Thread Tools |
New Gecko Faulting - RED LED
Just picked up a new Gecko 201X today. All axes are in working order. However.......
The new Gecko is faulting with a red LED. Tried to reset but no luck. Haven't found any other reference on the Gecko site yet. What is going on and how do I fix this? Voltage is measuring 56.6 like the 3 existing Geckos. Current is set at 3A same as the others. Opened the drive and blew some air to clean it. Nothing. I feel like the Gecko Gods are against me in completing the machine ![]() |
Did you try to put in into a known working spot?
Suggest you disconnect the motor from the Gecko at the Gecko end, and measure the resistance of the wires + motor to see if it is what you expect - the same low resistance value across both A and B phases, open circuit between phases, open circuit to ground.
I had some problems with the gecko related to loosy conectors .... does change anything if you move with yours fingers the conectors ? I had to dismantle the conector and tight the contacts ....
Sergio, I called Gecko when I first had the problem but don't remember what technical support told me. I remember testing it with a multi-meter and everything checked out so I kept it in the control box. It's still in use and I haven't had any problem with that axis.
I don't use Gecko, but are your signal ground connected to the power ground?
They should not be connected. |
Ken, Tuan fixed his problem more than a year ago. Sergio only saw his post yesterday
opps
| Alternatives to Gecko Drive? | liaoh75 | 70. Control Systems | 4 | Sun 09 May 2010 12:03 |
| Gecko / Motor Tuning | sailfl | 701. Motor Drives | 9 | Tue 06 April 2010 13:13 |
| gecko 210 | WOODCHUCKMAN | 701. Motor Drives | 3 | Sat 21 February 2009 14:13 |
| PMDX and Gecko 203 | gixi | 70. Control Systems | 6 | Thu 27 November 2008 20:38 |
| How do i wire this which gecko drive to use | eloid | Archives | 1 | Mon 05 March 2007 06:07 |
