Old Sat 26 December 2009, 10:43
Looks very nice!
But..... are these holes not to big for the mosquitos??
Sorry, I couldn't resist....
Ries
Old Sat 26 December 2009, 12:12
some more pics of the finished inlay work - the person finishing the piece filled the v groove with white metal putty - the lettering looked fabulous now - tomorrow its gonna get polished!
Old Sat 26 December 2009, 12:24
Irfan,
Is that a triditional design that you used or one you came up with?
Old Sun 27 December 2009, 01:53
Irfan, I am interested to know exactly what ' white metal putty ' is. Any trade name or website that describe it. Will it not shrink and fall out later ?
Old Sun 27 December 2009, 05:43
I think the white metal putty is talc mixed with GP resin,
nils thats a traditional design - art work is available over the internet
Old Sun 27 December 2009, 10:29
DMS
Just call me: Sharma #9 India
Rajasthan
Irfan,
Doesn't putty shrink when dry ?
I am asking becoz I am using other material sometimes there is gap, which can be filled with putty or putty may be used as inlay material.
Nice work.
Old Sun 27 December 2009, 10:35
Actually sharma - I don't know much about why he opted for that - I am aware of the fact that putty shrinks, btw what material do you use?
Old Sun 27 December 2009, 10:44
DMS
Rajasthan
I was trying to upload images when you replied.
I use bone pieces, supplied to me in sheet form glued on board. Which is then cut as inlay material. see example.
Old Sat 02 January 2010, 12:14
one more jali work
Old Sat 02 January 2010, 12:36
Nice Irfan, just to think a couple of years ago we used a fret saw to do those cutouts.Kobus I use a two part epoxy to do those type of fillings,if i work with valchromat I mix some of the dust with the epoxy and once it dries out and it is sealed you can`t notice that it is epoxy and it doesn`t shrinks ( the liquid type )
Old Sun 03 January 2010, 10:06
Problems in 2d cuts
Does anyone know why I am getting this sort of cuts?
I upgraded my Z with linear slides and yet face this problem??
it is solved to a large extent - but
is it the curves in the artwork, or do I need to use a different post processor,
or is it that I need to convert the curves to some sort of continuous curves???
or do i need a different Mach setting???
please help me.
RGDS
Irfan
Old Sun 03 January 2010, 10:14
jessyjames
Just call me: James
Reno, Nevada
Not too sure what is going on there. I seemed to have that problem at one time but it slips my memory.
What software are you using? Sometimes when I import stuff from Autocad into Aspire, Autocad will creat a bunch of little nodes around curves. I then have to have Aspire smooth the curves with one of its features..
But I think your problem lies in Mach if that is what you are using. All your curves lines are just too symmetrical to be a hardware problem, at least that is what I see. Seems like you need to check your "CV" settings in mach.
I will keep on thinking about what might be the prob.
James
Old Sun 03 January 2010, 10:17
May be CV setting in mach - i am thinking of same thing James, what is your CV setting?
I am using Artcam, what utility do you use in Aspire for curve fixing? yes the curve was imported from Acad.
Old Sun 03 January 2010, 11:00
Irfan, I had the same thing on the little disks that I did recently.It also baffeled me I eventually enlarged the drawing on the screen of my dxf file and saw that it was actually the drawing itself that had those ridges on them, it is not your MM that is the problem but the actual vectors that the toolpath follows.Enlarge that same drawing a couple of times where it gives you the rough cut and see if it is that.
Old Sun 03 January 2010, 11:41
Thanks Hennie - i will look into it soon
Old Sun 03 January 2010, 12:03
I noticed this sometimes when using a 12mm straight cutter and pushing it to cut 2mm per pass at a high feedrate. My whole table starts to vibrate and it seems that the router on the z-slide starts to oscillate. When I slow things down and take a 1 to 1.5mm deep cut it dissapears.
Old Sun 03 January 2010, 12:45
Irfan, did you notice that the rough cut is only when the X and Y motors run together to make a curve? If so, then see Rough Cut on Diagonal
Old Sun 03 January 2010, 15:01
mikefoged
Just call me: Mike #27
Randers
Denmark
Can you please post a pic of your settings for Mach3, I like to see how your CV settings are.
Old Sun 03 January 2010, 18:30
DMS
Rajasthan
Irfan,
Try to spline vectors and delete extra nodes.
Old Tue 12 January 2010, 11:13
one more of the Jali's
Old Tue 12 January 2010, 12:12
vishnu
Just call me: vishnu
Coimbatore(TN)
Nice Work Buddy, keep going..............
Old Tue 12 January 2010, 12:23
I think I need to visit India...looks like you have some nice wood available. Nice going
Old Tue 12 January 2010, 12:25
Irfan, Very Very Nice.
Old Tue 12 January 2010, 13:41
Castone
Just call me: Leo #41
Soddy Daisy , Tn
As always , very good work. Keep them coming I really enjoy looking at them.
Old Tue 12 January 2010, 21:04
Ah Kobus, thats pieces of teak wood joined together to form a plank -
heath - vishnu and Leo - thanks for the good words !
Old Tue 12 January 2010, 21:29
I like it when you do those jobs, make me want to make some doors with themgood work Irfan.We need to win the lotto to afford teak in SA.
Old Tue 12 January 2010, 22:43
Nice work Irfan. Did you find the reason for the rough cuts you mentioned with the earlier pictures?
Old Tue 12 January 2010, 23:33
G' I seem to have not set my machine upto the mark - i need to look into it further,
meanwhile does anyone have the model 99474(running horse) from 3d model club, it was given out last year as a free sample, the one I have has a corrupted zip file
Old Wed 13 January 2010, 02:39
show us a example if you can
Old Wed 13 January 2010, 03:26
this one oops its 99473
Wood carving - Bangalore, India issac winfred Introduce yourself and start planning 3 Wed 12 August 2009 10:13
We made it to #3 !! WTI Archives 3 Thu 05 June 2008 15:57
Laser kits for India - out of Bangalore javeria Profiled (laser cut) & bent steel plate 3 Tue 13 May 2008 22:50
CNC Router with Servo motors & belt drives (non-MechMate) - Bangalore, India Irfanulla Archives 67 Mon 01 October 2007 13:11
Hi, new to the gang - Bangalore, India ANIL Introduce yourself and start planning 5 Sat 09 June 2007 10:45
