Old Thu 19 November 2009, 16:42
Nice progress, locking froward to see it assembled
Old Fri 20 November 2009, 02:04
Nice progress, wish I can build as nice.
Old Fri 20 November 2009, 10:45
Claudiu
Just call me: Claus #43
Arad
Romania
Is it blue enough?
That`s just a peek preview of how blue it is.
It`s just the 1.st coat of blue after 2 coats of primer.
Of course you can still see some uncovered spots but they will disappear
with the next layer of Signal Blue.(RAL 5005)
If it`s not blue enough just say it, it can still be changed~
Bye alltogether
Claus
Old Fri 20 November 2009, 11:41
Sexy !
Old Fri 20 November 2009, 11:52
That blue is good
Old Fri 20 November 2009, 14:44
buibui
Just call me: John #34
Seattle
Beautiful work so far, Claus!!
Old Sat 21 November 2009, 08:18
Claudiu
Arad
Romania
Good day everybody.
Little update on my new rails cutting.
I used a Makita and some Bosch INOX cutting disks 1 mm thickness.
I used 6 disks for one x rail and one y rail.
Maybe they are not as good as the ones from Pferd, but this is what I could get.
BTW I did NOT polish them. C´mon....
Have a nice weekend alltogether
Claus
Old Sat 21 November 2009, 08:55
Claus….
The rail step is an easy but painful one you’re over with…Congratulation these look quite on the money !
Now…the chamfering …cut the angle very gradually, this extra time taken will pay off at the end !!
Good luck, Robert
Old Wed 25 November 2009, 12:11
Claudiu
Arad
Romania
Its taking shape...
Hello guys...
Me again posting some of my latest work.
I assembled the table and leveled it so far.
I guess this will be the final place for the MM
to be used in future.
Some details:
I`m still grinding the rails, which takes much more time than expected.
Have a nice day.
claus
Old Wed 25 November 2009, 13:17
aniljangra
Just call me: Anil #44
Delhi
Your build is looking great Claus
I am also at the same step in my build, starting rail grinding today, though not thought of paint job yet ..
Old Fri 27 November 2009, 17:18
cab. guy
Just call me: Ron
Boise,Id.
Claus,
Nice job,I think your inclination toward heavy steel is right on.The actions produced of a cnc is like watching a jackhammer with high g force shifts. Good looking elect. panel.
Old Mon 30 November 2009, 09:25
Claudiu
Arad
Romania
Hello all,
some more details of my latest doings.
I saw in other threads colleagues having trouble with the Spider not perfectly fitting into the Y Car. I had the same case with a tollerance of 2 mm. The solution is simply adding some Spacers between the screws.
Here you can see some tape applied under the Z-Rack. It is not the magical VHB, but I found something similar from Tesa. It is transparent and more like a rubber than a foam. I`m testing it.
This is a View under the Y Car where you can see the Z-Plate in its most upward position. Please comment if it should be different.
I also have to say that I did not install any stop screws in the back until I have it mounted on the Gantry to see all neccessary distances to the tabletop.
This is the Max travel of the Spindle, of course it is still adjustable in its mounting.
The same max travel viewed from the Railside. When I have the motor mounted I will check the pinion still grips the rack.
Thanks for comments and suggestions.
Greetings
Claus
Old Mon 30 November 2009, 10:04
Castone
Just call me: Leo #41
Soddy Daisy , Tn
nice
Nice heavy duty machine, It looks great.
Old Tue 01 December 2009, 04:14
Claudiu
Arad
Romania
Some gadget for the MM
I found these real bright Flexible LED Strips in a local electronic shop.
I thought it could be a interesting solution to have a light over the working area.
The Led Strips are rated 12 V, the owner of the shop told me 3 Ah which I think is a little overpowered.
- I want to take out 12 V from the computersource which also powers BOB and the fans in the Control Box, If you think the source is not enough I still can add a little spare source just for the strips.
I bought 4 m of LED Strips which are attached with their own double sided tape to each Gantry tube.
This week all MDF has to arrive, then I can also construct the board!
Greetings
Claus
Old Tue 01 December 2009, 08:39
gixi
Bucharest
Romania
The ideea with led's is very cool. I'll try something like this... Good job till now.
Old Tue 01 December 2009, 17:22
Besser
Just call me: Besser
Vic
Awesome! BLING a Mech Mate! I'll put it on my todo list!
Maybe a soft brush attached to the Y car to sweep these as it passes will help keep them clean.
Old Wed 02 December 2009, 02:07
Why not putting strobe lights on rail and the Y-car supply the trigger pulse so that everytime the Y-car passes a strobe it will flash. We can have a disco if we have different colour lights.
Old Wed 02 December 2009, 02:40
Claus, last week my dentist showed me her new drill with built-in LED light. She says the teeth look much whiter now
Old Wed 02 December 2009, 04:44
Kobus,
When you are not cutting at night you can use the top for a dance floor.
Old Wed 02 December 2009, 05:26
If we tune the G-Code to play a tune it will be even better...I once heard a Shopbot playing Happy Birthday ...and blew out the candle on a cake.
Is this thread getting de-railed or what.
Old Wed 02 December 2009, 05:47
Singing Shopbot! !!! I can tell my family I'm not as crazy as they thought...
now I get to use the pin1 relay on PMDX board to turn on some LED...
Old Wed 02 December 2009, 10:52
Claudiu
Arad
Romania
Ok boys, you got me on that one...I`m happy you got your laughs...
But indeed they had also colourchanging Led Strips, combined with a pink table and some trannys....(from the other post)....but then who is doing the work.
Besides I managed to get my motors mounted.
Some on the Gantry and one on the Z.
Led Strips still to come....
Greetings
Claus
Old Wed 02 December 2009, 12:18
Thanks for understanding Claus. We are just one big happy family sharing a good time with each other..now where is the strippers ?....I mean strips...
Old Thu 03 December 2009, 10:21
Claudiu
Arad
Romania
Hi guys,
just a few pics of my rail shaping.
I`m in the first process of shaping them. After this I will try also to make them smoother...so my Led with reflect better
Greetings
Claus
Old Fri 04 December 2009, 01:19
Claudiu
Arad
Romania
Hi Bryan,
here is the file you`re looking for.
The mounting holes are now adapted for fitting on the Gauge Plate.
You see that I added some more thickness where the tapped holes are to add some strenght. So I guess to the original overall length you just add 8 mm.
SpindleMount mod.zip
Hope it is of use.
Greetings
Claus
Old Fri 04 December 2009, 05:34
Claus,
I recon we are using the same spindle. Here is my observation, the shiny part looks like a cladding and the actual body is the black painted top & bottom end which is a tat smaller then dia80mm. I would prefer to have my brackets holding the body rather then the cladding. Hope you agree.
Old Fri 04 December 2009, 05:35
Claus,
I recon we are using the same spindle. Here is my observation, the shiny part looks like a cladding and the actual body is the black painted top & bottom end which is a tat smaller then dia80mm. I would prefer to have my brackets holding the body rather then the cladding. but then again, my observation might be wrong.
Old Fri 04 December 2009, 13:52
Claudiu
Arad
Romania
Hi Ken,
Do you mean I`m not allowed to use the clamp on the shiny part?
I thought by fixing it this way I can still move it up and down as it would be needed for adjustment.
Please confirm if I have understood right.
Claus
Old Fri 04 December 2009, 14:01
Interesting question. On my spindle, the top and bottom black parts seem to be plastic caps over the ends of a shiny solid metal body, and my clamps are on the shiny part.
Old Fri 04 December 2009, 22:51
I prefer to clamp on something that is solid.
Let me write to the supplier & see what they say about this.
Greetings from Romania Claudiu Introduce yourself and start planning 3 Fri 26 June 2009 22:43
Letters and other projects hennie The Show Room 25 Thu 25 June 2009 03:12
Couple of CNC projects. Rad Racer The Show Room 2 Thu 26 February 2009 22:56
AutoScaled Projects - choosing cutters, mat. thickness, etc. servant74 Miscellaneous / General / Whatever / Catchall 14 Wed 28 January 2009 08:14
Cool front panel joint WTI Miscellaneous / General / Whatever / Catchall 0 Sat 07 June 2008 16:53
