Thread Tools |
Cheaper drives
Does any one know of good axis drives that i could replace or rather use instead of the gecko 203v drives usin nema 34 motors and the pmdx-122 bob board
keling - affordable units (be sure to pick the correct step and current value for your motors)
uirobot - used on a few MechMates already automation direct gecko G540 drive - The most affordable solution with the right choices. Also, you don't need the G203 series drives, others in the gecko family will work. Last edited by smreish; Tue 15 November 2011 at 19:15.. |
Thank you for a quick response i will look at this drive
I have used Leadshine models drives for the last build, and they work like a charm. Probably not the worlds best, but they do the job, and are affordable.
you might want to check these out.
http://www.tinycontrols.com |
Thanks a lot ken c check the site and emailed for a price people on mechmate forum are great help 30 yrs as a machinist cnc but the electronics part is where ui can
can"t afford to make mistakes |
Anyone tried them out? The drive looks pretty slick. Browsing through the site, I came across a very nice looking BOB too. This could be a pretty good option for builders in this region. http://www.tinycontrols.com/parallel...out-board.html |
#10
Nice. What are the caps for?
#11
Those caps are needed because he used long and thin wires to connect power to drives
#12
Ahhh.... Channel isolation & better PS Zo
A thick 12g loudspeaker cable should save the trouble nicely ? |
#13
Anil, would you kindly elaborate the protections you put into your drivers?
#14
Thanks Ken for your keen interest, basically drivers are protected for current at the outputs making them protected from over-current, miss wiring and short circuits at the output.
So you can only destroy them by connecting the power in reverse (even then the fuse blows) otherwise they are safe to common miss use or miss wiring. |
| WTB: Belt drives | JamesJ | The Market Place | 1 | Sat 27 August 2011 20:46 |
| Spindle and vfd cheaper than I can get a decent router | jwt | 50. Toolheads | 23 | Tue 19 October 2010 03:35 |
| Belt Drives?? | zigmart | The Market Place | 1 | Thu 22 July 2010 20:12 |
| Build a functional MechMate at lowest cost - what can be done cheaper? | Gerald D | General - MM Build | 87 | Sat 06 March 2010 18:21 |
| Steel sizes & gauge substitute info! (can we make it lighter and cheaper?) | Robert M | 10. Base Table | 17 | Tue 06 May 2008 09:51 |
