Thread Tools |
Gear set screws and loctite?
hi
i've been thinking about using loctite or something on the set screws to the x motor as the load is high and the last thing i want is them to come free during some fine stepping motion. Is this what most of you are doing? thanks dc |
I would use two screws. First one, shorter length so that there is treads left for second one, set tight to motor shaft. Second one, screw on top of first one to keep from backing out.
hi.
the boss on the gear leaves me with a threaded length for the grub screw of only 6mm. I maybe able to get 3mm long grub screws but would have to look, it's kind of short and think they need atleast 3flutes of the thread so not sure if i can do that. dc |
This would be a problem. Loctite is not recommended. If you search this forum for 'grub screw' you should find solutions for your problem.
I would use longer grub screw, maybe 5mm long. more metal to ensure it bites hard.
I think its a matter of what color or type of loctite you are talking about. Red 271 no freaking way. Maybe Green 290 if I was really getting tired of the screws backing off but I do use Blue 242 with no problems. It does require a little more umph to get the screws out so I recommend a new or freshened up allen wrench.
| "Grub"/set screws for pinion gears - fitting and locking them. | J.R. Hatcher | Driving Mechanisms: Rack/pinion, gears, screws, belts & chains | 23 | Wed 23 June 2010 08:53 |
| Spur Gear decision | shelbygt500buddy | Driving Mechanisms: Rack/pinion, gears, screws, belts & chains | 2 | Wed 14 April 2010 05:46 |
| Moore Gear Racks | jessyjames | The Market Place | 2 | Mon 15 March 2010 22:32 |
| Pinion gear chatter | lunaj76 | Driving Mechanisms: Rack/pinion, gears, screws, belts & chains | 5 | Tue 27 October 2009 01:29 |
| Drilling & tapping the pinion gears for locking screws | lunaj76 | Driving Mechanisms: Rack/pinion, gears, screws, belts & chains | 11 | Sat 29 November 2008 05:49 |
