Old Tue 23 February 2010, 02:43
martin77pl
Just call me: Martin #39
Wroclaw
Poland
Hi Kostas and welcome. Good luck with your build. Them parts that are laser cut and bent you can order from any company with laser cutting machines. I am sure you can finde some in Warsaw. I used a company called Blehinger as far as I can remember and they are based in Wroclaw. I emailed them dxf files from download page and they agreed to do that. Oriental motors I got from Poznan company name is Masterpol and the bearings are from SuperiorBearings. com. Hope that helps.
Old Tue 23 February 2010, 02:52
kostas5
Just call me: KOSTAS5
WARSAW
Poland
hi martin
i am very hapy thats you can help me to found my parts ..and i hope thats we can be in contact .i like to ask you if they make you the laser parts withe bending or not and if not how you did your bending .
thanks..have a nice day
Old Wed 24 February 2010, 03:34
martin77pl
Wroclaw
Poland
Kostass they do bending and laser cutting.
Old Tue 02 March 2010, 07:30
kuka
Just call me: kuka
Reading,PA
It's my first post on the forum,despite long undercover activity(reading only).First off my
regards to all active members,whose knowledge helped me to make decision on build of
my router.At the moment I have all parts laser cut and bent.Now,as I am temporarily,
back home I would like to get in touch with martin77 or Kostas5 for further consultations.
Old Wed 03 March 2010, 02:09
martin77pl
Wroclaw
Poland
Hello mate and welcome on board.
Old Thu 04 March 2010, 02:58
kuka
Just call me: kuka
Reading,PA
Hi Martin77,
for years nobody addressed me as "mate",so reading your post I realized how
much I miss from Down Under.
My email:[email protected]
Old Sun 02 May 2010, 04:47
martin77pl
Wroclaw
Poland
Good to be back. Although I visit the website every day I havent posted for a while now. I have installed my MechMate with dust extraction system and laser crosshair for zeroing X and Y. I use game pad for jogging the machine. I switch on ond off the spindle and laser using the pad. I will post some more photos of the set-up soon. I cut it yesterday the piece is 225 mm wide by 320 mm high.
Old Tue 04 May 2010, 14:41
Travish
Just call me: Travis #75
Wa
Good looking work there Martin!
Are you willing to share the settings used and what was done to get the router to switch on ond off for the spindle and laser using the pad?
Travis
Old Wed 05 May 2010, 14:06
martin77pl
Wroclaw
Poland
I am using chinese water cooled spindle. The VFD that drives the spindle is connected to the PMDX on board relay contacts. The ports and pins tab for spindle setup contains relay control and you should unchek the box 'disable spindle relays'. You should set both CW and CCW outputs with 1. I had to modify standard Mach3 screen a bit for the laser to be switchable using my pad. Screen 4 and KeyGrabber is all you need to achieve that. I am using a cheap game pad but that is working fine. As far as the laser is concerned I am using 'Flood/Mist Relays' to switch the laser on and off and I can use the screen or the pad to do that. Although the laser I am using needs 3 vdc I connected it directly to the PMDX and is working ok.
Old Tue 18 May 2010, 14:46
martin77pl
Wroclaw
Poland
Here are some photos of what my laser and dust feet look like and a modified screen as well.
Timerwolf Beer Tap Handles J.R. Hatcher The Show Room 13 Thu 28 May 2009 20:33
www.akcesoria.cnc.info.pl - Ogólne dostawca w Polsce (Supplier in Poland) martin77pl The Market Place 4 Sun 22 February 2009 14:15
New concept for gear reduction and zero friction movement with zero slippage of axis? Art Archives 1 Fri 05 September 2008 08:40
Mamba logo ideas smreish Archives 18 Mon 03 December 2007 23:00
Jerky movement of the gantries - Limit Overides activated in Mach fabrica Troubleshooting 31 Tue 23 January 2007 10:39
