Old Tue 19 October 2010, 13:43
AJWConstruction
Just call me: Jon
Yucca Valley CA
Mach3 to HY series VFD on/off control
Hello all,
I had to replace the spindle on my CNC router after the winding went bad. I took a chance and purchased an Air Cooled 4kw Chinese spindle and VFD, the spindle works good when I used the VFD to stop/start it. I used the same connections on the new VFD- DCM & FOR as were used on my old one. I went into the programming menu and changed pd001 to 1 and pd002 to1. I also made the changes to the ports/ pins output setting in mach3.
I still have no stop/ start via mach.
Any help would be greatly appreciated.
thanks
Jon Alwine
Old Tue 19 October 2010, 19:07
Jon,
Are you certain that the DCM and FOR are the correct location?
Additionally, check to make sure there is not a secondary setting after enabling the contact closure for "std run or " 3 - wire run" functionality.
On occasion, you have to also tell it to DISABLE looking for a rs232, +/- 10VDC or 4-20ma potentiometer control.
Can you post a link to the manual, I might be able to assist further.
Old Tue 19 October 2010, 19:53
Kenrbass
Richmond Tx
The next to the last post on this thread has a wiring diagram along with good info on setting it up. It helped me quite a bit, but I am not running Mach, so I can't help on that section.
http://www.mechmate.com/forums/showt...hlight=chinese
Ken
Solid State Relay (SSR) for switching Router under control of Mach3 Gerald_D 70. Control Systems 77 Tue 07 January 2020 19:43
Finished writing plugin for Mach3 to control the VFD via RS-485 - Adelaide, Australia MattyZee MechMates already cutting 99 Sun 06 March 2011 05:05
In need of a little advise from the experts...series or half-coil wiring? jeffa Motors & their mountings 7 Mon 17 August 2009 12:57
Delta Variable Frequency Drive VFDB series - (for the spindle motor) Gerald_D 701. Motor Drives 8 Tue 25 November 2008 11:08
Power supply transformer - series/parallel of the output (secondary) side ekdenton 702. Power Supplies 2 Wed 27 February 2008 09:01
