Old Sat 05 December 2009, 14:14
Interesting, and good result!
Old Sat 05 December 2009, 14:29
obuhus
Just call me: Dmitriy #68
Kirov region
Russia
The main thing - is easy to work and stable result!
I now load video on youtube. It will be loaded - I will lay out the reference.
Old Sat 05 December 2009, 15:56
obuhus
Kirov region
Russia
And here cut&grind-skateboard in a position of 45 degrees. And result.
Old Sat 05 December 2009, 16:22
obuhus
Kirov region
Russia
Here a videoclip: http://www.youtube.com/watch?v=tnAmCa7islE
Old Sat 05 December 2009, 17:56
Castone
Just call me: Leo #41
Soddy Daisy , Tn
Rail
That is some very nice rail grinding.
Old Sat 05 December 2009, 20:46
Dmitry,
I just came across your thread here and noticed that in the pictures of post 6 (I think) you ground the shielding if the control cables from the BoB to the drivers on the cooling plate. This is incorrect. Officially they should be grounded on the BoB site, see this post http://www.mechmate.com/forums/showt...69&postcount=2
great build, I like to pictures, and I wish my rail grinding was that good!
Ries
Old Sat 05 December 2009, 21:28
Ries, there is nothing wrong with the way in which Dmitriy is grounding his Bob shields. Do you want to discuss it further in another thread?
Old Sat 05 December 2009, 23:34
Very nice grinding!
Old Sun 06 December 2009, 01:22
Claudiu
Just call me: Claus #43
Arad
Romania
Hi Dimitry,
You built yourself a rail grinding monster ! ...but with good results.
Nice building so far.
Good luck!
Greetings
Claus
Old Sun 06 December 2009, 01:38
obuhus
Kirov region
Russia
Thanks all for kind words Here an end result. X-rails are completely finished. Y-rails I will do again - better...
Old Sun 06 December 2009, 01:52
obuhus
Kirov region
Russia
And it is my relay board and its scheme.
Old Sun 06 December 2009, 07:24
@Gerald & Dmitry,
I think I did see that the shielding of the control (BoB to Drivers) is attached to the cooling plate of the drivers, I cannot enlarge the picture to confirm. it would be better to ground (put on the 0V side) the shielding on the Bob side.
if you want we can discuss this on a other thread, I am far from a authority though in this subject and haven't been doing electronics design for over 12 years.
Ries
Old Thu 14 January 2010, 08:24
obuhus
Kirov region
Russia
Originally Posted by riesvantwisk View Post
@Gerald & Dmitry,
Ries
Greetings, Ries.
I do not understand, what problems? Try to draw a wiring scheme of it.
Old Thu 14 January 2010, 09:33
Dmitriy,
shielding of signal cables should be done at the signal source, in this case on the BoB (PMDX) side, not on the gecko side.
Shielding the signal cable on the cooling plate of the gecko driver might even introduce more nasty effects (EMI) because usually this ground is what's called dirty.
Since the ground of the power supply is attached there, and the gecko's are connected to the power supply (high current) this might introduce more EMI then not shielding at all.
Also EMI in the ground plate might come from external interferences outside of the box it's not 0V! and might contain any other fluctuations from for example plasma welders, drills, saws etc.. So don't use a dirty ground for shielding signal cables.
Beside, from computer tot BoB is electrically connected, but from BoB to Gecko it's isolated using opto couplers (on the gecko side) . So it's best to keep this circuit as much separated as possible.
Lastly, and this is what gerald also mentioned, reducing EMI in your signal cables can also be archived by:
1) Not lying the signal cables and high power cables (110V, gecko power, stepper cables) close next to eachother in one line, it might look better, but it can introduce a lot of EMI in signal cables. Lay thm as far away from each other as possible, left, rights side of your control box for example and in separate cable ducts to insure separation.
2) If you do need to cross (in space) signal cables then do so in a 90 degree fashion, so
they cables don't 'see' each other. This technique is also frequently used in RF circuits where coils need to be layed out 90degrees from each-other to minimize interference.
Ries
Old Thu 14 January 2010, 10:06
obuhus
Kirov region
Russia
Ries, many thanks for a competent substantiation. I think, already soon I can check up it in practice And unnecessary contact pieces to cut off is never late.
Dmitry
Old Tue 27 April 2010, 09:56
obuhus
Kirov region
Russia
27-04-2010.
Greetings to all builders MechMate.
After a long break I had a possibility to continue work on the machine tool. Result on a photo.
Old Tue 27 April 2010, 10:01
obuhus
Kirov region
Russia
27-04-2010
Time has come to take in hands this...
Old Tue 27 April 2010, 10:47
I like the wind-up piece between the table legs.
Is RED the official colour of MM's in Russia.... looking smart
Those Motion King's are looking good on the belt reduction
Old Tue 27 April 2010, 11:03
obuhus
Kirov region
Russia
Red and Cherry
Old Tue 27 April 2010, 11:42
timon
Just call me: tim
Moskow
Russia
Дмитрий молодцом !!! Я с товарищем такой же собираю. Ток покрашу по другому.
Dmitry the good fellow!!! I with a companion same collect !!!Only I will paint on another))))))
Old Wed 28 April 2010, 22:00
Nice Work Dmitriy!
Old Wed 28 April 2010, 22:47
Almost there! Keep it up!
Old Thu 29 April 2010, 08:06
Looking Great !!!! Keep up the great work !!!
Old Thu 29 April 2010, 23:02
cvriv.charles
Just call me: charles
New Jersey
Your shop is scary
Old Wed 05 May 2010, 23:24
liaoh75
Just call me: David
Taibao
Taiwan
Dmitriy, your build is looking real good. Those belt drives are nice and looks like a very polished design.
Charles, I was just about to say the same thing but my shop looked a little like that until I cleaned it out. I'm sure a fresh coat of paint on the wall would make a huge difference.
Old Wed 02 June 2010, 09:01
obuhus
Kirov region
Russia
Greetings to all!
It seems, I have finished a layer pad of wires "on a paper". Here my scheme of MM
http://img-fotki.yandex.ru/get/4301/..._aaae94db_orig
Old Thu 03 June 2010, 00:16
Dmitriy, what software did you use to draw out this layout, I haven't gone thru the circuit- but a good effort i feel.
Old Thu 03 June 2010, 01:00
obuhus
Kirov region
Russia
Hi, Irfan.
One of my trades - the designer. Therefore I professionally own Corel Draw and Adobe Phonoshop. In most cases I use these programs - for me so more conveniently and easier. Also I use AutoCad and many other programs.
Old Thu 03 June 2010, 01:27
Thank you Dmitriy, now you can cut those beautiful designs on corel with the MM
Old Thu 03 June 2010, 18:59
PEU
Just call me: Pablo
Buenos Aires
That drawing should be part of the mechmate parts, beautifully done!
MachMate по русски - Krasnodar, Russia Maxkor1973 Construction started, but not cutting yet 1 Sat 14 June 2008 18:48
Interesting Dust Collection Software Brian_B Golden Resources 4 Sun 25 May 2008 21:32
