Old Sat 14 May 2011, 05:42
garymo
Just call me: garymo
Canberra
Send a message via MSN to garymo
Gmax-CNCtoolkit script & EMC2
Im planing to use this combination and was wondering if anyone else is using this combination, and if so how is it working out for you?
Old Sun 15 May 2011, 00:01
lumberjack_jeff
Just call me: Jeff #31
Montesano, WA
I haven't used gmax, but emc2 works well.
Old Sun 15 May 2011, 05:26
garymo
Canberra
Thanks Jeff,
How easy to set up is it and are you running a VFD and spindle of it?
Old Sun 15 May 2011, 09:46
lumberjack_jeff
Montesano, WA
No, I use a router. By all accounts it's more difficult to set up than Mach, but it's very flexible.
I had zero previous experience with motion control before installing this, but I use it in its most rudimentary way.
Lots of people are using EMC2 for spindle control, z-plates and touch probing, but it's not plug and play.
Gmax suggests that you intend to use a 4th axis?
Old Mon 16 May 2011, 03:16
garymo
Canberra
Gmax from what I can gather will handle extra axis which i eventually want to do but another good thing for me is it runs off the 3d max interface and it's also free.
Thanks for the advice on e=mc2 as you say it's not plug and play but the ability to use it for different applications is an atraction for me.
I like these open source programs as they are a bit like the mechmate experience.
Old Sat 06 August 2011, 02:40
garymo
Canberra
New videos of cnc toolkit posted here
http://www.youtube.com/user/cnctoolkit
EMC2 - LinuxCNC (open source "free") Gerald_D CNC motion control software 27 Fri 24 December 2021 21:54
Setting up EMC2 servant74 CNC motion control software 62 Wed 08 November 2017 23:03
G540 running under EMC2 and Linux #10 - Somerville MA USA bradm MechMates already cutting 68 Thu 11 March 2010 09:13
Setting A-axis terminal as X2-axis in EMC2 KenC CNC motion control software 2 Wed 27 January 2010 06:40
Homing Sequence In MACH3 and EMC2 kkilst CNC motion control software 3 Mon 25 May 2009 11:02
