Old Wed 13 January 2010, 04:07
Irfan,
You have mail.
Old Fri 22 January 2010, 14:23
some more jali shapes
here is what we did with the jali shapes - its a pulpit for a mosque . yet to receive polishing - will have a matt finish.
Old Fri 22 January 2010, 23:32
Beautiful!
Old Fri 22 January 2010, 23:37
Magic, but I still want to know how to make that WHITE stuff. If it is a trade secret so be it....but PM me then
Old Sat 23 January 2010, 02:14
its called white metal paste here and gets mixed with a hardner (gp resin+chalk powder)d
Old Sat 23 January 2010, 02:16
Irfan, what is the purpose of the paste? Would you show us the finished?
Old Sat 23 January 2010, 02:17
the paste is the white color you look as a inlay in the v carving on the jali
Old Sat 23 January 2010, 02:34
Interesting, does it contain metal? or it is how they are commonly known as?
Old Sat 23 January 2010, 07:36
digger
Just call me: Milosh #113
Toronto
Some interesting reading regarding inlays:
http://www.woodsmith.com/issues/173/...n-epoxy-inlay/
Old Sat 23 January 2010, 21:02
Thanks Milosh. Its really interesting read. I can see modern tech slowly creeps into wood working procedure.
Old Sun 24 January 2010, 21:17
student1616
Just call me: student
drop from sea
good work.
whats the tool u used for this work.imean carbide or MS and its size and type(engraving tip or endmill).
and the site u posted before craftsmanspace.com providing Autocad drawing.how did u convert that in to Gcode.
Old Mon 25 January 2010, 04:09
GCode is convert with the use of a CAM software program.
Old Mon 25 January 2010, 10:37
student1616
drop from sea
program like....?
i know mastercam.but its bit difficult to operate.is there any tool which is for hobby ppl level with good features
Old Fri 05 February 2010, 10:28
some more of jali work
some more of the jali work, this time on 30 mm thick mdf, sure the cutting bit makes a racket now!
G' how deep can you drive a 6mm 2 flute endmill in mdf and at what feed rate? i am currently going with 6mm deep per pass at around 2500mm/min
Old Fri 05 February 2010, 10:29
4th axis
and here is what I have to build my 4th axis attachment
Old Fri 05 February 2010, 11:59
Irfan, I think my son would do 4 passes to get through 30mm MDF with a 6mm bit. The speed for that job sounds about right.
On doing 4 passes, the trick is to do the 4th (last) pass with a slightly smaller offset, so that it cleans the marks left by the previous passes. Some guys do the first passes climb cut direction and the last pass conventional to get the same clean-up effect.
Old Fri 05 February 2010, 13:31
Claudiu
Just call me: Claus #43
Arad
Romania
Irfan, what is your cv setting in mach? why don`t you get rounded corners at that beautyful jali work? Please tell me your secret...thanks for the mail.
Old Fri 05 February 2010, 21:59
student1616
drop from sea
still waiting for your reply reading the type of G-code generation program you guys use.
iam quite impressed with the work done on the MDF.
Old Fri 05 February 2010, 22:35
Looks like that 4th axis is on it's way.
Old Fri 05 February 2010, 23:46
How would you handle the potential backlash?
Old Sat 06 February 2010, 02:10
To me backlash is like a gost. I hear about it, but do not experiece it. Why worry about something if it is a potential hazard ? With the2 gears pulled against each other with a spring, will there be a backlash problem ?
Old Sat 06 February 2010, 02:37
IMHO, Backlash is not a ghost, it is an inevitable occurrence which will comes with wear & tear of mating surfaces. AFAIK, Even with correct design compensation, they will catch up eventually. I'm just hopping it the occurrence will not be too frequent
I do hope the spring loaded gear meshing like what MM is having will work on rotary spur gears as well, I do see good reason why it should work. There will be a huge advantage in Gear Ratio to Size advantage. Not to mention cost saving as spur gears are the cheapest of all gear form.
Will follow this development with acute interest.
Old Sat 06 February 2010, 11:26
Kobus gave me the guts to go in for the arrangement- whats wrong in trying - afterall we have it everywhere on the mechmate, its only straight on the others and here its round (the rack)
Old Sun 07 February 2010, 19:58
Besser
Just call me: Besser
Vic
Yes spring loaded is the simple and effective anti backlash method. Getting fancy can mean headaches
See Toyota's pedal jam . . . . . for the side-conversation
Old Tue 23 March 2010, 13:29
Long due pictures
pics of the finished pulpit and jali work.
Old Tue 23 March 2010, 13:52
Sergio-k
Just call me: Sergio #61
Athens
Greece
Amazing Irfan !!!!!
Very nice work. Congratulations.
How long did it take you to finish that including paint ?.
Old Tue 23 March 2010, 13:56
Irfan,
It looks great. Thanks for sharing the pictures.
Old Tue 23 March 2010, 15:18
Impressive, impressive.
Old Tue 23 March 2010, 16:47
Hat’s off to you Irfan….
Where is this place, it’s seem V-nice !?
Old Tue 23 March 2010, 23:32
Wow!!!
Wood carving - Bangalore, India issac winfred Introduce yourself and start planning 3 Wed 12 August 2009 10:13
We made it to #3 !! WTI Archives 3 Thu 05 June 2008 15:57
Laser kits for India - out of Bangalore javeria Profiled (laser cut) & bent steel plate 3 Tue 13 May 2008 22:50
CNC Router with Servo motors & belt drives (non-MechMate) - Bangalore, India Irfanulla Archives 67 Mon 01 October 2007 13:11
Hi, new to the gang - Bangalore, India ANIL Introduce yourself and start planning 5 Sat 09 June 2007 10:45
