Go Back   MechMate CNC Router Forum > Common Assemblies & Parts > Profiled (laser cut) & bent steel plate
Old Fri 17 November 2006, 09:45
fabrica
How many laser profile cut components required per part number?
In the CNC profile cutting drawings, have you mentiond how many units are required from each drawing. For instance if we take the motor mount drawing how many units do we require . I assume that it should be 6 units.
Old Fri 17 November 2006, 10:46
Why do you want more motor mounts than motors?
Okay, I must plead guilty in getting all that information out slowly . Also, with the development on the z-slide (to throw out the expensive linear bearing) there are some more laser cutting shapes to come. (3 shapes, qty 1 each)
Anybody who has already ordered laser-cuttings will have no scrap, unless they ordered too many pieces. If the quantities are not clear to you please ask.
I used 5 motor mounts (2 for x, 2 for y and one for z) but a MechMate only has 4 motors. The extra mount on the y-axis is just carrying a roller. I suggest that you order 4 mounts, this gives you the option to have double Y-motors later, or to use the same spring roller that I used. If money is tight, order only 3 mounts to the published drawings. (The z-axis mount will be a different shape)
Old Fri 17 November 2006, 11:22
fabrica
I was thinking of handing over the total job to the CNC cutting facility by Monday. It is better if I could get everything done in one go. The cost would be cheaper if they could quote for the total job in a single go.
I was thinking that you need 2 mounts for the x rail, two mounts for the Y rail (including one dummy) and two more for the Y rail (the max you will need since you have not perfected the drawings).
Old Fri 17 November 2006, 12:43
Here is the latest list of Profile drawings:
The .zip was put in the downloads section tonight. The quantities are as follows....
2 off 10 20 454
4 off 10 20 456
1 off 10 30 422
2 off 10 30 450
2 off 10 30 455
1 off 10 40 422
1 off 10 40 432
1 off 10 40 434
4 off M5 10 012
....but it is Friday night and I might regret it in the morning - please check my quantities against the photos, etc. !
Old Sun 19 November 2006, 07:55
After assembling the z-slide today, 3 profile drawings were revised. (This is the risk of publishing drawings while still prototyping). One could get into the lazy habit of saying it is too much trouble to improve a design because it is too much work to re-publish a drawing.
Old Mon 19 February 2007, 10:28
Loren Gameros
Do I need to have AutoCad to open up the profile drawings that are in "dxf"? Can I use something else to open them that is free?
Old Mon 19 February 2007, 10:49
You have the exact same drawings in .pdf format as well.
But, in general, if you are interested in CNC, you almost certainly must find a way of opening .dxf's
Old Mon 19 February 2007, 12:13
Paco
Check out CAD standard. Still, it may fail to import some DXF...
You may want to see if SketchUp handle 2D DXF nicely...
or you may Google for a DXF viewer. I'm pretty sure you'll find many.
Old Wed 22 August 2007, 03:58
soulvoid
Just call me: Håvard
Stavanger
Norway
cannot PM you back but thank you, I never noticed the zip file in the downloads. And thanks a lot for making these plans available, there are several DIY machine plans on the net that are inferior in many ways where they charge $$$ for the plans.
Am I right when I order this number of items:
1 pcs. 10 20 422
2 pcs. 10 30 450
2 pcs. 10 30 455
1 pcs. 10 40 432
1 pcs. 10 40 434
4 pcs. M5 10 312
1 pcs. M5 10 322
2 pcs. 10 20 454
4 pcs. 10 20 456
regards,
Håvard
Old Wed 22 August 2007, 06:44
Copied from my last order to my supplier:
2 off 10 20 454 + bending
4 off 10 20 456 + bending
1 off 10 30 422 + bending
2 off 10 30 450 flat
2 off 10 30 455 flat
1 off 10 40 422 flat
1 off 10 40 432 + bending (6 major bends only - leave out the tricky small ones)
1 off 10 40 434 flat
4 off M5 10 012 flat
Lot's of differences to my list - let me know what's wrong?
Old Wed 22 August 2007, 07:23
motor mount for X, Y was M5 10 012, is now M5 10 312 and motor mount for Z is M5 10 322. looks like Gerald needs to update his list. found a few others 10 30 422 is right, 10 40 422 is wrong
Old Wed 22 August 2007, 07:25
soulvoid
Stavanger
Norway
I shuffled my list around...
2 pcs. 10 20 454
4 pcs. 10 20 456
1 pcs. 10 20 422
2 pcs. 10 30 450
2 pcs. 10 30 455
1 pcs. M5 10 322
1 pcs. 10 40 432
1 pcs. 10 40 434
4 pcs. M5 10 312
Not too bad. M5 10 312 replaces M5 10 012?? M5 10 322 is missing from your list or is 10 40 422 replaced with M5 10 322?
Old Wed 22 August 2007, 07:48
Well, I havn't built one of these things for a long time! I might look at the list again tonight - but I would think that JR has the list right.
Old Wed 22 August 2007, 10:48
My mind is not ready for all those numbers tonight. Just check the "Higher drawing/s" number in the title block, find that higher drawing and see what numbers it asks for. There is a very clear line/sequence from one drawing sheet to the next. That part must be logical and correct and from there you make your own lists.
(Where is my mind tonight? Fitting RFID transponder tags to 600 000 rubbish bins and patenting an antenna to read them....)
Old Wed 22 August 2007, 12:29
2 off 10 20 454, 5mm or 3/16" thick
4 off 10 20 456, 3mm or 1/8" thick
1 off 10 30 422, 2mm thick or 14 gauge
2 off 10 30 450, 5mm or 3/16"
2 off 10 30 455, 4mm or 5/32" thick (if not available 3/16")
1 off 10 40 432, 4mm or 5/32" thick (if not available 3/16")
1 off 10 40 434, 6mm or 1/4" thick
4 off M5 10 312, 6mm or 1/4" thick
1 off M5 10 322, 6mm or 1/4" thick
Old Fri 09 November 2007, 01:53
Now that a lot of optional drawings are going to be included, the quantities are not so clear cut. See this spreadsheet:
Old Fri 09 November 2007, 20:33
Would this spreadsheet be usefull on the download page as well, for people downloading the plans? Just a thought.
Old Fri 09 November 2007, 20:49
Heath, the spreadsheet is included in the zipped set on the downloads page.
Old Fri 09 November 2007, 21:24
Sorry, I noticed that after I posted it. Probably up too late.
Old Fri 28 December 2007, 19:31
kwang90020
Just call me: krod
California
Hi,
I'm posting for the first time and trying to figure out where the drawing 10 20 454 is. I could not find it in zipped files nor in pdf files. It wasn't even in the spread sheet.
Old Sat 29 December 2007, 16:50
Krod,
Can you give us more information? Why do you think that drawing 10 20 454 exists if you can't find it and it isn't listed on the spreadsheet. Do you see it referenced somewhere else? If so, on what sheet is it listed?
Old Sat 29 December 2007, 16:57
Doug, look at the earlier postings in this thread. The file is listed. I think that Gerald will be the only one that answer this question but I suspect that it was a drawing that is no longer needed.
Old Sat 29 December 2007, 17:14
Krod if I'm understanding right, 10 20 454 has 3 sheets. It's the Carrier Plate, 10 20 454 P D cut, 10 20 454 D B drilled, and 10 20 454 B A bent, it's the ends of the gantry.
Old Sat 29 December 2007, 17:26
JR, 10 20 454 is not listed in the current Mamba drawing package. Do you have an older package?
Old Sat 29 December 2007, 17:33
gmessler
Just call me: Greg #15
Chicago IL
I believe that 10-20-451 Mamba plans replaces 450 (original plans) to account for the higher rails.
Old Sat 29 December 2007, 17:53
Greg I looked at both sets of plans and you are right, 10 20 454 (old plan) is now 10 20 451 (new plan)
Old Sat 29 December 2007, 20:27
DMS
Just call me: Sharma #9 India
Rajasthan
Yes it is becomes in new plans 10 20 451 and 10 20 452 for correct-side drilling of counter sunk holes and bending purpose.
Old Mon 31 December 2007, 13:28
kwang90020
Just call me: krod
California
Smile
Thanks for the info.
Just make sure.
Is 10 20 454 became two drawings which are 10 20 451 and 10 20 452?
Happy new year!
Old Mon 31 December 2007, 17:23
DMS
Rajasthan
There is slight difference between 10 20 451 and 10 20 452. Previously these were 10 20 454.
Mechmaters were facing difficulty becoz since two of these required, and bending and countersunk holes drilled in wrong direction, though resulted in only in wrong orientation of motor.
However Gerald corrected it new drgs and these are also fit for Geared motors.
Old Mon 07 January 2008, 12:32
Glad you guys worked this one out. 451/2 (Mamba) is not interchangeable with 454 (original) mainly because of the motor mount position caused by the Mamba's slightly taller rails. The direction of the bends is a secondary reason for the renumbering. (However, in an emergency, the 454 could be forced to work with the Mamba rails)
