Old Tue 13 April 2010, 18:40
shelbygt500buddy
Just call me: kyle
stuart fl
hiwin linear rails on ebay
Hi i found hiwin linear rails on ebay about 4 foot long comes in pairs with 4 trucks. By the time i did the math on the custom made rails with angle iron and the crazy expesive v bearings i decided for the little extra cost to go with the linear rails look into them see if they will work for you im very pleased with them.
Old Thu 09 September 2010, 22:47
Mojo
Just call me: SolarImages
Bisbee, AZ
Kyle A photo of your modification would be greatly appreciated please.
Old Sun 12 September 2010, 15:39
shelbygt500buddy
Just call me: kyle
stuart fl
I saved money where i could. I work at a sheet metal fabrication shop so i knew where i could change some things... I didnt have anything cut out by laser. But i wish i had now but its to late. But this is the modified z and x axiis.
Old Sun 12 September 2010, 22:04
Impressive! That must had cost a bump! Did you shim the rail? & how do you make the rail straight?
Old Mon 13 September 2010, 08:45
shelbygt500buddy
Just call me: kyle
stuart fl
The price was about 500 in the end i believe. But the best way to get the rail straight is a laser jet. I used a cnc punch but the problem turned out that the punch slightly warped the 1/4" material so i had to restraighten it which led to boaring out the holes in the rails in some locations. Then i tapped the wholes with a 1/4-20 roll form tap. And all the holes where precisely placed so all i ahd to do was mill the end of each rail till the nested perfectly together. I have not shimmed my rails yet since I have not finished everything on the machine and its not sitting where im keeping the machine. I know the machine wont flex much but i figure its a waste of time at this point.
Old Mon 13 September 2010, 10:47
Mojo
Bisbee, AZ
very cool thanks for the pic's
Old Sat 09 July 2011, 18:57
tcheney2000
Just call me: Terry
Victoria, Texas
Kyle,
I've been looking at linear bearings too. What size did you use and how are they holding up? Also, how did you determine size?
Thanks, Terry
HSD spindles currently for sale on eBay jeffa The Market Place 18 Tue 17 August 2010 17:20
Bought Linear Rails, Help mounting (non-MechMate) shelbygt500buddy Archives 4 Sun 29 November 2009 21:07
Geckos on Ebay 275 for 3! stefanv Archives 0 Fri 08 February 2008 10:59
Anyone has any idea if this drive is something I could use off eBay? Kim Mortensen Archives 1 Thu 08 February 2007 18:40
Linear bearing Z slide Dirk Hazeleger Archives 25 Fri 03 November 2006 09:01
