Old Sat 07 January 2012, 04:20
Hi Martin,
You will make a seperate plate that mount on your spindle.
This plate will have 2 dowel pins and a 8mm threaded hole.
You then attach this plate (with the spindle on it) to the Z-Plate (the tools steel plate)
The dowels match into the holes on this plate and the whole assembly is held together with only the 1 x 8mm bolt......sort of a quick release system.
Hope it makes sense.
Old Sat 07 January 2012, 04:26
Dowel pins are for mounting a plate for which you attach the spindle/router mount
Its sort of quick attach, two pins and a large screw in middle.
Old Sat 07 January 2012, 04:47
Something like this...
Old Sat 07 January 2012, 05:27
mrakoplas
Just call me: martin
praha
Czech Republic
great, thanks s lot for the quick response!
Old Sun 30 September 2012, 13:59
mrakoplas
praha
Czech Republic
First cutting test
Hi. I finally found some time during this summer to finish the machine to its cutting state. Finally its ready to make some chips! The cutting area is 1700 x 2900. The control system is LinuxCNC. I used Rick's gearbox to build 3:1 belt reductions. I had to slightly file it to fit it on the Z axis and it can be attached only to the first slot on top of the Y-car. Otherwise it works perfectly. I am using spindle Teknomotor 2.2KW with separated ventilator. However, there is still some work waiting for me, such as the e-stop wiring, controlling VFD via Linux, and so on. I will post more images of the machine and products done with it soon.
Old Sun 30 September 2012, 15:50
HomeMadeCnc
Just call me: Tim
Calgary, Alberta
Congratz! Now the fun begins!
Tim
Old Sun 30 September 2012, 21:35
Looking good, now you need some decals to be in line for the next serial number.
Old Sun 30 September 2012, 22:41
Sweet - back to back yellow MechMates
Old Mon 01 October 2012, 00:04
And the red beltbox is neat too. Nice job.
Old Mon 01 October 2012, 07:34
Well done...welcome to production land!
Old Mon 01 October 2012, 08:22
rischoof
Just call me: Rik #92
Goirle
Martin,
Nice yellow machine, you will not hit yourself when you walk around in the dark in you workshop. These are the first pictures I see from the gearbox. and they look nice in Red. 2 questions,
1) could the laser cutter made the hole for the bearing with the correct tolerance?
2) This one is not a question but a request, is it possible for you (sooner or later) to update the gearbox design for the original z axis at the gear box topic on the forum. then the story is complete.
Old Sun 07 October 2012, 05:30
Look locally, they are the simplest of bearings. Almost the same size as a kids roller blade center. I purchased mine from vxb in california, but the part linked to a skate as a replacement part number.
Old Mon 08 October 2012, 12:50
mrakoplas
praha
Czech Republic
Thanks for the nice comments.
Rik: The gearbox plans worked great, the bearings fit in just perfectly. I used your design also for the z axis. However, it fits only when you put the z axis in the first slot of the Y car, as you can see on this picture. If I find later that I need to move it close to the center, I will redesign it and post the plans here, but I think that the air hose should fit in still fine.
I still plan to work out more the LinuxCNC, pragram to it spindle control and so on, and than post the files here.
Also, I want to make now a dust shoe. I like the one from Ross aka Surfcnc, but I did not see anywhere that plans to download, but I can probably trace his jpg image in autocad.
Old Mon 08 October 2012, 23:59
I reckon you don't need the gear reduction on the Z-axis. Consider how often it move during cutting... Direct drive should have more than enough precision for plasma works.
Starting Mechmate in Czech Republic mrakoplas Introduce yourself and start planning 7 Wed 10 August 2011 07:59
Speed Test isladelobos General - MM Operating 1 Tue 13 October 2009 05:07
test test buibui Test Area for this forum 0 Mon 20 April 2009 01:08
Test DocTanner Test Area for this forum 0 Mon 15 January 2007 12:27
