Old Fri 25 March 2011, 00:42
tnarch
Just call me: Tuan
Milwaukee WI
New Gecko Faulting - RED LED
Just picked up a new Gecko 201X today. All axes are in working order. However.......
The new Gecko is faulting with a red LED. Tried to reset but no luck. Haven't found any other reference on the Gecko site yet. What is going on and how do I fix this?
Voltage is measuring 56.6 like the 3 existing Geckos. Current is set at 3A same as the others. Opened the drive and blew some air to clean it. Nothing.
I feel like the Gecko Gods are against me in completing the machine
Old Fri 25 March 2011, 05:29
Did you try to put in into a known working spot?
Old Fri 25 March 2011, 11:00
Suggest you disconnect the motor from the Gecko at the Gecko end, and measure the resistance of the wires + motor to see if it is what you expect - the same low resistance value across both A and B phases, open circuit between phases, open circuit to ground.
Old Wed 17 October 2012, 05:18
silverdog
Just call me: Sergio #70
Rome
Italy
I had some problems with the gecko related to loosy conectors .... does change anything if you move with yours fingers the conectors ? I had to dismantle the conector and tight the contacts ....
Old Thu 18 October 2012, 21:15
tnarch
Just call me: Tuan
Milwaukee WI
Sergio, I called Gecko when I first had the problem but don't remember what technical support told me. I remember testing it with a multi-meter and everything checked out so I kept it in the control box. It's still in use and I haven't had any problem with that axis.
Old Thu 18 October 2012, 22:13
I don't use Gecko, but are your signal ground connected to the power ground?
They should not be connected.
Old Fri 19 October 2012, 00:26
Ken, Tuan fixed his problem more than a year ago. Sergio only saw his post yesterday
Old Fri 19 October 2012, 00:56
opps
Alternatives to Gecko Drive? liaoh75 70. Control Systems 4 Sun 09 May 2010 12:03
Gecko / Motor Tuning sailfl 701. Motor Drives 9 Tue 06 April 2010 13:13
gecko 210 WOODCHUCKMAN 701. Motor Drives 3 Sat 21 February 2009 14:13
PMDX and Gecko 203 gixi 70. Control Systems 6 Thu 27 November 2008 20:38
How do i wire this which gecko drive to use eloid Archives 1 Mon 05 March 2007 06:07
