Old Fri 15 July 2011, 08:01
Ross, a random thought:
Could you also pre-blow a set of blocks that support the blank?
Old Fri 15 July 2011, 08:34
Hi Brad
Short answer - Yes for a specific design.
Long answer - each board can be quite different so generally the set up needs to be flexible enough to accommodate these different designs.
Here is one idea that uses a flat bed -
http://www.youtube.com/watch?v=SgMGTEhspZ4
http://www.youtube.com/watch?v=Uvnl-R5Pkjg
Here is an example of too little support or excessive plunge rate - note the tail flex on contact.
http://www.youtube.com/watch?v=8viItUSoKx8
Old Sat 16 July 2011, 20:00
Red_boards
Just call me: Red #91
Hi Ross,
The WitchCraft videos are impressive. A whole separate control system for the vaccuum suckers. That's one looong bit they use to cut the outline.
No surfing for me. Bit busy at present and baby is too cute, so I prefer to hang with him than drive 2 hours on a cold day to get hammered in freezing water. Also I'm trying to get the MM done.
My intention has always been to cut from a block of foam leaving tabs, then flipping the block. I believe this will be the easiest for hold-down (clamp the edges that do not get cut) and for registration (use the block edges). Of course it's slower because of all the excess material. I've had boards done this way on a big 4 axis machine (5 boards at a time!) and it worked well. Of course, EPS only, so I don't have to worry about varying density of the blank.
My longer-term solution to cutting too much foam will be to use the hot wire cutter I have to cut bottom curve and thickness (like the Witchcraft people appear to do), but leaving the rectangular outline. Then support the curve on rocker tables (one for the top and one for the bottom) to limit flex during cutting (excessive use of tabs could also be an option).
If all pans out well, then my intention is to use vaccuum hold-down on EPS rocker beds. I only use one rocker on anything 5'10"-6'2", with slight tail kick variations.
My boards are stringerless. I use vaccuumed-on veneer to hold the rocker shape, and do this on a rocker table (I see the Witchcraft people put the bottom veneer on before cutting the deck), so I may decide that some distortion during cutting is acceptable, and so review how I do things.
I'm open to advice. Sean, feel free to chip in.
Old Sat 16 July 2011, 23:05
Hi Red
Family first is always the best policy, the surf will come again.
Thanks for your response and interesting that you use the veneer to hold the rocker.
If I ever get on with it and do some shaping on my machine, I will post up what happens.
Will probably just tear the glass off some old boards and cut them down progressively until they are just dust in the extractor as a practice.
Other projects need to be finished before any shaping gets a run on my machine, its a long term goal for me but a goal none the less.
Only time will tell if I deliver on that one . So many projects so little time.
Old Sun 17 July 2011, 06:19
Red,
My thoughts on you application are this:
If your working with a rectangular billet, then tabs and registration blocks on the table are a fine solution. The down side is you use "just a little" more material, but the extra mass=stability in size pending your number of tabs and placement.
If your going to use the "preformed" blanks, then a cheap solution is make a "negative mold" that the board of choice fits in. Since your table size is large enough, the left side is for top cutting, the right for bottom cutting. Vac-holddown could be as easy as a shopvac and a few holes in the "negative" foam block and your holding everything down. The tool path for the hold down will be the same as the board, so registration will be spot on. If you have a high volume part that will be cut frequently, then the hold down negative part could be out of plywood, plastic or anything really. 3d is fun, you just have to think about the part and "z" change for clearance of tool bit vs. gantry height.
(tip and trick)
If you smartly build the hold down negative part, you can put "side draft" tunnels down the starboard and port sides of the blank as dust collection. It doesn't really pay off if your doing a few parts a day, but if your doing a hundred, then in makes sense!
Old Sun 17 July 2011, 18:41
Red_boards
Ross,
I'm the same - too many projects! Cutting a few boards is just the start.
Sean,
Thanks. I hadn't thought of using each side of the machine for a separate purpose. My 'rocker table" is the 'negative" you recommend. If I do a good job with the hot wire, then I will end up with a positive and a negative. Nice idea about the holes through for vac hold-down. I had not considered this. And thanks for the tip on dust collection. You've got me thinking.
Cut a few roadrunners this weekend. Trying to figure out feed rates and bit size so I don't have strings on the top surface (should I surface the wood first?).
Still struggling with getting Z zero right. Time for a touch plate, I think. This may be a circuit involving a bulb, battery and crocodile clip, but I'll do a bit more research.
Old Tue 19 July 2011, 07:09
sprayhead
Just call me: Francis
sydney
Originally Posted by Red_boards View Post
Feet arrived
With the Au$ almost at parity with the US$ it makes sense to get stuff from the US at the moment. Mike figured that he could ship 3 sets of feet at similar price to 1 set. I am duly proud owner of 3 sets of feet that arrived well packaged in wrap, foam beads and two boxes with lots of tape!
Andrew has already snagged one of the extra sets, so there is another set available to a local builder.
Red, can you help me? remember where you got these feet?? thanks!
Francis
Old Tue 19 July 2011, 13:36
I know where he got them But I think Red has some spares
Old Wed 20 July 2011, 08:07
sprayhead
sydney
Cool I am interested...
Old Thu 21 July 2011, 17:45
Red_boards
Hi Francis,
Apologies for the slow response. I have no more feet.
I got feet from Mike MetalHead. No issues shipping from the U.S. and the price is right. I also got bearing supports from Mike, so you might consider those at the same time.
Good building.
Red
Old Sun 07 August 2011, 21:37
Red_boards
Quick update
I had a few Mach 3 crashes. Traced them to continued residence of the trial version on my machine and use of that version's loader to start the licensed version (I think). Some uninstalling and installing and a few restarts later and redirecting Mach 3 to the correct .xml config file and things are running smooth again.
I'll get some decals cut, and post the Roadrunner cut to prove it works.
Old Wed 21 September 2011, 06:47
Red_boards
MM in a bucket
The Rosencrantz and Guildenstern of MM construction.
I swept my drill shavings into a bucket. This is how much accumulated during the build...
And here's the reason I've been so slow getting the decals on the machine and finishing the workshop so that I can move it in:
Old Wed 28 September 2011, 20:30
Red_boards
Help needed on sourcing foam router bit and other stuff
I've been spending time getting the tin shed garage into some sort of shape and nailing carpet to the walls for soundproofing. We'll have to see how that works out. Can't be worse than current practice of running machine in the open air.
Touched up a few things on the machine like paint scratches and more permanent mounts for the proxy detectors.
I have to cut a sign for the MM. and then shoot a film of it cutting.
The wheels are in place, so now it's a question of rolling the machine into it's more new home that does not involve blocking the view out of the kitchen window.
My gas shock can't lift the router, but does "help". Is this likely to be a problem over time? The motor lifts the Z without problem, but I don't want to overwork the motor (mind you, the same spec motor drives the Y-car).
I've done a bit of looking around and only found one supplier of these kinds of bits for cutting polystyrene foam. They are rhino and wounded, judged by the way they charge. Anyone recommend a source or alternate?
CUTTER HEAD DIMENSIONS: 1.19" (31mm) Diameter X 2.83" (72mm) Length.
RADIUS: 0.325" (8.25mm)
SHAFT/SHANK DIMENSIONS: 1/2" Diameter X 1.5" (38.1mm) Length
PS I have checked out the Frog3D range, but their bits are small and conventional.
Old Wed 28 September 2011, 23:55
shaper
Just call me: Jed
Perth, WA
Red
As always the MM site is a treasure trove of information, there's been some discussion on this in the past, have a look here, it's old so maybe not much help but a starting point.
Old Thu 29 September 2011, 01:21
Red_boards
Thanks, Jed. Nice to see you still come around and help us beginners. I see Oliver.com have carbide burrs, but they seem limited to smaller sizes. Still, at $15 vs $300, I might give one a try.
Old Thu 29 September 2011, 04:20
As smreish suggested try using long drill bit for foam, just sharpen it for a radius, it works really well
Old Thu 29 September 2011, 13:14
Danilo....I told you!
You will find that if you use the wood ONLY type twist bit with a "full length" twist, it works best.
I also found, that if I got above 12#/ft3 foam, it was not so pretty. But on the lighter standard foam density, just fine.
Old Mon 28 November 2011, 19:49
Red_boards
Restarted the machine after a layoff of a few months. Had to learn to drive all over again.
Here it is, still outside the kitchen. Roadrunner video to follow.
Mike - I looked up P-Sketty and got some reference to accents, dancing cats and a place in England. I'm missing something?
Old Mon 28 November 2011, 19:56
Red_boards
I have 2m of cable chain left over. It's large (same as the pic above), does sag a bit over 1.5m, but it's doing the job.
Old Mon 28 November 2011, 21:42
Ha Ha - P-Sketty is what us down south (US anyway) boys call pasta !!! Spaghetti
Old Wed 30 November 2011, 19:35
barry99705
Just call me: Barry
Xenia
You guys can't pronounce pecan right either...
Old Tue 24 January 2012, 05:00
Red_boards
The official first cut
I finally got the garage (a strong word for a tin shed) "finished" (The floor is sort-of level and doesn't leak, and the sound is dampened using carpet on the walls and roof. Nailing used carpet to roof beams is not something I recommend, even with dust mask and goggles - eugh!).
Rolled the machine from its birthplace on the concrete slab outside the kitchen window into the shed, removed the wheels and leveled using Metlahead's highly recommended feet.
Worked through some new computer stability issues. Discovered two earth wires had been busted loose in the move (well to be honest, one was poorly attached in the first place; the other was in the control box that suffered a few bumps in the move). Not nice to touch the machine rails and get a buzz.
Turns out that my computer did not like sharing a 10amp circuit (the highest amperage I have available in this aged home) with the power box. Laid in another source and the computer crashing disappeared (and there I was blaming Mach 3).
Anyhoo, it's somewhat telling that the machine has been running for 4 months and it's taken me that long to apply a nameplate and shoot a video. Here it is:
When I look back, I'm amazed that it's come together. Given my lack of skills in any of the departments: electrics, electronics, welding, drilling, measuring(!), it's testament to the plans and support from people on this forum that I've managed to construct something that looks pretty professional, speaks to the computer, and does things reproducibly.
I have a few posts to come on my build lessons, and probably many more on how to actually run the thing somewhat effectively.
Old Tue 24 January 2012, 05:17
Red - Great looking build !! You get #91 !! Congrats on getting you machine cutting !!!
Old Tue 24 January 2012, 05:25
Red_boards
Mike, That was quick!
I was aiming to get in the first 100, so I'm happy.
Thanks for your help and for this forum.
Red
Old Tue 24 January 2012, 05:38
I'm on the clock early today !!!
Old Tue 24 January 2012, 05:45
rnixon
Just call me: Rick #45
Vic
well done Red - now the learning begins
regards,
Rick
Old Tue 24 January 2012, 08:22
Geluk Red, well done.
Old Wed 25 January 2012, 03:05
Hi Red
Sent you a PM but so everyone else can see, well done.
Old Sat 28 January 2012, 07:41
Updated Builder's Log
Red,
I apologize for being so tardy on updating the Builder's log. I check the forum everyday, but just missed your serial number award message from Mike.
My hardiest congratulations to you on completing your MechMate and earning Serial Number 91. I appreciate your extensive build history and look forward to any "build lessons" to follow.
The Updated Builder's Log is here.
I looked, but didn't find the dimensions of your machine mentioned in your build thread. I did see the Z-axis dimension. Please let me know the cutting dimensions so that I can add them to your Builder's Log entry.
Also, please review your Builder's Log entry and let me know any changes you want to make.
Old Sat 28 January 2012, 12:50
Red,
Congrats on the build!
A chip off the old block quadtech Miscellaneous / General / Whatever / Catchall 0 Tue 23 August 2011 08:30
Anyone need more bearings? MELBOURNE rotorzoomer The Market Place 1 Fri 12 February 2010 07:45
M1 18 000 Alternative Stopper Block dmoore 20. Gantry 15 Fri 13 June 2008 13:47
Rail and Block John Archives 2 Mon 09 April 2007 16:25
