Thread Tools |
#61
Hello Irfan.
I bet your having a great time, no matter the doubts you can get. Keep going. I like your solution to the limits switches. I was thinking in involving them in a very soft plastic to protect them from the powder. |
#62
RGDS Irfan |
#63
Irfan & Hugo, all dust evacuation systems have a problem to work correctly at the edge of the board. When you are right on the end of a board, the cutter gets exposed.
Irfan, you have the right idea to lift a mechanical switch up, away from a flat surface where dust will collect. Also, the holes in the switch must point downwards (like you have it) so that the dust will fall out. |
#64
Hi Gerald and All,
I had a Q 1. for the timing pulleys which i will be using to drive the pinion can i use just the grub screws to hold the pulley's in place or is it necessary to have a key to bind it with the shaft. 2. If only grub screws can be used tehn how many, I was about to put 3 each 120 degree apart........is it OK 3. I expecting a center distance of 325mm, will that matter much? 4. I will be using a HTD 8 mm pitch belt. is it OK Regards Irfan Last edited by javeria; Tue 25 September 2007 at 08:33.. Reason: added more Q |
#65
Hi,
Any answers to my previous questions RGDS Irfan |
#66
CNCzone
#67
Righto Gerald,
I moved my thread to the CNC Zone, I will keep posting updates on this forum when ever there are major updates on my thread at CNC Zone, Gerald, thanks for all the inspiration. Next a mechmate in in my mind. I already have the vampires. So see you all guys later at CNC Zone my address will be http://www.cnczone.com/forums/showth...147#post347147 Thanks for all the help! RGDS Irfan |
#68
