Old Tue 19 January 2010, 04:10
albertoslayer
Just call me: albertoslayer
san blas
Mexico
How many motors use mechmate in the long axis
Hi, I'm gonna build a mechmate and I want to know how many motors use mm in the long axis, 1 o 2?, Right now I have 3 740 OZin Stepper motors, thank you for the help and sorry for my bad English
Alberto
Old Tue 19 January 2010, 04:17
2 motors on long axis. You need 4 motors total.
Old Mon 01 March 2010, 23:39
Besser
Just call me: Besser
Vic
Well it depends on which is the long axis. Commonly 2 but if your Y is longer then your X (mine is) then the answer is 1.
Alberto, those sound like powerful motors for a MM.
Old Tue 02 March 2010, 01:07
isladelobos
Just call me: Ros
Canary Islands
Spain
Well, this is because it applies creative engineering, but you can see the design of the PlasmaCam has done it with one motor Link
One tube inner the granty and a big motor is the secret.
Old Tue 02 March 2010, 01:48
albertoslayer
san blas
Mexico
Hi
So, do you think that 2 stepper motors of 740 oz-in are to big for my long axis??, I have 4 stepper motors of 740 oz-in, what do you thing about my motors??, sorry for the english jaja
Kind Regards
Alberto
Old Tue 02 March 2010, 05:39
Alberto, do you have any of the electrical data for the motors. We can help you better if we know exactly what you have. Normally, a 740 oz*in motor should work fine. It is probably very similar in size and capability to the Oriental Motor PK299 motors that I've tested.
Old Tue 02 March 2010, 14:48
albertoslayer
san blas
Mexico
Hi Richard
the motors are RHT34-740 from http://www.homeshopcnc.com/RHTstepperMotors2.html
The data information that I have is:
Motors are 4 Lead parallel configured, 2 phase, 1.8 degree step angle
HOLDING TORQUE Nm 5.2 (740 oz-in)
Rated Voltaje 2.0
Rated current per phase (amps DC) 6.0
Resistance 0.33
INDUCTION mH 2.7
Rotor Inertia g-cm2 1400
I hope that you can help me with this information, thank you!
Kind Regards
Alberto
Old Tue 02 March 2010, 20:59
Originally Posted by albertoslayer View Post
. . . . .Right now I have 3 740 OZin Stepper motors . .
Besser read 3740 oz.in per motor, instead of 3 motors at 740 oz.in each.
Looking at the homeshopcnc link, the motors are 78mm long and weigh 2.3 kg. That immediately suggests single stack, and a rotor inertia of 1400 g.cm^2 confirms it. (equivalent Oriental Motor is the PK296 series). It is highly unlikely that the 740 oz.in is possible from these motors on a permanent basis without damaging them. These motors will not be suitable as direct-drive motors for the MM, but with 3:1 belt reductions, you could be okay.
Old Tue 02 March 2010, 21:27
albertoslayer
san blas
Mexico
Hi Gerald,
Thank you for your quick response, I donīt speak English very good.. sorry XD, single stack is a bad thing?, I donīt understand this:
"It is highly unlikely that the 740 oz.in is possible from these motors on a permanent basis without damaging them"
Could you explain me this with single words jaja, I understand that I need a 3:1 belt reduction system but I donīt understand why
and I have one question jaja, my MM with that motors and the 3:1 belt reduction gonna works fine and fast or it gonna be slow???
Thank you!
Kind Regards
Alberto
Old Tue 02 March 2010, 21:31
albertoslayer
san blas
Mexico
Sorry Gerald I donīt ask you one thing..
Can I use the RHT34-740 Oz-in on direct drive with a ballscrew?, because my Z axis gonna be with ballscrew.. or I need belt reduction in the Z Axis too?
Thank you
Old Wed 03 March 2010, 01:22
Alberto, I have no experience with those motors, and I have no direct experience with ballscrew drives on router tables, so I can not answer all your questions.
Simple language:
I do not believe the specification of 740 oz.in that is given by the supplier. I think it is a lot less. (maybe 500 oz.in max?)
If you fit a pinion gear direct to that motor, and run it direct on the rack, then the performance will be bad.
If you use belt-drives with that motor, I think you will be okay. I never make promises of speeds.
Old Tue 09 March 2010, 11:44
rick748
Just call me: rick
wrexham
2 motors on X axis
I know ive read somewhere regarding keeping the 2 steppers working together on the x axis but cant find it anymore...can someone please point me in the right direction.
thanks
Long Z axis and motor springs glintid 40. Z-Slide 5 Thu 16 January 2014 10:32
Selecting motors for the MechMate Gerald_D Motors & their mountings 278 Tue 26 February 2013 08:27
Rotary axis (4th Axis) or Indexer software smreish Graphics & CAD 0 Tue 28 July 2009 07:02
Selecting motors for the MechMate - some history Gerald_D Archives 151 Sat 11 October 2008 00:12
Concept for Five Axis Mechmate with 1000mm Z Slide jksiew Archives 7 Wed 26 March 2008 02:58
