Old Wed 23 February 2011, 14:41
isladelobos
Just call me: Ros
Canary Islands
Spain
The spindles ares three phase?
You can see the 7.5Kw vfd prices. ($700 aprox.)
Normaly here in Spain the home one phase electric contract is 5.5kw.
For 7.5Kw, three phase consumption, is more cheap.
You have solutions.
1- tree phases contract in your home.
2- 7.5Kw VFD (expensive vfd and maybe need more amepres in your home electric box)
3- three phase rotary converter, you need one 15kw rotary converter for move 7.5kw spindle, (need more amperes in your home electric box)
4- connect a cable to the street lamp (free )
Old Thu 24 February 2011, 07:33
alan254
Just call me: Al #95
mystic ct
I have a 400 amp in my shop. it is single phase i can convert to 3. the real question is can the mm handle 10 hp and structually and still run accurately without structual changes
Old Thu 24 February 2011, 11:36
Can you drive a 200 HP car off the street, across your driveway and stop it before it goes through the back wall of your garage?
Old Thu 24 February 2011, 14:09
alan254
mystic ct
all i would like to know is, positive or negitive, will the mm structually handle a 10 hp spindle.. ? i currently have built a rolling mm, wired and ready for a spindle and drive motors and plan to use the preferred drive motors you recomened the oriental w/7.2 reduction. I am not married to the 10 hp spindles, but, I do have them and the cost is nothing if they are not compatable i just won't uses them.. if they are maby i can another mm builder out since i have 2. see thread #1 in parting out a non mm machine
thank you
Old Thu 24 February 2011, 16:45
Al, I believe that Gerald's point is that a 10 hp spindle is more power than you need, but if properly installed and operated, it will work. You'll obviously have to make the appropriate adjustments for the extra weight.
Gerald, I can normally drive a 200 or 300 HP car off the street, up my driveway, and into my narrow garage. Unless I've been manufacturing too many shims, in which case I don't drive.
Old Thu 24 February 2011, 20:59
Alan, the point is that the horsepower rating has nothing to do with whether you can use it or not. You will have to make a judgement if it will fit in the MM.
Old Fri 25 February 2011, 06:38
alan254
mystic ct
thanks all
Some IC's needed for another project Gerald D Miscellaneous / General / Whatever / Catchall 11 Wed 23 September 2009 13:26
Horse jump with pink butterflies mikefoged The Show Room 4 Tue 14 July 2009 06:39
Is a second motor needed for the other side of the Y-car? fabrica 30. Y-Car 6 Fri 11 April 2008 13:07
Height detector needed JoeJakey Miscellaneous / General / Whatever / Catchall 12 Fri 28 March 2008 06:32
Calculate the Voltage and VA size of the DC power supply needed to build or buy Gerald_D Archives 38 Wed 23 January 2008 10:29
