Old Sun 10 January 2010, 17:10
Regnar
Just call me: Russell #69
Mobile, Alabama
How much Torque is required when cutting?
I hope I am asking this in the right section but here we go.
I am looking at the Keling KL34H280-45-8A Stepper Motor,
http://www.kelinginc.net/KL34H280-45-8A.pdf
http://www.kelinginc.net/KL34H280-45-8AT.pdf
I am still in the planning stages but I would like to do a 3.1 to 1 belt drive with a 20 tooth pinion.
If I have done my math right I should end up with a almost 1:1 with the steppers rpm and 3 times the torque at rated speed.
Now for a few numbers, I would have
Stepper RPM-------Stepper Torque-- Pinion Torque--Table Speed(est)
150rpm------------594oz------------1841oz--------150ipm
300rpm------------580oz------------1798oz--------300ipm
600rpm------------509oz------------1577oz--------600ipm
900rpm------------410oz------------1271oz--------900ipm
1200rpm-----------311oz------------964oz---------1200ipm
1500rpm-----------254oz------------787oz---------1500ipm
1800rpm-----------198oz------------613oz---------1800ipm
This was all caculated from the torque/speed chart.
My question is will the torque and speed meet the Mechmates need with the above setup? I have never cut at a significant speed and dont have a clue what is required for cutting.
Would anyone object to this stepper motor and setup. In my mind it sounds good but then again what do I know.
Old Sun 10 January 2010, 19:59
Consider that a 20 tooth pinion which has a 20 diametral pitch has exactly a half inch radius. Therefore, a 613oz.in torque on a 20 tooth pinion is going to give you 1226 ounces of linear "pushing" force at the cutter, which is 76 pounds, which is plenty for a typical bit in a hand pushed router.
Old Sun 10 January 2010, 22:32
Castone
Just call me: Leo #41
Soddy Daisy , Tn
I have the 640 oz Keling steppers, with beltdrives. no problems so far and I am very happy with them.
Old Mon 11 January 2010, 14:04
Regnar
Mobile, Alabama
Leo, are you running them 3 to 1 or are you doing a different setup. Thanks guys for the responses. I feel very comfortable with the mechanics but unsure of the electronics that need to be put in. Thanks again. Russell
Old Mon 11 January 2010, 18:03
Castone
Soddy Daisy , Tn
Yes, I am using the 3 to 1
Old Tue 09 March 2010, 07:43
kostis
Just call me: kostas
Falkland Islands (Malvinas)
Why beltdrives?
So, why do you use beltdrives in your machines?
I now build my 1mx2m cnc and I have 640oz-inch steppers with G203 and ballscrew 2510 and I plan to put them directly to ballscrews....If I put belt drive I will have decreased speed right?I do not want to decrease the speed...
Will I have any problem with this?
Kostis.
Old Tue 09 March 2010, 07:49
Kostas, this forum generally only handles the specific MechMate machine design.
The answer to your question is that the MechMate uses rack and pinion, and thus gearing/belting down the motor makes sense. With a ballscrew, it wouldn't, since the ballscrew naturally does that. Whether you will have problems is a question for another forum, I think. Good luck with your build.
Old Tue 09 March 2010, 08:00
kostis
Ok sorry then,
thanks for clearing this out Bradm...
Good luck to you too...
Old Tue 09 March 2010, 11:21
oopz
Just call me: oopz
Stockholm
Sweden
bradm: So therefore a kind of --Back to basics -- I´v like to know how G540(+motors) and Linux has worked on your MM over time.
( Im a Mach3 and G203 person.) The reason why is simple I decided to go "THAT path - G540 and Linux" on one of the slanted machines I´m building.
I know that its a learning curve on everything new thing you have to learn, so
" Lets Start NOW!! "
If you wounder in what build it will apear etc..Its this machine you can see grow in this moment taking its shape in my building three below.
http://mechmate.com/forums/showthrea...7&postcount=25
Feel free to answer either in the three above or here !
So if you have same advice or what to avoid etc or likewise let me know.
/oopz
Old Wed 23 June 2010, 23:10
eesanopi
Just call me: Edgar
Morelos
Mexico
Leo, I have this motors too, but not running yet, how fast they can perform with 3:1 reduction?
Edgar
Drawing problems and revisions required, considered and intended . . . . . Gerald D General - MM Build 55 Sat 23 March 2013 05:48
Flexible Hose required in India DMS 55. Dust Management 9 Wed 16 September 2009 06:22
Same torque, different sized frame chrisd7306 Motors & their mountings 5 Wed 19 November 2008 02:25
Required Torque for possible upgrade ?? boutzo869 Archives 4 Wed 22 October 2008 08:04
How many laser profile cut components required per part number? fabrica Profiled (laser cut) & bent steel plate 29 Mon 07 January 2008 12:32
