Old Sat 07 January 2012, 12:15
Zouave
Just call me: Eric #115
Sacramento, CA
Gas Spring Stroke Length
Looking at drawing 10 40 014, for the 10" z-slide assembly, my version of the drawings calls for a gas spring with a 14" stroke. I am assuming this is a typo, but figured I should ask in case I am missing something.
So, am I missing something...?
Old Sat 07 January 2012, 13:16
I don't have a drawing set, so I can't check, but there are some drawing title mistakes between 10" and 14". If the drawing number is 10 40 014 then this suggests it is a 14" drawing and the title may incorrectly be referring to 10".
Old Sat 07 January 2012, 13:25
Zouave
Sacramento, CA
Hah! And there we go. The other drawing calls for a 10" slide. Problem solved.
Old Sat 07 January 2012, 15:02
Zouave
Sacramento, CA
Next question becomes the spring rating. My router (Porter Cable 7518) plus z slide weigh 25lbs. I assume I am going for a 30lb spring? Since I have the rack to add, plus whatever dust collection I use...
Old Sat 07 January 2012, 15:32
Eric,
I had the same set up. 30lb spring should be fine. You want the z-slide to be positive loaded so if you have a failure, it goes up and not down into the table.
Remember to install the gas strut properly to avoid seal damage.
Old Sat 07 January 2012, 15:34
Zouave
Sacramento, CA
Heh, yeah, I have been reading those threads. :-)
Tolerance in length of y-beams Red_boards 20. Gantry 10 Wed 26 January 2011 17:57
Rack length problem buuk Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 3 Thu 11 November 2010 13:23
Gas Spring : Compatible automotive gas spring Nikonauts 40. Z-Slide 0 Sat 03 January 2009 10:59
Multiple gas springs for extended stroke sprayhead 40. Z-Slide 12 Fri 12 December 2008 08:26
Z slide length, dimensioning the linear system. sprayhead Archives 1 Thu 10 July 2008 07:02
