Old Fri 12 March 2010, 13:20
jehayes
Just call me: Joe #53
Whidbey Island, Washington
Scarf cutting file for plywood
Can anyone help me with figuring out how to cut a scarf in plywood using V-Carve Pro? It can either be a step-scarf or a ramp. I just can't figure out how to set it up in V-Carve.
Joe
Old Fri 12 March 2010, 15:11
jehayes
Finger scarfing techniques?
Further to my question above, I found this picture of a finger scarfing system used by a kayak kit maker. Does anyone have any thoughts on how to do this in V-Carve Pro? (I have been to the Vectric Forum and CNC but have found both less than helpful).
Joe
Old Fri 12 March 2010, 15:34
Explain what your trying to do for us.
I got this on a quick search.
http://www.oneoceankayaks.com/stitch.../scarfjig2.htm
here is my search string
http://www.google.com/#hl=en&source=...ec2db39eb50b9d
Mike
Old Fri 12 March 2010, 15:51
jehayes
The ocean Kayaks scarf jig is OK and will work, but I was hoping to be able to lay out the pieces for a stitch and glue boat with the scarfs (step, or finger or ...?) built into the design to be cut out on the MM so that I could then just assemble to pieces. I just found this web site (http://www.duckworksmagazine.com/06/...zzle/index.htm) that has a really good idea but the question now is: how to implement the concept on the MM using VCarve. I assume it involves using the inlay function in VCarve but since I am a newbie on that software I can't get a handle on it.
Joe
Old Fri 12 March 2010, 16:32
Joe,
Most of the time when you talk about scarf joints you mean like:
http://www.duckworksmagazine.com/05/...arfs/index.cfm
Your link took me to a puzzle joint.
ShopBot had a scarf joint that was more like the first one.
So I am not sure which you want help with the first or second. Then I went and looked at Ocean Kayak and it is the finger joints.
You need to create a profile of the finger joints and cut it using the create profile toolpath. Your profile will fit together in the two piece you want to join together. Most likely using an 1/8" bit for the gaps. But you do not need to inlay the cut.
Do you have a profile that you think you want to use? Post it.
IF you are designing a kayak, I am interested and would like to participate.
I have attached a exagerated example because the fingers are 2" wide. So you would make them 1/8".
Old Fri 12 March 2010, 17:19
lumberjack_jeff
Just call me: Jeff #31
Montesano, WA
We build boat kits using puzzle joints. The marine architect we work with believes (and I agree) that a scarf has no advantage, and several limitations compared to a puzzle joint.
See this for an example.
The main limitation with a scarf joint is that (if you use it to assemble precut panels) there's no good way to be really hyper-accurate on the lateral or longitudinal alignment; the scarf does not accurately position the parts. Second, it doesn't provide significantly more panel strength because although the scarf joint allows a greater glue area, the panel's weak point is at the transition, whether it's the scarf transition, or the imaginary line where plywood becomes the joint.
The finger joint above would be a decent alternative, (it provides some enforced lateral alignment if not longitudinal, and it minimizes the straight-line weak point) but it would be slow to cut, create a great deal of waste, and unless I miss my guess all that glue will create an unfair spot - a part of the panel that bends less than the rest.
Old Fri 12 March 2010, 20:34
jehayes
Jeff: That puzzle joint is fine for what I am trying to do. Topologically it is the equivalent of the finger joint Nils provided. So the question remains: once I have the design in DXF format (which I can do) how do I set up VCarve Pro to cut the two sides so they will meld when pressed together. Do I cut one on the "inside" and on the "outside" or both on the inside or what?
Joe
Old Fri 12 March 2010, 21:16
lumberjack_jeff
Montesano, WA
For me, the design of the puzzle shape was the result of a fair amount of trial and error. The shape I came up with is dependent on the peculiarities of my setup. In general, I started with a set of parallel lines (or polylines for acad folks) spaced an appropriate distance - say .010". For the kits we build, maintaining strict positioning between the spliced panels is important, so the profile needs to interlock.
The two lines are then separated and used to border matching panels. Both panels are then cut on the outside.
Most people doing this choose symmetrical profiles, but using the example of dovetails, I don't know that they necessarily need to be.
PS: The shapes used by PT watercraft are not my work. I will post photos of ours when I can.
Old Fri 12 March 2010, 23:01
Joe, I think what you are asking how to cut some joint with V-Carve is the following.
Both pieces you cut on the OUTSIDE of the line.....just make sure that your cutter size matches the joint profile. If the cutter is too big it wil DISTORT your joint..
If your workpiece is big, then go with a big cutter, if it is small, go with a small cutter.
Old Fri 12 March 2010, 23:18
jehayes
DXF example of finger joints
Jeff: Thanks. That tip about the parallel lines is a big help. I did the attached DXF file in TurboCad as a sample and have done a VCarve file which I will test tomorrow. Please let me know if this is what you had in mind (the dovetail version, not the oblongs)
I'll let you know how it goes.
Joe
Old Sat 13 March 2010, 04:37
Joe,
I had to bring the file into aspire to open it what version is the dxf created in?
Old Sat 13 March 2010, 05:27
isladelobos
Just call me: Ros
Canary Islands
Spain
This is the puzle method?
Dxf file.
test.dxf
Old Sat 13 March 2010, 07:34
Joe,
I took your dxf file made the pattern for one. Brought it into Aspire but it will be the same with V-Carve, created a 2D profile tool path, cutting with a 1/4" bit on the outside of the vector using my new favorite test material foam.
This is the results.
Let me know if you have any questions.
I missed the comment that you want the dove tails. Now it becomes more difficult because of the angle in the corner. You have to use a smaller bit.
Old Sat 13 March 2010, 08:21
Joe,
Once again, I took your DoveTail drawing but I added a .125 radius to the corners. Used 1/4" bit cutting on the outside.
Hope these help.
Old Sat 13 March 2010, 09:29
Nils, make it more interresting and do it so that the actual dovetail is only cut halfway on both the male and female side that should give you a verry strong joint so that when you glue them together there is a bigger surface for the glue to sit onto.
Old Sat 13 March 2010, 10:22
jehayes
Nils: That is perfect! Exactly what I needed. Can you just confirm for me what the cutting settings were in Aspire (better yet, send me the .crv file so I can see them).
Many thank. Joe
Old Sat 13 March 2010, 10:23
jehayes
Henny: That is a good idea except I will be working with 1/4 inch ply and am not sure I can cut to those tight tolerances. I will try one and see. Thanks for the excellent suggestion.
Joe
Old Sat 13 March 2010, 10:39
jehayes
Joe,
Nils:
It was created in TurboCad 14.2 I can resave in Version 12 if you still want it but it seems you have imported into Aspire which is the goal anyway. Thanks again.
Joe
Old Sun 14 March 2010, 18:25
lumberjack_jeff
Montesano, WA
In a boatbuilding application, where the panels will be primarily bent around a curve, the point of failure will be the edge of the joint transition. Strength is improved by making this transition as gradual as possible.
There is actually a step above "strongest"; the kayak splice shown upthread. Its problems with it have to do with alignment, fragility for assembly and material waste.
Old Sun 14 March 2010, 19:55
Jeff,
What are the dimensions of the last tabs? Height and width should be the same?
Old Sun 14 March 2010, 21:02
lumberjack_jeff
Montesano, WA
Personally, I use a rule of thumb that for panels which are bent, (as opposed to bulkheads) the joint (height) should be at least 8x the material thickness.
How many dovetails to put per foot of panel width? More ambiguous... I make the width and the height about the same, the main objective is that the joint should minimize the straight line parallel to the bending axis (the seam on the green dotted line) as much as possible.
Old Sun 14 March 2010, 22:09
Jeff, I agree with your logic on what makes the stronger joint. But, isn't the natural conclusion that a triangular finger joint is the best, albeit a bit boring?:
Old Sun 14 March 2010, 23:15
lumberjack_jeff
Montesano, WA
Yes, but... strength is not the only consideration. Boat hull panels are often only a 10" or so wide x 20' (or more) long. It is very easy to glue the sections together with a non-obvious (yet catastrophic) misalignment that only becomes apparent when you're trying to stitch the panels together into a boat shape. The joint not only needs to be strong, it needs to enforce alignment during glue-up.
Granted, a finger joint is better than a traditional (or stepped) scarf, but it still is less foolproof than interlocking joinery.
Old Mon 15 March 2010, 00:17
Years ago we did stepped scarfs (in z-direction) for a boatbuilder, but we also added 2 dowel holes through the joint, which made the alignment a piece of cake. See http://www.dixdesign.com/oneill2.htm
Also, you would only need interlocking at the outer edges, the middle area can be finger jointed.
Old Mon 15 March 2010, 09:30
normand blais
Just call me: Normand
montreal
Example of s.b. wiggle step scarf joint
Old Mon 15 March 2010, 09:48
lumberjack_jeff
Montesano, WA
Nice Gerald! I like the dowel pins.
Old Mon 15 March 2010, 10:05
Jeff, what you might like even more, is that we supplied a big board with registration holes (you can see it in that link) and the dowels went right through into that board. The individual pieces had a few more dowel holes that lined them up to the big board.
Old Mon 15 March 2010, 12:57
Jeff,
Then it seems that the picture in post #2 is a good way to go but with some changes as far as size and frequency.
Old Mon 15 March 2010, 13:03
lumberjack_jeff
Montesano, WA
Nils,
The more I look at that joint, the more I like it... it looks like the short pin does lock in place.
Old Mon 15 March 2010, 13:08
Jeff,
It also give the advantage of not having a straight line all in the same place so I would guess it is distributing the load which means there would be less likely that there would be a failure.
Welsh Dragon .dxf file keithstanley Dxf Library 16 Tue 19 November 2013 16:09
Converting file formats smreish Dxf Library 16 Tue 01 June 2010 07:14
Scale a DXF file (modelling dinosaur kits) MariusL Utility software 24 Wed 02 December 2009 06:28
1010123 Support Board - material selection (MDF, plywood, other . .) IN-WondeR 10. Base Table 2 Sun 27 May 2007 13:53
Where can i get full cad drawn like the pdf file eloid Archives 12 Mon 14 May 2007 11:37
