Old Sat 30 July 2011, 12:09
Engadget Article
Old Thu 04 August 2011, 18:05
PEU
Just call me: Pablo
Buenos Aires
Machined a friend photo:
http://www.youtube.com/watch?v=njHgg5jnFsU
Old Fri 05 August 2011, 06:16
olz
Just call me: Bubolz
Pelotas/RS
Brazil
Olá Pablo!
Originally Posted by PEU View Post
Ótimo trabalho!
A propósito... estou a procura de um fórum bom sobre CNC em espanhol... Se puder indicar algum agradeceria muito!
Abs.
Paulo Bubolz
Old Fri 05 August 2011, 06:50
PEU
Just call me: Pablo
Buenos Aires
Tem muitos mais nunca participei neles, so estou aca e na cnczone.
Pablo
Old Fri 05 August 2011, 09:51
lumberjack_jeff
Just call me: Jeff #31
Montesano, WA
What did you use for CAM software?
Old Fri 05 August 2011, 10:10
PEU
Just call me: Pablo
Buenos Aires
old version of art cam
Old Sat 06 August 2011, 14:09
quadtech
Just call me: Prasad
Hyderabad
Very cool.
Is there any software to do halftoning using different sized
drill bits, instead of carving?
Edit: I re-read the topic and saw Danilom's post about the brazilian software
which can use stepped drill bits. Really nice!
Old Sat 06 August 2011, 17:17
PEU
Just call me: Pablo
Buenos Aires
Maybe you can convince the finish guy who developed the software to use a finite amount of diameters for the circles, then any CAM would do the rest of the job for you.
Even better, from what he has now, posting G-Code directly would be super easy as I'm sure the DXF file export filter needs to specify the center of each circle.
Or maybe a compromise in the middle, just be able to export a text file with the X,Y,Diameter of each hole and then post process it directly to gcode.
Pablo
Old Sun 07 August 2011, 05:48
Did one video not show a chap using a 60 deg V-Cutter ? Will the CAM then not tell the Z-axis to go deeper for bigger circles ?
Old Sun 07 August 2011, 09:24
PEU
Just call me: Pablo
Buenos Aires
yes, you can use V cutter too, I used a ball mill because I used a 4mm MDF sheet, larger holes could go thru the sheet, with a ball mill your spoilboard needs to be dead flat because holes do not go deeper than 0.5mm when you set max circle diameter of 2mm
Old Sun 07 August 2011, 10:02
PEU
Just call me: Pablo
Buenos Aires
Just for fun today I opened the DXF file generated by the halftone app, each circle has this info:
PHP Code:
CIRCLE
  8
Default
10
248.036575
 20
-10.3113995
 30
0.0
 40
0.0685546920
  0
So, all the info its there, 10=X, 20=Y, 40=Diameter. One just need to calculate the depth of the V cutter or Ball mill based on the diameter of the circle and then gcode is around the corner. Any trigonometric guru reading?
I think can do the code in visual basic given enough time
Pablo
Old Sun 07 August 2011, 12:32
ger21
Just call me: Ger
Detroit, MI
When I get a chance, I might write a macro to do it in AutoCAD.
Does anyone know a way to get a .dxf of circles out of Inkscape? I've spent the last two hours trying, but it seems that .pdf is the only way that doesn't take forever.
But I do have Aspire that I can use. But an AutoCAD macro would give me a more optimized toolpath
Old Sun 07 August 2011, 14:30
PEU
Just call me: Pablo
Buenos Aires
Here is what we need to know:
Old Sun 07 August 2011, 14:54
ger21
Just call me: Ger
Detroit, MI
For a V bit, the depth = Radius of circle/tan (1/2 cutter angle)
For a 6mm circle, with a 60° v bit, the depth = 3/tan(30) = 5.196mm deep
Old Sun 07 August 2011, 17:58
PEU
Just call me: Pablo
Buenos Aires
A friend of mine offered this solution for the sphere, can you validate it?
c=ballmill radius
d=circle diameter
depth of cut=c-sqrt((c^2)-(d/2)^2)
I will test it empirically with Solidworks [edit] works!
Pablo
Old Mon 08 August 2011, 06:07
PEU
Just call me: Pablo
Buenos Aires
yesterday I sent an email to the developer with the formulas and some comments about how to implement gcode generation to the program, today he replied saying that he was already working on the new version and it should be available today or tomorrow as he was waiting for some betatesters, he even provided this image:
I would like to think that brilliant minds think alike, but he actually did all the heavy lifting
Pablo
Old Mon 08 August 2011, 09:47
Metalfusion
Just call me: Tomi
Tampere
Finland
Version 2.0 is up!
Path width modulation example video:
http://www.youtube.com/watch?v=jqksgmyWI3k
Download here:
http://www.students.tut.fi/~syvajar3/
Have fun! I'm looking forward to see your work.
Old Mon 08 August 2011, 10:21
PEU
Just call me: Pablo
Buenos Aires
Amazing Tomi !! and welcome to the forum. BTW, Tomi is the software developer.
For some reason I cannot make the wave method to be shown in the preview, how does preview knows which method to show?
Old Mon 08 August 2011, 10:55
PEU
Just call me: Pablo
Buenos Aires
general tab, dumb me
Old Mon 08 August 2011, 15:27
Travish
Just call me: Travis #75
Wa
Hi Tomi! Great looking software! Is there an easy way to output the code into inches or to set the software up in inches? Keep up the great work! Really cool, wow!
Old Mon 08 August 2011, 16:11
ger21
Just call me: Ger
Detroit, MI
Just ignore the fact that is says mm's, and enter the numbers you need in inches.
Old Mon 08 August 2011, 16:25
Travish
Wa
Hi Ger, your right....it worked! Thanks. All the code looks good. The program outputs the number to the 10th decimal place. I hope mach will read/run it ok. I'll have to try it out when I get home.
Old Mon 08 August 2011, 21:53
quadtech
Hyderabad
Tomi, that is so amazing!
I would love to have a metal speaker grill (a funky car sub grill, more
like) with a half-toned logo made of the drilled holes :-)
More reasons to build a CNC.
Someday, when the space-time-money conundrum is solved...
Old Mon 08 August 2011, 22:37
Travish
Wa
Works fine in inches
Grabbed a pc of mdf and a can of black. Mach ran it fine..... 4300 holes, 30 inches per minute, picture is 8.8 x 10.5 ish. I like how simple it is!
Old Mon 08 August 2011, 23:08
Hi Tommi,
Great software! It works!
Will try to run on EMC2 once I get a chance.
Thanks for sharing.
Old Mon 08 August 2011, 23:57
quadtech
Hyderabad
Travis, you may be able to make cloth prints. Coat that mdf with
fabric paint and press it on a T-shirt.
This half-tone stuff is way cool!
Old Tue 09 August 2011, 01:02
Quadro
Just call me: Anthony #77
South Australia
Worked no worries with EMC2. Can the software write the gcode for the cut out?
Old Tue 09 August 2011, 05:17
Metalfusion
Just call me: Tomi
Tampere
Finland
Nope, making cutouts is not supported.
Adding that feature would require a new tab of UI and all kinds of parameters such as endmill dia., offset, tabs, pass depth, material thickness, ramped plunges... to be any good.
Making and tweaking the user interface for new features usually takes longer than coding the actual stuff and is frustrating, boring work. I'm starting to understand why Linux coders like to make console apps.
Old Tue 09 August 2011, 06:15
Quadro
South Australia
Tomi,
You listed off all the options/parameters just to cut out or profile cut and I could put a tick next to all of those options, it is amazing how I as an end user take coding software for granted.
Old Tue 09 August 2011, 07:58
Metalfusion
Just call me: Tomi
Tampere
Finland
Originally Posted by quadtech View Post
Very cool.
You could also use the export size parameters on my software to make multiple dxf files, each containing a different size range. Then just use any CAM-software to generate GCodes and change the drill after each set.
Ghost in the machine ?... Router creating its own G code Blue eleven Troubleshooting 22 Mon 02 August 2010 23:12
Mr Lasercut&bend has his own machine drawing pictures! #42 - Birmingham, AL jbmclain MechMates already cutting 25 Mon 14 December 2009 10:27
Creating a "manual" to describe the MechMate build process Gerald D Archives 5 Thu 05 June 2008 18:09
Why can I sometimes not see all the pictures? Mike Nash About this Forum 5 Sun 27 January 2008 10:39
