Old Wed 02 February 2011, 07:01
Builder's Log Update
Thanks for the updates, Rceja.
We are proud of your MechMate too. And such a quick build, only 3 months, less than half the AVERAGE. Good luck as you learn to use your MechMate and keep us posted with pictures (please) of your projects.
Old Wed 02 February 2011, 17:24
PEU
Just call me: Pablo
Buenos Aires
Felicitaciones!!
Originally Posted by Kobus_Joubert View Post
In South Africa, we have burglar bars in front of all windows..We stay INSIDE our 'jail' and the thieves are roaming the streets.
Same here
Old Wed 02 February 2011, 17:37
Houses look somewhat the same here aswell, you don't have bars if you have a wall of 3 meters though!! That was quite a change when I moved from holland where the biggest wall around a garden is something you can jump over.
Old Fri 04 February 2011, 16:10
isladelobos
Just call me: Ros
Canary Islands
Spain
Felicidades !! por esa máquina.
Ahora a hacer mucho polvo
Saludos.
Old Fri 04 February 2011, 20:14
rceja
Just call me: rceja
jalisco
Mexico
Send a message via MSN to rceja Send a message via Skype™ to rceja
Gracias Ros!!!, finalmente estamos listos para llenar el taller de polvo, ahora deberemos pensar también en la manera de realizar algunos trabajos para recuperar algo de $$$$$, pues nos hemos quedado casi sin plata, jejejej. Sin embargo nos queda un camino largo en la comprensión y aprendizaje del software correspondiente, pero ahí vamos sobre la marcha!!!!!, de igual manera estamos listos para romper cortadores, clamps y lo que sea necesario para aprender, jejejej.
Old Wed 16 February 2011, 20:25
rceja
Just call me: rceja
jalisco
Mexico
After a while learning about the cam software, finally we did our firs alu cut, we cut or reductor alu plates. It feel fine when you see the MM cutting alu like butter (0.5 mm per pass), 10000 RPM, 6 mm cutter and 20 IPM. Finally we got our plates and the bearings fit just fine, we are very happy of that. We show you some picutres of our plates!!!!
Old Wed 16 February 2011, 20:43
tnarch
Just call me: Tuan
Milwaukee WI
good work! thanks for sharing the specs as i will need them soon for my reduction assembly.
i notice in the pictures you are using a laptop. any issue with mach3? can you share your laptop specs? i'm temporarily running the machine with a laptop but i get buggy responses when using the arrow keys for jogging the axes.
Old Wed 16 February 2011, 21:01
rceja
Just call me: rceja
jalisco
Mexico
Hi Tuan,we use the laptop just for designig with the CAM soft, we have a desktop running Ubuntu and EMC2 to control de MechMate, in fact our laptop does not have a paralell port!!!, i beleive that laptops are not recommended because of latency issues.
In a while i will upload a small video cutting our plates!!.
Thanks for your comments!!!!
Old Wed 16 February 2011, 21:46
rceja
Just call me: rceja
jalisco
Mexico
And now,the video of the MM cutting our al reductor plates!!!.
http://www.youtube.com/watch?v=Xyoc0GS33VM
Old Wed 16 February 2011, 21:52
So, how did you hold the part down? It sounds like (in the movie) when you translate to the x-cut you get extra bit chatter from the part moving.....or am I missing something?
Old Wed 16 February 2011, 21:59
rceja
Just call me: rceja
jalisco
Mexico
We use double adhesive tape, several strips along the alu piece, that way you can get a strong holdig force. That's all we did. No chatter at all, in fact it was quite difficult to remove the tape once we finished cutting.
Old Wed 16 February 2011, 22:10
Cool - You have to love machines that help make themselves better
Old Wed 16 February 2011, 22:16
rceja
Just call me: rceja
jalisco
Mexico
You are right Mike, we love so much our MM, and we are still begening to know it!!!!
Old Thu 17 February 2011, 07:17
GC3
Just call me: Eugene Beaufort Crain III
San Jose del Cabo
Mexico
Nice work! Well done, thanks for posting. See you on skype...
Old Sat 19 February 2011, 14:38
albertoslayer
Just call me: albertoslayer
san blas
Mexico
Que tal yo soy de Tamaulipas y también estoy construyendo una mechmate después publico las fotos y a ver si me puedes ayudar en algunas dudas saludos!!
Old Sat 19 February 2011, 17:06
rceja
Just call me: rceja
jalisco
Mexico
Con gusto, en todo lo que este de mi parte.
Que bueno que estas en esto,ademas de divertido es una actividad muy interesante.
Felicidades y estoy a tus órdenes.
Old Mon 21 February 2011, 12:31
albertoslayer
san blas
Mexico
Muchas gracias rceja, mira yo empece el proyecto hace tiempo pero lo deje y pues ahora lo estoy retomando ya tengo casi todo lo electrónico y de lo mecánico pues si me faltan algunas cosas, tengo 4 motores de 740 oz pero medijeron que necesitaba utilizar un reductor 3:1, tus motores ya vienen con reductor o tu lo hiciste es que la verdad se me dificulta mucho conseguir las poleas dentadas, la mayoría de las piezas yo las mande pedir a usa pero es mucho rollo para pagar y luego tener que ir por ellas que me recomiendas que haga?, saludos!! Ahh otra duda tus motores de cuanta potencia son es que no se si sean pequeños mis motores o necesito otros
Old Mon 21 February 2011, 13:46
rceja
Just call me: rceja
jalisco
Mexico
Que tal Alberto. Mira mis motores son pequeños son de menos de 450 Oz, por tanto creo que tus motores son adecuados. Hasta donde entiendo, el reductor se usa principalmentre para que los coretes sean mas finos, si tu trabajo no es de muchisima precision, entonces no creo que requieras de reductores.
Nosotros conseguimos y hemos conseguido poleas en un huesario industrial que hay por aca, me imagino que en tu ciudad debra haber huesarios similares. Pero si te interesas en las poleas yo buscaria la manera de conseguirtelas aca visitando de ves en ves el huesario como lo hago por costumbre.El reductor nosotros lo fabricamos, de hecho el blog puedes observar las placas de aluminio que cortamos.
Si te interesa te consigo las poleas y te dibujo las placas para que las mandes a cortar alla, te las mandaria en DXF, deben existir empresas que corten aluminio en tu ciudad.
Nosotros las cortamos en nuestra maquina (checate el video que esta mas arriba), nos quedaron bien. como te comento, nuestros motores son pequeños por esa razòn requerimos de los reductores.
Saludos.
Old Mon 21 February 2011, 20:28
albertoslayer
san blas
Mexico
Te lo agradecería mucho si pudieras consegurimelas y yo te deposito el dinero, y pues me surgió otra duda, veo que hay partes que se tienen que mandar cortar en láser, ustedes las mandaron cortar en Guadalajara ?? y como en cuanto sale mandarlas cortar? Y vi que también tienen dobleces eso lo hicieron ustedes? O también lo mandaron hacer, jaja perdón por tantas preguntas pero es que son los primeras personas de mexico que conozco y yo he batallado mucho en conseguir las partes, les mando saludo y gracias!!
Old Thu 24 February 2011, 14:09
rceja
Just call me: rceja
jalisco
Mexico
A video of our belt reductor moving !!
http://www.youtube.com/watch?v=eKl5K0-1z5g
Old Thu 24 February 2011, 21:21
rceja
Just call me: rceja
jalisco
Mexico
One more picture, this one is our first cut of this kind.
Is 3 mm MDF. cut depth 1.5 mm
Old Fri 25 February 2011, 00:46
That made a lot of dust!
Old Fri 25 February 2011, 09:16
rceja
Just call me: rceja
jalisco
Mexico
Certanily Gerald it did!!!!, We want to thank you again for sharing this wonderful project
Old Sat 16 November 2013, 23:30
rceja
Just call me: rceja
jalisco
Mexico
after a long time out of the game, finally we are on again in a new location.
I this place it is quite difficult to get a 220 vac line, so we decided to rewire a toroidal transformer to drive the VFD for the spidle. It worked fine !!!!!!!
Old Sat 16 November 2013, 23:48
rceja
Just call me: rceja
jalisco
Mexico
Rhis is a gif picture of the arrange
Old Sun 17 November 2013, 07:26
Welcome back!
Mexico's 1st Mechmate Finally is cutting #55 - Obregon, Mexico Conrado_Navarro MechMates already cutting 128 Mon 18 November 2013 13:38
3D Elk cutting (video) #13 - Hagerman, New Mexico Greg J MechMates already cutting 415 Sat 05 September 2009 21:28
Extruded wood? - actually a composite of wood and recycled plastic . . . . . Gerald D Miscellaneous / General / Whatever / Catchall 2 Wed 02 July 2008 23:51
My first cuts bbreaker The Show Room 2 Mon 23 June 2008 00:06
