Old Fri 20 November 2009, 14:32
Gato Richy
Just call me: Richy
Chillán
Chile
Sounds different bipolar unipolar
I used to work with unipolar connection, but I´ve been having some problems with Z motor (sudden fail) and I wanted to try bipolar, my surprise is that sounds different, so...is it normal?
Old Fri 20 November 2009, 15:10
Richy,
Bipolar Parallel uses the same voltage, but it has 1.4X as much torque as half-coil and draws 1.4X as much current. That can make the motor sound different.
Bipolar Series uses 2X as much voltage, but it has 1.4X as much torque as half-coil and draws 0.7X as much current as half-coil. That can also make the motor sound different.
Old Fri 20 November 2009, 17:38
Gato Richy
Just call me: Richy
Chillán
Chile
Thanks Richards
Unipolar, Bipolar series, Bipolar parallel, choices for 2phase steppers Gerald_D Motors & their mountings 47 Fri 26 February 2010 21:16
need 6A bipolar scheme gorantec 701. Motor Drives 18 Sun 27 December 2009 16:21
Resistors for G504 and wiring for PK296A2A-SG7.2 motors (unipolar) jehayes 701. Motor Drives 7 Sun 15 November 2009 19:16
bipolar (parallel) connection stepper's kongblom 701. Motor Drives 5 Wed 28 October 2009 00:43
What mode are u running your motor - Unipolar Bipolar eloid Archives 3 Thu 22 March 2007 22:23
