Old Tue 01 June 2010, 04:14
southernduckie
Just call me: Andrew (Duckie)
new south wales
Lightbulb south coast.... of Australia
It's been a sloooow start but im getting momentum.
the beast will be 2750mm x 1850mm with aproxamatly 250mm z
but i need repeatable accuracy of 0.01mm need some advice on this issue, looking for resolution of at least 0.005mm to ensure acuracy.
mostly aluminium part manufacture and mdf pattern making for casting, one is tolerance specific the other is a rough it out job
any help?
Regards, Andrew
Old Tue 01 June 2010, 07:18
Andrew,
Did you read the other post's regarding your resolution request. Mr. Richards has put together a very good explaination of the expectations of the MM for your review.
http://www.mechmate.com/forums/showt...&postcount=218
Old Tue 01 June 2010, 08:07
southernduckie
new south wales
hi sean,
Oh no i looked it was not there, so i decided to introduce myself again after several years dosen't look good though
cheers andrew
MM Quick Build #63 - Pretoria South Africa Cois MechMates already cutting 71 Sun 26 January 2014 12:30
Laser kits in South Africa nicoferreira Profiled (laser cut) & bent steel plate 12 Wed 08 February 2012 06:36
New Things - Pretoria, South Africa Marinus Introduce yourself and start planning 11 Tue 22 December 2009 01:50
Hi there Dave from South Africa kooskoek Introduce yourself and start planning 14 Mon 17 August 2009 10:09
South Africa's bright people . . . . . . Gerald D Archives 14 Wed 16 April 2008 16:41
