Old Mon 08 March 2010, 23:47
Ries & Irfan, it could simply have been a case of a dirty connector pin on a particular cable and that could be why replacing the cable fixed it. I tend to agree that measuring "resistance" is going to be a tricky subject if we are just going to hold probes against pins.
Old Tue 09 March 2010, 01:13
Hi Guys
I agree that measurement error coupled with instrument error and a typical lack of calibration means we are likely to see some vastly different readings. The discussion did make me think more fully about the subject though and I now have some gotchas to watch out for.
Old Tue 09 March 2010, 09:51
All, when I was perplexed why my machine was missing steps,, I found out that a friend of mine had the same problem on his plasma machine, and in both case - it was the ready made parallel port cable problem.
may be we should put this matter to rest now here.
Old Tue 09 March 2010, 10:03
@Mike, may be you can move the couple of posts over to a suitable place?
I feel we hijacked Ross this thread now, that wasn't our intention..
Old Wed 10 March 2010, 19:58
Follow Up on USB Repeater Cables
Post 97 and 98 discussed USB repeater cables. I have now done a few tests and can confirm that they pass a signal very well over long runs of USB cable/s.
Anyone who is passing data over longish runs on USB be it control to a smoothstepper or images back from a webcam might consider this as a very cheap insurance policy to protect the quality of the signal.
Acknowledgement to Besser for his suggestion.
Old Thu 11 March 2010, 03:08
USB over Ethernet Follow Up
A further note - I have found that USB over Cat5/6 adapters are now selling out of China for around 12 AUD. These will give a 150m max cable run over Ethernet cable and do not require external power. These adapters are now on a price par with a 5m USB extender cable but allow the freely available, cheap and pre-wired Ethernet cables to be used.
Looks like ethernet cable might find it's way into the Mechmate cable chains after all.
Old Thu 11 March 2010, 10:13
jehayes
Just call me: Joe #53
Whidbey Island, Washington
Ross: Wish I had found these earlier! Thanks for doing the research. I may just go back and rewire!
Joe
Old Sun 14 March 2010, 20:29
Besser
Just call me: Besser
Vic
Bulk Order or Local Supply
Thanks for the updated into, where do we get the adapter or are we looking at a bulk order?
Old Mon 15 March 2010, 04:43
Hi Besser
An Ebay search "USB Cat5" will lead to a few different international sellers.
Old Wed 31 March 2010, 06:03
AuS MaDDoG
Just call me: Tony #71
Brisbane
How about an update Ross???
Tony.
Old Wed 31 March 2010, 06:13
Hi Tony and Others
That would require some work being done !!
I have progressively knocked over other commitments both social and work since my recent return from holidays and hope to have another go at the machine after Easter.
As I wander past the components they are just calling out to be assembled.
Old Fri 09 April 2010, 06:37
Painting - Lower Table
Hi All
I have been procrastinating about paint and when to paint.
Decided to paint the lower table first but snagged on finding what I considered to be a good colour in the hammer tone finish paints.
As usual tried mixing some paint of my own using a metalic blue and a black epoxy paint.
It did not work well as the silicone in the hammer finish seems to prevent proper mixing of the black epoxy.
After much searching I found a refinish supplier paint shop who made up a paint I liked from a silver hammer finish base and a blue - red tinter.
Tuned out a nice colour and was very easy to spray with a HVLP gun at 50 PSI thinned with 10-20 percent automotive thinners.
Attached is a pic of the table legs in their new paint. Everything had a full coast of grey primer before the top coat of hammer finish.
The X beams and the Y Cross Bearers are still outside waiting for a second coat but are the same shiny colour.
Finally tidied up my welding on the ladder frames for the table base by grinding, priming, filling with acrylic filler and then priming them again.
They are now presentable enough to get their own coat of paint.
Old Fri 09 April 2010, 06:51
AuS MaDDoG
Brisbane
Hey!!
I wondered how long it was going to be before we had an update Looking very good Ross, and the hammertone colour sounds very interesting.
Old Fri 09 April 2010, 07:01
Tony - Finally !
For reference I used two liters of paint to do one topcoat on the legs, the X beams and the Y cross bearers.
That leaves the ladder frames to do in two coats and another coat for the other components.
Looks like 5-6 liters of topcoat will do the whole job incl. the gantry and Y car and a few touch ups - way more than I originally guessed.
Old Fri 09 April 2010, 07:38
Ross, That is nice paint job. Also a lot of paint, I only bought 2 liters of top coat & still have enough balance for a 3rd coat... no solvent too...
Old Fri 09 April 2010, 08:00
Hi Ken
Yes it is a lot of paint but the hammer finish effect changes with the volume of paint wet out.
When spray applied, you spray for your desired level of hammer toning and that is how much paint you use.
It is a pretty thick coat and needs to harden up before it is worked with.
I leave it to "cook" in the sun for a day or so but it is still soft eniough to mark for a while so a touchup will be required here and there.
I have followed your build as you know, and as we both have selected this finish it just has to be the the best one, haha.
Old Fri 09 April 2010, 21:43
I mentioned the volume so that other builder won't have to stock up excessive paint
Careful with cooking the paint, contrary to common believes, paint don't really like heated up under the sun too much. Here, metal can heat up to easily 85C & as high as 100C, which is demaging to the paint. Years ago when I was a lot younger, I left one of my paint job under the sun for a day & I got bubblle effect on it, then I found out the paint actually boiled...
For my build, I gave at least 16 hours to cure before the next coat. Over 3 day after the final coat before I did any work on it. but I recon you need more then that.
Old Fri 09 April 2010, 22:16
Hi Ken
I found a hole in the tin maybe that's where the paint went !!
Only kidding again there Ken - used 4 liters so far and I'm pretty sure it all went on to the steel excepting for a little over spray.
As I am thinning with automotive thinners it dries a fair bit quicker than the same product thinned with turps.
Part of the explanation for the paint use is I have to spray it thickly to get it to wet out and hence form the hammer finish.
The benefit here is it dries more quickly and it is easier to get a run free finish than thinning with turps.
If you thin with turps you will get a better gloss but a slower drying time.
I got a bargain on the paint and for 2 liters paid less than 3/4 of the normal shelf price for 1 liter, so using a bit more paint has not added any significant extra expense.
Thanks for the tip on the sun, I will move it into the garage once it is cured enough to not mark the paint.
My progress so far ... lots of blue as per the Mechmate manifesto.
Old Sat 10 April 2010, 23:03
Looking good Ross!
Old Sun 11 April 2010, 02:14
Thanks Heath
Now to leave it for a few days to cure before assembling it.
Old Sun 11 April 2010, 03:01
AuS MaDDoG
Brisbane
Hi Ross,
Looks impressive!! all that painted steel. What did you use to prep all your steel and what was the process? going to be looking to prime ours up sometime fairly soon, we have a fair amount of prep to do with regards to surface rust mainly on the main X beams and Y support channels, so interested to hear what your process was.
We might need to have another little get togetherat some stage once you have yours all together again, would be nice too see it nearing completion. Plus I have your countersink bit too return too.
Tony
Old Sun 11 April 2010, 03:26
Hi Tony
Just finished stacking the stuff inside my garage.
The steel was degreased and vigorously wet scrubbed with a plastic scouring pad. Destroyed quite a few in the process.
Any thing else that needed attention was just given a (very) rough sand, blown off with some air and then cleaned down with thinners.
After that, it is was spray undercoated with a grey rust guard primer (White Knight) then topcoated with the hammer finish.
I tried tapping some M6 holes on the motor plates and all was going well by hand.
Got greedy and then broke a bottom tap off just running one hole through with the battery drill !!
A crash, bash and hammer later had the broken bit out and managed to still put a new thread down the hole. Today was my lucky day it seems.
Cheers on the countersink Tony, it's nearly time to catch up again.
Old Mon 12 April 2010, 06:33
While the Paint Hardens
Finished tapping the M6 threads in the motor plates this evening.
After finishing the motor plate taps I was thinking about how to keep the tap at 90 degrees and the number of taps in the X beams and gantry.
Made two M6 and M8 guides out of 20x20mm stock to keep me straight to start off with.
The pic is a little hard to see but it is a hole in the stock that "just" fits the tap.
Also made up the 20x6mm clamp strips for the gantry.
A question for the knowledgeable, one gantry tube is 2mm longer than the other one.
Can I get away with this variation or should I attempt to cut the extra 2mm off the long tube?
Thanks in advance
Old Mon 12 April 2010, 06:48
I have continued to test a webcam over the USB baluns mentioned in post 126 over a range of cable runs and they reliably run it over 10 - 15m.
The baluns will make the connection to the webcam initially at 20 and 30 meters but will not maintain it.
Not great, but better than the 5m standard cable run for a USB cable on its own.
Old Mon 12 April 2010, 06:55
AuS MaDDoG
Brisbane
Hi Ross,
I would think that the Gantry beams would have to be exactly the same size otherwise your gantry will end up out of square before you even start.
Tony.
Old Tue 13 April 2010, 05:00
Ross,
Your question on gantry tube length is a ligit concern, but not a reasonable one.
They are part of an assembly that you must assemble (weld) square.
One simple method is to cut both of those tube together at the same time, held be some sort of clamping, assuring an exactly same length without measuring anything.
BUT YES, they MUST be the same length. Read some more about how to weld & assemble the gantry here and here.
Best of luck. Amicalement, Robert
Old Tue 13 April 2010, 06:47
Hi Robert
I should know to never even think about cutting a corner, so I hear both you and Tony loud and clear on this one.
Thanks for the advice.
Old Tue 13 April 2010, 07:04
Assembly Time for the Bolt Together Base
A milestone for my project today as I assembled the table base this evening.
Time to also acknowledge the many others on the forum who have contributed their photos and ideas for me to use in my own build. Thank you.
Here are the photos of my table base going together.
Old Tue 13 April 2010, 08:08
Very nice!
Old Tue 13 April 2010, 15:09
Travish
Just call me: Travis #75
Wa
Looks good Ross! The color has some sparkle to it?
What size table are you building? 4'x4'?
