Old Sun 31 January 2010, 00:35
aniljangra
Just call me: Anil #44
Delhi
Right, That was one of my thoughts and as I pulled up the freq/step calculator, can see that my full step resolution is .094mm, very near to the resolution (0.1mm) we are working.
Though the micro-step resolution is 10 times more, still there will be rounding off errors. And I think even if there was no rounding off error, the micro-step position is not held up as accurately as fill step position.
Old Sun 31 January 2010, 01:26
I have this nagging belief that the micro-step position is not held at all, but the smart people tell me that it is. If I am really bored one day, I could test it.
Old Sun 31 January 2010, 10:50
aniljangra
Delhi
No more boring small PCBs this time
This is one of the two-parts divider ...
This is how I plan to use it, the upper part is yet to be done..
Measure 2.5' x 5' approx, used 3mm end mill cutting 2mm per pass at 80ipm. Total four passes in 8mm thick mdf and total time to cut about 3 hours.
Old Sun 31 January 2010, 10:54
please do a duco finish on that one - also probably enforce it with sheet of cast acrylic on bothside or on one side and yes email me the file
Old Sun 31 January 2010, 11:12
Talking of cast acrylic, how about casting acrylic (various colours) into the cutouts?
Nic job Anil!
Old Sun 31 January 2010, 11:32
I like I like well done
aniljangra
Delhi
Thanks Gerald for the cutout idea, wish I had that earlier
I did not keep the original vectors and just have the outlines now. I think the cutouts won't fit exactly if I work reverse from outlines now.
Something to remember in future, to keep copies of file from each step as you design.
Old Sun 31 January 2010, 11:33
normand blais
Just call me: Normand
montreal
Hi
mil might come from french( millième ) thousand ,we say the same like 4 mill but with the french accent. Nice divider acrylic would be great !
Old Sun 31 January 2010, 12:11
Anil, I am thinking of pouring a liquid into the openings. Something like this: http://www.creative-resins.co.uk/lamresin.htm
Old Sun 31 January 2010, 13:07
Claudiu
Just call me: Claus #43
Arad
Romania
Very nice divider, how long did you cut on this one. CV or exact stop?
Old Sun 31 January 2010, 21:13
Must get my MM running.... must get my MM running... must get my MM running...
Old Mon 01 February 2010, 08:06
aniljangra
Delhi
Nice song Ken
Yes thats a possibility, need to find out the availability and price.
Claus, total a little less than 3 hours with CV on.
Old Mon 01 February 2010, 21:32
aniljangra
Delhi
Other part of the divider done, need some finishing on other side.
Used (snapped) 4mm endmill, total time 4 hours.
Old Tue 02 February 2010, 06:31
good snapping
Old Tue 02 February 2010, 08:15
Anil,
Great work. Very impressive.
What's "snapping"? I'm sorry if I should already know this.
I was wondering if you are monitoring the temperature of the Drives and Motors. Since you have "Open", DIY built drives, their performance "under load" is of interest to some of us that are considering using them as well.
Old Tue 02 February 2010, 08:36
aniljangra
Delhi
Last 2 jobs were about 2 and 4 hours respectively. I noted that the drives were getting hot (but nothing that can't hold finger over it).
The temperature was samilar for 2 hours or 4 hour job, so I think that's max it can go irrespective of the time after a initial period.
I mounted the fan blowing air over them and how they run cool
Old Tue 02 February 2010, 09:18
John, look at the text just below the pic. . . . I think snapped means "broke"
Old Tue 02 February 2010, 10:50
did you not choke to the dust of that mdf, i heard that ur machine is now locked forever in the room you built it in
Old Tue 02 February 2010, 11:01
aniljangra
Delhi
I want to do something for dust but don't have space for anything more, at least for now I'll continue as it is with masks
I can remove a wall if I want it out , I was advised to do a bolted design but as I said earlier I like welded stuff somehow.
You guessed it right Gerald , sorry John if that's not correct English
Old Tue 02 February 2010, 11:11
hey get the eureka forbes vacuum cleaner thats like 8k I think and get a 12 inch industrial exhaust fan - almonard brand is 2k
remove a wall- what do you have hinges on em
RGDS
Irfan
Old Tue 02 February 2010, 11:27
Nice work on the PCB Anil! A lot of guys that are doing pcb work seem to have jigs that they can surface right before they cut the pcb to make sure everything is flat as of that day. They also will raise up the work so that the Z has as little extension and less flex as possible.
Old Tue 02 February 2010, 16:21
Jason Marsha
Just call me: Jason
B'Town
Barbados
Anil,
Excellent work.
I thought I was the only person that used the corridor as storage for my MDF and plywood sheets , it sends the others in the house crazy.
You may want to experiment with a slower speed like 40 inches/min but with a single 8mm plunge, that will reduce your cut times significantly and save your bits.
With a 2mm plunge you will cut one path four times and with MDF being very abrasive on tools it may lead to premature failure.
What brand bit are you using?
Is it a spiral upcut?
If possible post a closeup pic of your bit.
I have used Whiteside spiral upcut 3.175 mm and 6.35 mm diameter bits and they have worked well.
Jason
Old Wed 03 February 2010, 19:26
Rad Racer
Just call me: Wayne #25
Minnesota
Anil - Claus,
I really like the dividers you guys are making.....very detailed design. What software did you use for the design work?
Old Thu 04 February 2010, 01:23
aniljangra
Delhi
Heath, thanks for the tips. Anyhow I did the PCB job on MM because my other small machine is in not in functional state. I need to make some space for that and make it functional again to do pcbs )(thats was the reason it was made )
Originally Posted by Jason Marsha View Post
Anil,
Excellent work.
You may want to experiment with a slower speed like 40 inches/min but with a single 8mm plunge, that will reduce your cut times significantly and save your bits.With a 2mm plunge you will cut one path four times and with MDF being very abrasive on tools it may lead to premature failure.
What brand bit are you using? Is it a spiral upcut? If possible post a closeup pic of your bit.
Jason
Jason, I only had worked in metal before and I am just starting with wood/mdf stuff.
The bits I have are 4 flute carbide meant for metal work, I'll try if I can get (as you said) "spiral upcut" bits. Also will try your suggested strategy of low speed with more pluge next time . Still learning..
Originally Posted by Rad Racer View Post
Anil - Claus,
Wayne, I use Corel, that's the only one vector program I have a my work. In fact any vector program can be used, you just want node editing and weld/combine features.
Old Thu 04 February 2010, 02:16
Anil, those 4-flute metal cutting bits are not designed for drilling in the z-direction (the center of the bit has no cutting edges)
However, the 2-flute metal cutting bits can usually drill. And they have bigger space between the "blades" for clearing the sawdust out.
By far the most common cutter we use for MDF is the 2-flute solid carbide bit from the shop that sells to the metal cutters.
Old Thu 04 February 2010, 06:32
normand blais
montreal
4 flute cutter need to move faster or rotate slower so it dont end up rechopping chips into dust and creating heat and wear. Also a 1/4 inch step down only wear the first quarter inch of the cutter even going 2 '' down
Old Thu 04 February 2010, 07:42
Pardon my ignorant, what is the advantage of the wear pattern?
Old Thu 04 February 2010, 07:55
If you make two passes at a 1/4" deep....compared to one pass at 1/2" deep
The deep, low number of passes gives you double the bit life because you are only make half the number of passes. But the bit is worn for the last 1/2" inch.
Old Thu 04 February 2010, 08:27
normand blais
montreal
1/4 inch dull and 1 3/4 sharp on 2 inch flute cutter
Old Thu 04 February 2010, 10:32
aniljangra
Delhi
wow, good info here to learn from.
I'll probably get my spindle in few days and can then experiment with more plunge, right now my die grinder seems overworked with high plunge or high feed.
Checking continuity of wiring with Antec Power Supply Connected oliver2257 702. Power Supplies 0 Wed 30 November 2011 16:52
New Guy from India ksgpathi Introduce yourself and start planning 1 Wed 26 January 2011 15:56
Checking Parts List confirmation of pinion & gearbox DocTanner Motors & their mountings 21 Fri 09 February 2007 12:53
