Old Sun 13 December 2009, 16:47
oddname
Just call me: frallan #57
skane
Sweden
Just to get stuff done ive started researching spindles a bit more.
Seems Ill be getting a Elektro motor from http://www.teknomotor.com/.
1.6kW 24000RPM motor, suitable for both milling and drilling due to Double angular contact bearing in spindle nose and tail. This will be powered by a used VFD i got from a friend. A Danfoss VLT 6011, 7.5kW and around 16kVA. Sounds pretty solid to me, anyone got comments?
Old Sat 19 December 2009, 04:51
oddname
skane
Sweden
Move of the steel is delayed a little due to bloody snow :P
So have to write something and show the newest addition to my milling project:
Teh awesum VFD and spindle!
http://www.pici.se/gal/oddname/Mill/
Old Sat 19 December 2009, 05:21
My village weather at the moment: http://www.fishhoekgalley.com/webcam_fullscreen.php That white stuff is sand.
Old Sat 19 December 2009, 14:31
Claudiu
Just call me: Claus #43
Arad
Romania
Pictures taken 5 min ago.
minus 10 deg. celsius.....25 cm snow. ...
From that wooden Deck we usually jump into the pool...
Old Sat 19 December 2009, 19:42
Our pool has been frozen over for at least a month now. -32C tonight. Hope your metal shows up soon.
Old Sun 20 December 2009, 04:32
oddname
skane
Sweden
Its just a matter of time and willpower, will try to get it all home once the garage is cleaned. =)
Old Tue 22 December 2009, 11:29
oddname
skane
Sweden
And so the monster is home!
Small test of it all, atm a bit tight due to more cleaning needed, just cleaned enough to make it fit More pics in the link to the gallery a few posts up.
Old Sat 26 December 2009, 14:08
oddname
skane
Sweden
While waiting and fixing stuff I got my motor running wity my VFD
Seems pretty nice, ceramic bearings and duty cycle: 1
http://www.vimeo.com/8397375
Old Thu 04 February 2010, 07:17
oddname
skane
Sweden
Small update:
Not much is happening but at least the rails are of being machined since I failed a pair of rails
An older pic of the steels status:
Started doing the electronics in the meanwhile, providing a small familyphoto:
Old Sat 13 February 2010, 13:33
oddname
skane
Sweden
While waiting for rails and gaugeplate I started doing the electronics and im getting along with it quite well.
Cabinet with a few holes missing. 4x speakon connectors which seems to be the perfect choice.
Electronics with wiring started, dual contactor for safety reason, if One welds shut, no worries!
Schematic of the new part. A new button for reset if e-stop is triggered.
Old Sat 13 February 2010, 22:20
Frallan,
you are going strong I see!
make sure you cable chains have enough room for 4 cables from the gecko to your motors, they current one I say looks kinda small to me, or I just like things roomy...
Second, and I am not sure if you told me already, but just a reminder, are you planning to use any heat paste under your gecko's? According to the Gecko manual, you have to do this for stepper over 3A, yours are 4A.
Third, are you planning to use these cable connector things (see image) I forgot there names... I found them to be extremely handy. My suggestion is to use that instead of what you are using now, they they tend to break quite quickly..
Ries
Old Sun 14 February 2010, 03:19
oddname
skane
Sweden
Plenty of room
About the geckos, a MAX of 14A out from my transformer and not so good to use it all, som im settling with 12A, 4x 3A so no need for paste.
Old Sun 14 February 2010, 07:31
Frallan,
then in that case you need to current setting to be limited to 3A.
I did notice that my heat sink get's a bit warm to hot, mine are set at 4A (62K resistor).
Ries
Old Thu 01 April 2010, 09:16
oddname
skane
Sweden
Im just too lazy to update, but here is a current status: allmost done
Electronics all done, tested all axis but not together yet(will do asap cabling is done) , need to do some final assembly of them, and to fix the cables (some nice bruflex shielded cable and speakon connectors) Today I got my spoilboards too, its been hell finding them, but I did!
Old Thu 08 April 2010, 16:00
oddname
skane
Sweden
http://www.vimeo.com/10774348
May I have my status as complete and a serial number?
Old Thu 08 April 2010, 16:05
Congratulations with the work....
Looks like a very nice working machine...
Where can we see the MM logo's
Old Thu 08 April 2010, 16:15
oddname
skane
Sweden
Its under the machine :P
Nah, getting them tomorrow
Old Thu 08 April 2010, 16:18
hehhe..
it's seems like a fast machine over there... I think it's because you are at 230V, I am at 115V
Old Thu 08 April 2010, 20:05
Cool !! Congrats on the Machine. Show us your logos (sounds like Marti gras sign I have seen ..... )
Old Fri 09 April 2010, 06:55
oddname
skane
Sweden
Took a bit longer then expected, the printer (a real life man) :P was out of white ink for the machine that will print on some kind of "vinyl" and cut my nice logos
Middle of next week is delivery
Old Fri 09 April 2010, 09:02
oopz
Just call me: oopz
Stockholm
Sweden
Congratulations and a nice build!! Grattis !!
/oopz
Old Fri 09 April 2010, 20:24
jehayes
Just call me: Joe #53
Whidbey Island, Washington
Well done! I like your "hands on" dust collector - it is the same one I use
Look forward to seeing your number and name on the list.
Joe #53
Old Sat 10 April 2010, 16:43
oddname
skane
Sweden
TY all :P
I made a temp one today instead of hands on, works pretty ok
http://www.vimeo.com/10830189
Soon my number will be mine!
Old Sat 10 April 2010, 19:47
AuS MaDDoG
Just call me: Tony #71
Brisbane
Nice machine!! Nice Vidieo's and congrats on getting your number soon.
Tony.
Old Sun 11 April 2010, 01:24
Well done Marcus! I read your thread again this morning and remembered that you had built your own CNC machine before. It will be interesting to hear your opinions on ballscrew versus rack & pinion, and any other things that you noticed so far.
Old Sun 11 April 2010, 05:39
oddname
skane
Sweden
Well this machine is way faster than my previous so, so far rack and pinions are the bomb. Not really much to complain about, a bit louder due to some cheap chinese rack and pinion (played with some other locally which were alot quieter and smoother) but they cost most more, but I can live with some noise when it works this great
Im pretty impressed with both the machine and the results it produces "out of the box" havent really had to adjust much, perfect flat cuts, no difference at all from each cut.
Old Sun 11 April 2010, 13:39
Have you tried any grease on the racks to see if the noise is lessened?
Nice job on the machine!
Old Sun 11 April 2010, 13:50
oddname
skane
Sweden
I was going to do that but forgot to get grease
A small test run made of some damaged MDF
Made a mistake with Z when running the finishing (separate code) so it messed up a little but all in all, it got potential.
Old Mon 12 April 2010, 09:59
jehayes
I would think twice about grease on the racks (dust collectors)
Old Mon 12 April 2010, 10:09
oddname
skane
Sweden
If there is enough dust collection that shouldnt be a problem, or if your not milling super dusty stuff like MDF.
Another Q, anyone using EMC2 and controlling their spindle via RS485 and MODBUS RTU?
57 legs turned Can do orders for others sailfl The Market Place 24 Mon 10 January 2011 11:10
Building a Wall mounted Slanted base - Stockholm Sweden oopz Construction started, but not cutting yet 26 Fri 12 March 2010 06:10
It is cutting! Angle motor drives, pumpable gasspring #14 -Soderhamn, Sweden hans.arnell MechMates already cutting 31 Mon 05 January 2009 15:25
Will be visiting Scandinavia next week . . . Gerald D Archives 39 Fri 06 June 2008 00:33
