the 3/8" cutter? Do you believe that these 15amp routers will do that or is your 5hp router a spindel? I'm afraid to try.
Old Tue 13 March 2012, 23:08
timberlinemd
Arizona
Good link for true horse power of small motors...
http://www.kevinsbrady.net/motors.pdf
Control Board Help Please paul60 70. Control Systems 8 Wed 07 October 2009 23:52
What is the purpose of a spoil board or bleeder board? j_wizard 10. Base Table 1 Sun 09 August 2009 18:00
Squaring the spoil board or .... sailfl General - MM Operating 4 Wed 08 July 2009 00:01
Sizing Melamine Panels hflwaterski Archives 8 Sat 21 June 2008 07:11
cnc4pc board help smreish 70. Control Systems 1 Wed 23 April 2008 06:22
