Old Sun 25 July 2010, 06:34
That's a nice speedy build!
Old Sun 25 July 2010, 10:19
Okes in Gauteng are always quicker that the laid back Capies
Old Sun 25 July 2010, 10:21
Zzzzzzzzzzzz
Old Sun 25 July 2010, 10:45
Pictures, Pictures, Pictures ..... so us your pictures
Old Sun 25 July 2010, 14:03
Yes Cois even Afrikaans pictures is ok.
Old Thu 29 July 2010, 04:15
Doing this for Cois.....so here goes....just helping where I can.
Rail grinding
I build the skate from plate that was cut by a guillotine and weld together to get all the angles right. Couldn’t wait for the CNC boys.
I struggle to grind the rails, could not get the sparks fly. After investigation I see that the grinding disk (Pfert) glazed more than it was grinding. The white ring is the area that is supposes to grind.
When I switched to a cutting disk (but 2 on top of each other to get support), the sparks fly!
After some “grinding” with a cutting disk.
Control box
Stepper motors: Motion king 34 HS 9801
I build a “chimney” to cool the heat sink.
1) Air inlet though Filter on bottom of control box
Old Thu 29 July 2010, 04:18
Air go through control box and down the “chimney” on the back of the heat sink of the Gecko’s.
The exhaust fan sucks out the air on the out side of control box
The Machine
Old Thu 29 July 2010, 04:19
My work clamping mechanism
Router mount for Makita router & Dust Mounting
Old Thu 29 July 2010, 05:24
And all of this for under R 24000.00.....
Old Thu 29 July 2010, 06:22
Kobus you have seen the dust , its blue and labled. Looks like it's SN time !! #63
Old Thu 29 July 2010, 06:34
I like the snorkle arm for the Monitor/Keyboard
Old Thu 29 July 2010, 08:44
Lex
Just call me: Johan #56
Empangeni KwaZuluNatal
Geluk Cois!
What did you get for free to build it for only R24 grand?
Old Thu 29 July 2010, 09:14
He has the proof......the spreadsheet he showed his wife
Old Thu 29 July 2010, 11:49
Hmmm... creative spreadsheets, he must be an accountant
Old Thu 29 July 2010, 23:51
Waar is die blou bull Horings.? What is the cutting size of your table?
Old Fri 30 July 2010, 07:05
Builder's Log Update
Cois,
Congratulations on completing your MechMate and earning Serial #63.
Please let us know the cutting dimensions of your MechMate for the Builder's Log.
Also, please review the Builder's Log and let us know any changes you wish to make.
Old Mon 02 August 2010, 22:43
Congrats Cois
Old Fri 15 July 2011, 09:04
Cois
Just call me: Cois #63
Pretoria
I decided to build an overhead crane to manage the “heavy” and large load in the workshop. The max load is 400kg.
After some trouble to move along the long axis I decided to use a second hand gate motor (R450) to do the hard work. Travel speed is 150mm/sek.
For the lifting I went to Adendorf for a 400kg electric hoist.
http://www.tooltime.co.za/ProductDetails.aspx?id=287
The original control of the hoist has an emergency mushroom switch that was taken out and replace with a stop/start switch that do the switching of the gate motor with some relays.
Old Fri 15 July 2011, 09:14
bolingerbe
Just call me: Bryan #54
Clinton(Tennessee)
I like it. The place where I purchase steel uses these. Although they are a lot bigger, I love to watch them move things around. As my shop is getting smaller and smaller and, I want to buy more and more I plan on moving my welding and other metal working tools out of the current shop and build one to house the metal gear and build a paint booth in the new shop. It maybe a few years down the road but I do plan on installing an over head crane also.
Old Fri 15 July 2011, 13:09
Impressive...well done
Old Fri 15 July 2011, 20:32
zumergido
Just call me: Fernando
BS AS
very nice. clever and cheap..
Old Fri 09 September 2011, 16:25
Cois
Pretoria
Build a Tongue jig for my MM.
Had a problem today, the MM is losing steps in the Z dimension. If I set the Z to zero to the top of the work piece, after a while it is no longer correct.
After played (with the MM you just play, it is not work) with everything and make sure all the nuts and bolts are tighten. I come to discovery that acceleration and deceleration value of the Z motion is too large.
After some software adjusting in Mach, everything is now working fine.
http://www.facebook.com/media/set/?s...3594325&type=1
Old Fri 09 September 2011, 16:37
This is one of the small downfalls of an open loop control system. Steppers are told to go a distance via steps, but without feedback to the amplifier. With no Absolute reference outside of the drive train, it's easy to loose steps if the inertia of the machine or the objects attached to automated device cause it to exceed what it was told to do.
Good troubleshooting to get the ramps on the accel/decel down to fix it.
I generally will set the accel/decel to a very moderate setting to troubleshoot missed steps on a cnc machine to make certain it wasn't induced by operation.
Thanks for sharing
Old Mon 19 March 2012, 23:04
Cois
Pretoria
Did anybody play with making dove tails on our MM.
Any software suggestions that we can hook on to MM.
I have found the following for Mach: http://cnc.wagnercraft.com/help
Old Tue 20 March 2012, 01:19
Is this your 'yearly' post to the forum Francois
Old Mon 26 March 2012, 14:17
Cois
Pretoria
On many occasions I have to cut many parts from wood that are the ame. The wood and bits is relatively inexpensive, but my time is valuable. You can only work with your MM from 17:00 to 20:00 in the evenings or the noise from the neighbors is louder than the MM.
I want to let the MM shut down automatically when the machine is finished with a job (program). After I have setup everything, press "Cycle Start" in the morning and of we go to my daytime work. The reliable MM go on and on until the end of the program is reach and switch everything off with the e-stop circuit. The computer is made ​​for be on the whole day. (yeh -yeh I know it is not green)
If a tool breaks or there is an error on the work piece, it is worth the time of.
At the end of the program M9 (flood off -output pin 14) is switch off and use this to break the e-stop mode circuit.
Your valuable input is appreciate!
Receive today my license for the dove tail software (Mach Wizard) from Alan Wagner.
http://cnc.wagnercraft.com/dovetail
Old Mon 26 March 2012, 14:36
What about a fire? There have been instances where a cnc has caught fire, I dont think I would not want to off site if an accident happened.
Spoilboard Fire
Old Mon 26 March 2012, 23:33
I too has a char spoilboard. Earlier incidences were bad enough that I had to replace it.
After I had my vacuum holddown, I can smell the burn earlier & hence had char spots small enough to just leave them there.
All these happened with me by the machine; Imagine if its left unattended!!!
From experience, few possible cause of fire,
1) Feed rate too slow + spindle too fast
2) Blunt tool bit
3) Fine saw dust sprinkle on open flame...
Old Tue 27 March 2012, 00:38
I personally would not leave it alone. I like to be in the area....even if you cannot see it as long as I can hear it. Things like to go wrong when you least expect it. Get the GARDEN ENGINEER to check on it during the day....or put a remote video camera in that you can monitor from work ...with a E-Stop and fire system that can be triggered remotely.
Old Tue 27 March 2012, 03:06
Be sure to put a fire alarm and sprinkler
Welding up the Table - Pretoria S. Africa CoRn3 Construction started, but not cutting yet 73 Sun 13 March 2016 05:39
New Things - Pretoria, South Africa Marinus Introduce yourself and start planning 11 Tue 22 December 2009 01:50
New MM in Cape Town, South Africa anton Construction started, but not cutting yet 24 Thu 03 December 2009 10:13
Hi there Dave from South Africa kooskoek Introduce yourself and start planning 14 Mon 17 August 2009 10:09
