#481
That's a lot of heat! Conventional wisdom would be that the feed is too slow and or the speed is too high; Are your chips coming off as spirals or flakes? Ideally, you want spirals, indicating that you are only cutting the material once. If you have flakes, particularly small ones, you are cutting the cut material, and recutting the sides of the cut, generating much more heat.
I always find this counterintuitive and scary, but you want to be very close to overfeeding to get the best cut and temperature control. |
#482
This is my first try with aluminium. I used 4mm Carbide TiAlN coated bit, spindle 12k rpm, feed 1200mm/min and 0.5mm stepdown.
It machines beautiful and the finish is extra smooth. ![]() bit is from ebay : carbidechiu |
#483
Hi Roos, i thing yuo dont use coolin liquid http://www.limpieza-empresas.com/cat...na-blanca.html and is posible the tool is olso not de best for aluminium http://www.belintools.com/Catalog.pdf ....
#484
For aluminum it's best to use non coated tools. And try lubricating it a with a few drops of lampoil every now and then.
#485
lampoil=kerosene=parafin
#486
As you can read on wikipedia or any other search trough internet I found that TiAlN is ok for aluminium
Thanks everyone for your input.
Aluminium is type is unknown. Cutter was a 3mm Carbide End Mill. Pass Depth .3 mm and Stepover 1.25 12,000 RPM and 10mm/sec feedrate. Feedrate was dropped by 50% after I saw the bit flex on contact. The chips were flakes not spirals and towards the end (as the workpiece got hotter) they were obviously rewelding to the bit and the work. With respect to the cutter size I have been considering using a larger end mill as 3mm is fairly weak even by comparison to a 4mm cutter that Danilo has used. Cheers Ross |
#488
Aluminium Milling
Better this time.
6mm Aluminium Test Piece.jpg A video of part of the process - http://www.youtube.com/watch?v=qnMIMSP-LWc Details... 6mm 2 flute HR45 Carbide End Mill at 1200RPM 0.3 mm Depth of Cut 20mm/Sec Feed Rate I also periodically stopped and used some welding anti spatter grease on the bit if the aluminium was starting to stick to the bit (you can hear it when it is starting to go wrong). Not perfect but better. Note I cleaned up the outside top edge with some 400 grit wet and dry. Thanks everyone for your help. Regards Ross |
#489
Instead of simple plunge , do a ramping plunge, and you can go deeper than 0.3 with 6mm bit.
#490
Ahh of course, that makes perfect sense Danilo.
Ross |
#491
As usual, Nice work Ross!!
Cheers Tony. |
#492
You should be able to increase your feedrate at least 50% with the same rpm.
#493
I agree with Ger, you can keep upping the feedrate. Look for spirals!
#494
Now I'm tempted to have a go....
Good job! |
#495
Will definitely give the faster feed rate ago and watch for the spirals.
Can't help but thinking lots of coolant and lubricants will make cutting aluminium all that much easier. Regards Ross |
#496
I just don't like the BIG MESS that ALU leaves. Wood shavings are much more pleasant.
#497
Agreed Kobus, still finding metal everywhere.
Ross |
#498
Even the dust foot didn't help ro contain the metal chips?
#499
Ken that is the reason they use flood coolant while milling most metals - except for some
#500
Hi Ken
I was not using it as it prevented me using the spatter grease on the work and cutter every now and then. Infran You got that right, with a coolant system in place cutting metals would be significantly easier. Regards Ross |
#501
Demonstrating how the CNC machine works is so much better than just telling esp when it comes to the kids.
A visiting 10 year old future engineer got his name cut out and was very happy with his new possession. The timber was reclaimed from a broken piece of furniture and the capital letter "A" is around 100mm high x 10mm thick. Angus cropped.jpg Regards Ross Last edited by Surfcnc; Sat 28 May 2011 at 00:43.. Reason: clarification |
#502
Greetings All
Recently it has all been about tidying up my work spaces and getting my older tools back into shape. Dare I say it but I killed my favourite 1100 Watt grinder last week, something not to be taken lightly on the MM forum as we all know !! The welding skills I learned building the Mechmate have come in handy as my ageing box trailer had finally passed the 50 percent mark - that is 50% steel and 50% rust. The ladder section base and the A frame have now been nicely re-fabricated so it rolls on for a few more years yet. As part of getting some sanding drums chucked up into my drill press I thought it might benefit from a retrofit with some of those crazy looking but very effective Power Twist belts from Fenner. As promised the belts reduce vibration a treat and have eliminated a harmonic at low speed (160 RPM) and smoothed out the 3000 RPM performance. Fenner belts are appearing on anything that turns in my place after they turned my beast of a table saw into a purring pussycat. Fenner Power Twist Belts in a Drill Press.jpg Once my restructuring and repair of all the support gear is over it will be back to the Mechmate and hopefully a few new and interesting projects. Some of the newer builds on the forum are speeding along and I am totally impressed with the support some of the senior members continue to give. Regards Ross |
#503
I lke those Fenner belts as well but they are VERY expensive here.
#504
They are very expensive here as well!
#505
Expensive everywhere !!
Here in Australia they are wickedly expensive. From the USA the belt is 7 USD a foot plus 14 USD for the initial postage so buying a bit makes it cheaper if their is such a thing. As usual Ebay is your friend. My tidy up continues - today I reclaimed some bench space by making a mobile sanding station for my disk sander. My neighbours entertainment unit is reborn !! No back or doors as the day ran out but should be finished tomorrow. Mobile Sanding Station.gif Regards Ross |
#506
Off the Rails
I know I run off the rails every now and then... it's to be expected!
BUT when the Mechmate gantry runs off the rails that will never do. My machine developed a very bad habit of crawling up off the rails and it was just so annoying. Anyway after a good look, either the LHS motor swing plate bolt had come loose or I had not tightened it properly after some fiddling with the LHS rail. Realistically probably the latter. Just a few simple turns to snug up the plate pivot point turned the MM from a out of control beast to a well behaved machine. Though I might leave a record of the symptom and the fix on the forum for others to stumble across. Stefan MM #73 is doing some nice stuff and Kobus is also knocking out some great creations on his thread. Also whoever "stole" my 4mm collet better fess up soon. I mean there is no way "I" could have lost it is there??? ![]() Regards Ross |
#507
Thanks for posting the off the rails tip. I was wondering what conditions might lead to it.
The person that got your 4mm collet is probably the same one who needed my 8mm one for their set. Definitely time to get the shed in shape! |
#508
Hardwood Timber Plugs
Thanks to Kobus and his post on using the Mechmate as a plug cutter.
I used my Mechmate to cut a few timber plugs for a friend who is building a recycled timber table (complete with pre-existing bolt holes). Plugs2.jpg Regards Ross |
#509
I am a great FOLLOWER.....the original idea came from Hennie. Nice to see it is used by others.
#510
Hi Kobus
Thanks for the attribution to Hennie - now we got a conga line. ![]() |
| wiifm's plans for building in Brisbane | wiifm | Introduce yourself and start planning | 32 | Mon 24 March 2025 02:27 |
| Making Bar Signs! #71 - Brisbane, Australia | AuS MaDDoG | MechMates already cutting | 440 | Mon 12 February 2018 01:40 |
| Touch Probes Have Arrived #72 - Brisbane, Australia | skippy | MechMates already cutting | 130 | Mon 04 March 2013 05:31 |
| Do my legs look fat? - Brisbane Australia | tangocharlie123 | Construction started, but not cutting yet | 60 | Wed 22 June 2011 07:32 |
| New member - Brisbane Australia | stan stuart | Introduce yourself and start planning | 3 | Tue 11 May 2010 21:48 |
