Old Fri 22 January 2010, 03:25
I second Ries's suggestion.
Was planning to build a fullrange ELS until I bump into this forum...
Old Thu 28 January 2010, 12:59
Claudiu
Just call me: Claus #43
Arad
Romania
Hi guys,
did some new stuff I wanted to share with you.
I used for the first time MM for aluminium cutting. Needed some special parts for a etiquette applying machine in wine industry. I had only some scrap alu lying around so I cant tell what grade it was. I used a 6 mm solid carb end mill with 20 mm/sec and 0,8 mm pass and 20% stepover.Toolpath was some pocketint and profiling in Aspire.Lubricant used WD40.
Second project was a roomdivider made of 10mm mdf.
First profile cutting done with 4mm endmill.
I used a 12 mm V Bit with a profiling toolpath, cutting depth on line 3,5mm.
This the cut quality obtained going exact Stop modus in Mach3. True it`s lot slower but worth.
and some more of it....some 10 hours later...
and then of course the other side, too...
And finally after some 30 machine hours, I used some Linseed oil for finishing the divider. Dimensions 190 x 90 cm.
After such a job I realise even much more what a wonderful piece of Art the MechMate is...Thank you Gerald for making this possible.
Old Thu 28 January 2010, 13:27
Very very nice Claus. Just glad you did not have a power cut in the middle of it.
Old Thu 28 January 2010, 14:24
Johannescnc
Just call me: John
Hannover, DE
Germany
power loss is a big problem in Florida. I had quite an investment in ups equipment. have not had this experiance here... yet Hope I didn't burn the cornbread.
Claus, those look awesome! my wife likes them too!
Old Thu 28 January 2010, 15:12
Travish
Just call me: Travis #75
Wa
Claus, Nice work! Now my wife wants on now....lol
My wife and kids are allready making me a list of things to make!
Good looking work!
Cheers,
Travis
Old Thu 28 January 2010, 18:19
swatkins
Just call me: Steve
Houston
Very, very nice work!
Old Thu 28 January 2010, 19:36
Rad Racer
Just call me: Wayne #25
Minnesota
Looking good Claus, it appears you have your machine dialed in perfectly.
Old Thu 28 January 2010, 21:00
AWESOME!
got to complete mine ASAP....
Old Thu 28 January 2010, 21:34
Claus, in #169 you were having a little static charge issue on the outside of your dust collector boot on your MM. I was wondering if painting that section with aluminum paint (or other conductive paint) and grounding the paint appropriately could help dissipate the static issue.
Old Thu 28 January 2010, 21:53
Well Done. It looks awesome.
Old Fri 29 January 2010, 01:02
did you place tabs in between - and after removing the inner material _ ai am assuming you have run a cleaning pass, thats how I do it, unless you have a order for a 100 numbers and you can build a jig to hold the job and let the pieces drop down
Old Fri 29 January 2010, 09:21
Claudiu
Arad
Romania
Thank you all,
Kobus, having daily problems with electricity I learned from you that making a small hole outside your workpiece, where your zero is, can save your work, and you allways can restart from there...!
Yes Irfan I had tabs, but those were cut away with V bit, imagine sanding about 300 tabs by hand... Hope that 100 piece order drops in some day, then I will come back to you to explain exactly how to build a jig.
Have all a nice weekend.
Old Sat 30 January 2010, 04:46
Jason Marsha
Just call me: Jason
B'Town
Barbados
Very impressive. The V bit to cut away the tabs was an excellent idea.
What was your feed rate?
Did you go slowly as it was your first attempt?
Jason
Old Sat 30 January 2010, 04:54
aniljangra
Just call me: Anil #44
Delhi
Very nice Claus... Can't imagine MM working 30 hours continuously yet.
Can you explain a bit how you generate the divider pattern/software (of course if its not a trade secret). I too wanted to make one for me
I do make a small cross somewhere outside work using a sharp engraving V bit before starting any work as you can never be sure what happens next !!
Old Sat 30 January 2010, 13:45
gixi
Bucharest
Romania
Esti foarte tare !!! Trebuie sa-ti dau tel unora din Buc care vand un grund special pt MDF. Altfel o sa te chinui f mult daca nu dai inainte cu grund. Cauta oricum pe net firma Goulda SRL. Sigur au site. Eu de la ei iau tot ce imi trebuie pt finisaj. Au marfa de super calitate calitate. Nu o gasesti in hipermarketuri. E industriala si e Italia. Cred ca am zis tot. Si ce e mai important e ca te ajuta cu sfaturi, sunt f amabili.
Bafta,
Marius
Old Sun 31 January 2010, 02:42
Claudiu
Arad
Romania
Jason, my feedrate was set to 3600 mm/min, but as I said before Mach was set to exact stop and therefore it went very slow, mostly not going over 400mm/min. Only when it had to cut a straight line speed went up to about 1500 mm/min.
Anil, the whole job took about 30 hours, divided in 13 hours of cutting out the small pieces and then another 7 hours for V encgraving each side of the panel. The machine stops were about 30min for changing tool, cleaning table, loading up GCode and pressing start button.
The easyest way to generate a pattern is to use Inkscape, and import some flower and deco patterns which you can arrange to form the first quarter of your finished pattern.It is also very helpful to use helplines in your sketch for aligning all patterns to have a nice geometry.When done simply mirror it sideways and downwards and you have your big pattern. Then you can multiply as often as needed. It is very important to use vector graphics as they are scaleable to any size. Hope that helped.
Old Sun 31 January 2010, 19:07
Jason Marsha
Just call me: Jason
B'Town
Barbados
Stumbled across this link a while back on the mechmate forum, cannot remember which thread but it was saved in my browser favorites.
Scroll down the page to find the patterns.
http://www.craftsmanspace.com/free-patterns/
Old Mon 01 February 2010, 01:19
Claudiu
Arad
Romania
Jason, thank you for that link.
Indeed there are tons of patterns. I found the one I used in a vector pack on file sharing server together with many other vectors.
The trademark logo from craftsmanspace was also removed. intresting...
Old Mon 01 February 2010, 01:34
It was 'Clean' Vectors - free project plans for the woodworker
Old Thu 04 February 2010, 09:23
Claudiu
Arad
Romania
Rectifying Brass.
This is a part of a wine bottle labeling machine. The part I had to rectify is a leveling device for the glue applicator. Having an age of about 30 years it had lots of dents and hits on the surface which normally has to be smooth.
Thatīs the result. Thats the upper part which had to be chamfered 45°. I used a V Bit. Then with an endmill the cutting edge was straightened.
Then turned it around. Thats the underside which was worked with a 8 mm endmill.
This is my first job where all was done by manual control of the MM.
Old Sun 14 February 2010, 23:55
quadtech
Just call me: Prasad
Hyderabad
Claus, do post a pic of the completed speakers.
Here are some nice BLH CNCed speakers from Andrew Tisley -
http://www.creationaudio.com.au/Products.html
Old Mon 15 February 2010, 01:20
Claudiu
Arad
Romania
They have some nice designs. I especially like the compination of layered birch with acrylic panels. I also had a nice link from one japanese diy-er and will post it when i find it.
The MDF speaker was just a prototype to see if everything fits, the product will be cut from layered Birchwood panels around 20 mm. I will use Fostex chassis from the sigma series. I`ll come back with pictures.
Old Wed 24 February 2010, 10:53
Claudiu
Arad
Romania
Hi guys,
I was pretty involved in some little projects lately. Soon my webpage will be ready for presentation, and of course I`m working on the content.
Here is what I`ve done lately from 25mm layered birchwood panel:
I will post some more work soon, as ti will be finished...
Old Wed 24 February 2010, 12:20
Johannescnc
Just call me: John
Hannover, DE
Germany
Thumbs up
I like it!
Old Wed 24 February 2010, 13:32
aniljangra
Delhi
Very nice Claus , how the glass is held on, is it glued somehow ?
Old Thu 25 February 2010, 00:07
Claudiu
Arad
Romania
Anil, the glass is just heavy. Size is 2.2 x 1.3 m and thickness 13mm. Gravitation is doing the fixing. But of course it possible to ad some rubber or felt pads...
Greetings from Romania Claudiu Introduce yourself and start planning 3 Fri 26 June 2009 22:43
Letters and other projects hennie The Show Room 25 Thu 25 June 2009 03:12
Couple of CNC projects. Rad Racer The Show Room 2 Thu 26 February 2009 22:56
AutoScaled Projects - choosing cutters, mat. thickness, etc. servant74 Miscellaneous / General / Whatever / Catchall 14 Wed 28 January 2009 08:14
Cool front panel joint WTI Miscellaneous / General / Whatever / Catchall 0 Sat 07 June 2008 16:53
