Old Tue 29 June 2010, 12:54
Zouave
Just call me: Eric #115
Sacramento, CA
Grinding Slide Plate
Hey guys,
I'm getting ready to grind my slide plate and trying to work through my available options for doing so, and would appreciate some input.
I have looked at doing it on a table saw and I'm just not enthused by that idea. I have a slow speed grinder with 8" dia wheels that I am thinking about building a jig for to rough it to size, then doing final shaping on the 10" dia tormek wet grinder I have, with the possibility of a final pass on a stationary belt sander to establish true flats instead of being slightly concave. The reason I have the tormek as an intermediate step is that I can better control the cut with that, using the same jig I would use for sharpening planer blades. Any suggestions, given that equipment, of what the best way to proceed would be?
Thanks.
Eric
Old Tue 29 June 2010, 13:47
Eric,
I have found very quick and complete success using the skate provided with the laser parts. If you are using a preground plate that is the proper length, then clamping runoff material on each end will keep you from violating or having to cutting tool steel stock.
Thus (run off plate)(tool steel)(run off plate)
* all placed in a typical bench vise or made up vise of wood material on a sturdy workbench *
The run off plates are sacrificial.
The 36 grit sanding disks do a very good and quick job of this.
Old Tue 29 June 2010, 14:20
Sean to the Z-plate rescue again !
ERIC, I say again as Sean came to my rescue too.
I too was not certain how to take care of the Z-slide, and after following was is suggested by Gearld and Sean convincing me to go with the skate, well…. I tell ya, it’s a lot more easy done than just think or exchange post about it.
Proof in the “pudding” …have a look at my thread on this here.
Your approach MAY be ok, but as I put it to my staff & my kids…. Why do you want to take the long & risky route when the simple one is available and in front of you ???
Hey, my two cent and after all….wishing you great fun on your build !
Amicalement, Robert
Old Tue 29 June 2010, 14:26
Zouave
Sacramento, CA
Heh, unfortunately, the primary reason I am not using the skate is because I don't have one... I went with alum. rails with the bolt-on guides. So not an option right now..
Old Tue 29 June 2010, 14:58
Eric,
Do you have a drill press? Chuck up a grinding mandle and tilt the table to 45 degree's. A little dicey, but with the proper table fixture and hold downs, can be done safely with pretty good precision. "yes, I have done it already for another project with vee wheels as the linear guide."
Old Wed 30 June 2010, 01:51
Besser
Just call me: Besser
Vic
Hey Eric,
I went down the 45deg jig table slotted to expose an 8" bench grinder wheel. Grinding was so easy I (and Chis) completed the grinding under 10min. I was amazed at the finish and consistency, probably the most important was the consistency.
Avoid heat build up by taking light cuts
conduct sequential passes on adjacent sides (you get even grind down to centralise the V)
Flat Plate fabricated slide Gerald_D 40. Z-Slide 120 Sat 30 June 2012 09:12
Z Tube / Z Slide / Quick Release Plate sailfl The Market Place 2 Fri 11 December 2009 07:35
Methods of grinding Z slide dmoore 40. Z-Slide 4 Sun 31 May 2009 06:48
