Old Sun 10 April 2011, 00:58
Well done so far. Looks like a A380 could land there.
Old Sun 10 April 2011, 02:57
234ahmed
Just call me: Ahmed #81
Damietta
Egypt
well done Melissa. You almost there
Old Sun 10 April 2011, 03:57
Good job! Almost... Almost...
Old Sun 10 April 2011, 15:50
melissa
Just call me: Melissa #83
Brighton (Ontario)
Motors Turning!
Moving right along... I've got the essential bits of wiring hooked up, and the motors turn under mach3 control. I still need to do more wiring (for the pushbuttons, e-stop and proxies) but I'm really happy that it works so far!
This will all be much neater when it gets installed into the control box .
Old Sun 10 April 2011, 17:16
purpura
Just call me: Gonzalo
Segovia
Spain
simply beautiful your machine .. thanks for illustrate the tricks
construction .. Gonzalo greetings.
I seem to see in the photos that you have used flexible leveling legs, so I thing this legs will give you unwanted vibrations problems on the machine.
Old Mon 11 April 2011, 12:03
camilleg
Just call me: Camille
Urbana, Illinois
Each foot has a screw thread, with bolts and lockwashers. The foot itself is rubber, but very hard rubber, harder than an automobile tire tread. Its resonant frequency is probably higher than the table's. I bet that the feet are stiffer than the table itself.
Old Mon 11 April 2011, 12:17
camilleg
Urbana, Illinois
Kobus, on final approach a hundred metres directly above this MM you'll find no mere A380s. We snapped this pic ten paces from the front door. (Google Earth Brighton Ontario, head east 10 km, and you'll see why.)
Old Mon 11 April 2011, 13:03
Now that is BEEEG!!
Old Mon 11 April 2011, 14:21
melissa
Brighton (Ontario)
Introducing Brighton International MechMate Airport:
Old Mon 11 April 2011, 14:24
melissa
Brighton (Ontario)
A few more, farther down the runway:
And taxiing:
Old Mon 11 April 2011, 14:26
melissa
Brighton (Ontario)
En nog eens De Vliegende Hollander, natuurlijk:
Old Mon 11 April 2011, 14:35
ok...now that's funny. I needed that levity today!
Cheers.
Old Mon 11 April 2011, 14:47
camilleg
Urbana, Illinois
BIMA you say? Here's one for $88,000.
Old Mon 11 April 2011, 15:27
Looks almost to scale!
Old Tue 12 April 2011, 01:51
Jan de Ruyter
Just call me: Jan
Pretoria
Heel leuk!
I always wonder how many people of Dutch origin are living around the world? Must be more than the total population of Holland.
Old Tue 12 April 2011, 03:00
Grappig
Old Tue 12 April 2011, 09:04
rischoof
Just call me: Rik #92
Goirle
is inderdaad leuk, ook om wat nederlands te zien
Old Tue 12 April 2011, 09:39
camilleg
Urbana, Illinois
Zeker zie ik hier Nederlanders van allerlei landen... maar niet van Nederland zelf?! Moeten wij ons maar bovenlanders noemen?
Old Tue 12 April 2011, 11:29
skillalot
Just call me: Sascha
Gelderland
Jawel hoor, ook van Nederland.
Old Tue 12 April 2011, 12:54
Jan de Ruyter
Just call me: Jan
Pretoria
Sascha, hebt je naam "skillalot" iets te doen met piepers jassen?
Old Tue 12 April 2011, 13:58
camilleg
Urbana, Illinois
(Trying to un-hijack this thread from the Dutchmen...) Jan and Sascha are now talking about "piepers jassen" which means peeling potatoes. The 'guy' way to do this is impaling the spud on a quarter inch drill bit and spinning it near a pocketknife. Surely a MM would do a better job on this, or other repetitive culinary tasks?
Old Wed 13 April 2011, 02:28
skillalot
Gelderland
Nee, niks met piepers schillen hahaha.
Terug on topic dan maar.
Old Fri 15 April 2011, 18:58
melissa
Brighton (Ontario)
Work is progressing on aligning the rails. I built an "alignment car" in the same style as some others here, to make this process easier.
The distance between the V wheels is the same as the bolt spacing. I used a 10-lb lead scuba-diving weight to balance and steady the car. It was still tending to hit the legs of the table, so I added some weight (the step blocks) on top.
The laser is held in place with elastic bands, and is positioned directly over the V to minimize any vertical motion of the laser if the car swings sideways.
The rail off-cuts clamped at the end are for preliminary alignment of the rails, using a fishing line.
Old Fri 15 April 2011, 19:06
melissa
Brighton (Ontario)
Now, what does the laser point at? The door of the workshop, which is 3.5m from the near end of the rails, 9m away from the far end.
I printed off a sheet of custom metric graph paper to act as a backdrop for the laser dot. This was checked against a known-good ruler, to make sure my printer actually printed the dimensions correctly.
The car was positioned at the bolt boundaries (1-2, 2-3, etc) and a photo taken of the graph paper with laser dot, with a handwritten label to identify the car position. Later, I compared the photos on my computer to measure the offsets from one position to the next. These were used to calculate the required shim thicknesses.
Old Sat 16 April 2011, 06:53
Melissa,
Nice explanation of the "alignment car" and the procedure. The pictures help immensely.
So after using the "fishing line" to get your initial alignment, how much variation did you measure using the "alignment car'? I would also be interested in how much variation you measure with the "alignment car" after you shim.
Old Sat 16 April 2011, 22:02
melissa
Brighton (Ontario)
I used the fishing line for lateral adjustment only. I used the car for vertical adjustment.
The weird part is that my baseline measurements show a maximum variance of 0.25mm on the Xa rail. (I'm calling the rail closest to 0,0 "Xa". The other rail I'm calling "Xb").
Now after shimming, I'm calculating a max variance of 0.45mm, but with fewer peaks and valleys. I don't know... maybe my math is off, maybe I'm just going crosseyed from staring at spreadsheets .
At any rate, the laser dot wiggles around much less when I roll the car down the track now.
I didn't find much on the forums about what tolerances others are shimming the rails to. What's typical? Is 0.45mm (about 20 thou) good enough? I can already picture Gerald rolling his eyes... .
Old Sat 16 April 2011, 22:19
Old Sat 16 April 2011, 22:22
HomeMadeCnc
Just call me: Tim
Calgary, Alberta
I spent a week and a half chasing .015, in the end I cant tell the difference. Just get it going, the fun stuff just begun
Tim
Still climbing the learning curve
Old Sat 16 April 2011, 22:25
Think about:
The gantry rides on a couple of rollers, so it takes a average/smoothed height
You "surface" the table to follow the rails
The material that you are cutting is mostly thin and bends to follow the table surface
For thick materials, what will you be cutting that needs a perfectly flat surface?
Old Sun 17 April 2011, 02:00
I did not even SHIM my rails...bolted the rail on the C-channel, surfacd the table, surfaced the sacrifice board and happily cutting for a while now without any problem.
dust collector capacity gorantec 55. Dust Management 15 Thu 19 November 2009 20:24
Dust foot and custom clamps done #3 - Conway, AR Doug_Ford MechMates already cutting 195 Mon 13 October 2008 21:27
Dust collector foot Marc Shlaes Dxf Library 7 Sun 27 April 2008 20:18
Dust Collector Foot Doug_Ford 55. Dust Management 34 Fri 04 April 2008 11:01
Dust collector foot Art 55. Dust Management 5 Sun 17 June 2007 14:09
