Closed Thread
Old Sat 31 October 2009, 23:29
chopper
Just call me: chopper
Big Lake Minnesota
[QUOTE=buibui;31945]Great looking machine, Chopper. I like how you mounted the eccentrics on the z-plate...I take it that's to keep one side vertical and only require adjustment on the other?
good eyes, you are exactly correct, I thought it to be to much screwing around to adjust it square and made the top left and bottom left solid and every thing else adjusts to them makes setting up the Z simple, you just have to make sure that you can shim the spider to square it up if necessary...
//chopper
  #32
Old Sun 01 November 2009, 11:29
And that's a lot of washers (shims)- even I have it on mine!
  #33
Old Fri 13 November 2009, 18:14
chopper
Big Lake Minnesota
my, bro has a metal fab shop and he needs some 304 stainless cut, and he wanted to know if I could do that for him on the MM, My reply was that a friend of mine just told me about these stainless bits for high speed machining
so we made a trip to the machine shop supply store and found the bits we were looking for, took them back to the shop and tried to cut stainless steel
and much to my surprise it worked this is 304 stainless 1/16 of an inch thick
it was cut as a test to see if it would work, so far so good.... if this works out it will save a lot of work and time shipping them out to get cut.
//chopper
  #34
Old Fri 13 November 2009, 19:39
lunaj76
Just call me: Justin #24
Littleton, (Colorado)
Chopper,
What's next steel? Great job!
  #35
Old Fri 13 November 2009, 21:20
Tell us more about this bit ?
Robert
  #36
Old Sat 14 November 2009, 13:16
chopper
Big Lake Minnesota
Justin,
been there done that.............1/8 mild steel with very little machine marks, better than I could get off of my bro's mill
these bits are amazing, I just turned my MM into a 4 foot by 8 foot cnc mill
  #37
Old Sat 14 November 2009, 13:26
chopper
Big Lake Minnesota
Robert
these bits are for the cnc machine world like a haas or equivalent,
also onsrud makes some look up there 83-300 series www.onsrud.com
feeds and speed are listed there, I want to throw out a disclaimer here I have done quite a few things to make sure my machine is tight... and backlash free,
without getting into a pissin' match I just want you to know that these cuts may not be accomplished with out the proper modifications to your machine excessive backlash may cause adverse effects like bit breakage etc.
//chopper
  #38
Old Sat 14 November 2009, 19:28
Thanks for this part #
Amicalement, Robert
  #39
Old Sat 14 November 2009, 20:27
chopper
Big Lake Minnesota
here are some more pictures. these are MM motor plates, kinda funny a MM making a MM,
these are .250 thick and are really smooth these pics are blown up a bit, you can reference to the quarter, I do not know how you can not believe that the 4 to 1 belt drives do not make a difference after seeing these cuts. I am getting better cuts in steel than most of you can get in wood,
//chopper
  #40
Old Sun 15 November 2009, 03:04
Claudiu
Just call me: Claus #43
Arad
Romania
Chopper,
excellent cut quality!
Really amazing.
It`s good to know, that with the right tooltip we can even work alu and steel!
Great machine.
Good day
  #41
Old Sun 15 November 2009, 10:50
Chopper could you show a picture with the entire part? How long did it take to cut? What did you use for coolant? Very cool stuff, thanks.
  #42
Old Sun 15 November 2009, 15:10
chopper
Big Lake Minnesota
J.R.,
here is a picture of the complete part, as far as coolant I used a stream of air,
and a little silicone lube once in a while, the air seamed to make the biggest difference, I didn't time it but as I recall it took around an hour to cut each piece, but some of that was wasted screwing down the parts and cutting air because I wrote the program a little deeper than the part, so it could have been done faster, but I wasn't in a hurry just wanted to see if it could be done.
//chopper
  #43
Old Sun 15 November 2009, 17:16
I'm amazed!! Good job.
  #44
Old Sun 15 November 2009, 18:17
Wow, those look really good.
  #45
Old Sun 15 November 2009, 21:11
Chopper,
Great stuff! Love you work. I'll be using your 4:1 Belt reduction for my build.
A few stupid questions, hope you can help clear my misery
1) You are using MDF as spoil board while cutting metal (AL & Steel)?
2) You use coolant for your cuts?
3) How to keep the MDF happy while applying coolant?
  #46
Old Sun 15 November 2009, 21:32
Rad Racer
Just call me: Wayne #25
Minnesota
Excellent Job! The MechMate is certainly versatile.
  #47
Old Sun 15 November 2009, 21:38
chopper
Big Lake Minnesota
Chopper,
Ken,
1) yes
2) on aluminum I do not use coolant, just a little air to keep the chips out of the cutting area, on the steel I used some silicone spray lube and air, mostly air, but if I were to cut it all the time I would set up some type of coolant system for the steel.
3) if you were to use coolant while cutting you would need to change out the table top to a substrate that would not be affected by the coolant like a plastic or aluminum, I am sure there are other types of material that could be used, my thought is to set up a tray to put on top of the table to catch the coolant when I need to use coolant, and remove when I do not ( so the MDF would be protected) ...
but I do not see myself using the MM to cut steel to often this was just a test to see if it could be done, so I haven't put a lot of thought into the coolant as of yet..no question is a stupid one.if you have more just ask..
//chopper
  #48
Old Sun 15 November 2009, 21:40
chopper
Big Lake Minnesota
thanks Wayne,
I was enjoying your posts on the 4th axes indexer you put on your machine very cool, what type of head are you using for the indexer?
//chopper
  #49
Old Mon 16 November 2009, 04:42
Even if it was not the MechMate destiny nor original concept, I’m somehow certain it is a « velour » to Gerald seeing that his DIY, low-cost no frill simple yet robust work horse can “ballet” dance on those metal, alu, and other material than plain sheet goods !
Robert
  #50
Old Mon 16 November 2009, 06:17
Chopper, can you confirm that you are still using a router, and not a spindle, for these cuts. There is often talk about a spindle giving a better finish than a router . . . . . I can't see that you can get much better than that!
Also, your z-axis is not very much modified, compared to the standard drawings . . . . this is another part where some believe that the basic MM design is weak. Would you think that z-axis mods are essential for basic wood board cutting?
  #51
Old Mon 16 November 2009, 09:14
chopper
Big Lake Minnesota
yes I am using a router it is a Milwaukee 5625 the only thing I have done to the the router is put new bearings in it ( much higher quality)
the modifications on the Z are minimal, the only difference on the Z is I welded it instead of bolting it, however, the spider is also modified ( I guess I consider that part of the Z ) and most of the modification on the spider is to make the squaring easier, and the bars that space the V wheels out are welded to the spider ( this really stiffened it up ), I think for some reason the welding makes the parts stiffer since bolts can move and welds cannot, so basically all the parts become one so to speak..
as far as it being necessary for wood board cutting is a good question.
I think the machine is under more stress from wood cutting than metal cutting, with metal I am limited to what the bit can do the machine is way more capable than the bit, on wood the same is true but at much higher speeds and feeds and depth of cut which can cause some to over drive their machine, the mods on the spider were needed to space out the V wheels anyway, so why not do it. so I guess that was a long yes...
I have thought about modifying the spider and Z assembly and I may some day, but what I have works..
I also wanted to add the only reason that I want to go to a spindle is not for cut quality, what I really want is the flexibility of different collet sizes right now I am limited to 1/4 or 1/2 inch size tooling, which so far has not been a big issue, and the er collet system is much better than what Milwaukee uses,
I have designed a collet system for the router but I decided that by the time I finished the proto-type I could have bought a spindle..
//chopper
  #52
Old Sun 22 November 2009, 08:30
liaoh75
Just call me: David
Taibao
Taiwan
Hi Chopper,
That was the exact reason I finally went with a spindle - collet size. I do a lot of work with acrylic and flame polishing and I now have a lot more bit selection. I no longer have to use a 3mm 0-flute with a 6mm shank (very expensive). I can just use a 3mm collet with a 3mm bit (very cheap - so cheap, I use a new bit for almost every job.
May I ask about your vacuum hold down system. I'm looking into a 10HP roots blower. You mentioned that you felt your vacuum was too strong? Can you tell me a little more about why do think this is so? I'm in Taiwan and there is a lot of industry here and when people talk about vacuum hold down, they all point point to this particular product. It pulls a staggering 55mm of mercury at a frightening cfm. I'm new to vacuum hold down and you have a pretty good setup. Can you give me some advice as to the plenum material (I'm thinking about using 3/4" PVC, bleeder (MDF) , or whatever else you can advise.
I'm still a little confused about the bleeder board. Why not just put what you cut directly on the plenum grid?
Sorry about so many questions but, if I'm spending almost $2000 for a 10HP roots blower, I just want to make sure I'm making the right decisions and understand what I'm doing.
Also, I've looked into your belt drive design and I can actually make a set very cheaply in Taiwan. Good design, simple and effective.
Thank you and sorry to inundate you with so many questions.
David
  #53
Old Sun 22 November 2009, 10:11
David,
If you use a vacuum mask between the plenum and the part being cut, you don't need a bleeder board. There are times when I use that method, but it requires the time, effort and expense of making a mask. (The mask is cut so that any through-cuts on the specific part do not have a direct "hole" to the plenum, which would cause the vacuum seal to immediately fail. When I cut a vacuum mask, I usually add AllStar gasket tape around the holes in the mask to give a little extra insurance against vacuum leaks.)
By using a mask and a GAST vacuum pump, I've cut parts as small as 2-1/2 inches square. With a normal bleeder board and two FEIN vacuums, I hesitate to cut anything smaller that 24-inches square without leaving a "skin". Others have had better results than I have, but they are usually at a lower altitude. (The Salt Lake City, area is about 4,500 feet above sea-level.)
  #54
Old Sun 22 November 2009, 11:10
dragonfinder1
Just call me: Dave #49
Astoria, Oregon
"I also wanted to add the only reason that I want to go to a spindle is not for cut quality, what I really want is the flexibility of different collet sizes right now I am limited to 1/4 or 1/2 inch size tooling, which so far has not been a big issue, and the er collet system is much better than what Milwaukee uses,
//chopper"
Chopper
Milwaukee makes a collet for 3/8" tooling. P# 48-66-1000. I use one in my 5625-20 router. It's not listed for that router but it looks identical, and as far as I can tell it measures the same. I use regular milling tooling in wood, that allows me more flexibility.
Dave
  #55
Old Sun 22 November 2009, 11:37
dragonfinder1
Astoria, Oregon
If you get that collet, you will need a collet nut as well. p# 44-40-0095.
You can get both from Milwaukee tools and Amazon.
M.T. collet $26.45, nut $3.60 total $30.05
Amazon collet $24.04, nut $16.26 total $40.30.
Amazon probably has free shipping on these items.
Unless you live close to a Milwaukee distribution center, you'll have to pay shipping. So it'll be close to the same.
Dave
  #56
Old Sun 22 November 2009, 14:09
chopper
Big Lake Minnesota
Dave
Thanks Dave, I will check into this it, do they have the same taper as the 5625 collets?
thanks//chopper
  #57
Old Sun 22 November 2009, 14:47
chopper
Big Lake Minnesota
Originally Posted by liaoh75 View Post
Hi Chopper,
David
David,
I am no expert with vacuum hold down, my reason for saying to much vacuum is more a limitation of my blower than there really being to much vacuum, my blower is an old army surplus air defense siren, and the duty cycle is really short about 15 minutes, and at that point it will blow the thermal protection on the motor, I need to upgrade it to a motor with a 100% duty cycle, also it depends on how I use my table if I have a small part to hold down and I only apply vacuum to one zone I will blow the thermal protection much faster since the blower has to work a lot harder, so when I do this I bleed off the vacuum through some of the non covered zones, so in reality I do not think there is to much vacuum..( I believe at the time I meant it sarcastically)
I use mdf for the plenum material on mine but in doing so you need to seal it to prevent vacuum loss, I have seen them made from pvc and aluminum,
the pvc I believe would be a great choice since it is impervious to moisture
and easy to machine, now my understanding of the purpose of the bleeder board (mine is trupan, light mdf ) is it acts as a spoil board so you do not cut up your expensive pvc plenum, but more importantly it spreads out the pull of the vacuum more evenly over the entire area of the zones being used, and if you cut all the way through your material down to the spoil board it slows down the leakage of vacuum so your parts are less likely to fly off, if you were directly on the plenum and you cut all the way through
it would be hard to produce enough vacuum to hold the parts in place since the vacuum loss would be great.(unless you did like Mike Richards suggested)
I also want you to know that the roots blowers are great for this application
but they are also very noisy so be prepared for the noise and the harder they pull the louder they get, so you can tell how good your vacuum is by the sound of your blower..
and thanks for the compliment on the belt drives, if this does not answer your questions, or raises new ones please ask I will answer to the best of my ability..
//chopper
  #58
Old Mon 23 November 2009, 09:00
dragonfinder1
Astoria, Oregon
Chopper
All three collets appear to be the same. They all fit the same collet nut, they are all the same height ( length ) and they are all the same diameter at the top end and they all hold the tool securely. For my money, they are the same.
On the CNC Zone others are using them as well with success.
Changing tools, sometimes three maybe four times during the job is a real pain, and once the MM starts to make an income, I'll try to justify an ATC set up.
I slid the MechMate through the funding officer, but to ask for $4000 to $9000 to make life easier on me won't be as easy until I have some real work.
Dave
  #59
Old Mon 23 November 2009, 17:23
chopper
Big Lake Minnesota
Dave thanks for the info....
by chance do you know what model router the collets are for?
I am also looking for an 1/8 inch collet
//chopper
  #60
Old Mon 23 November 2009, 20:47
dragonfinder1
Astoria, Oregon
The 3/8" collet is for model # 5660 and 5680, I haven't looked for an 1/8" collet.
If you are going to drill, then you might consider a Jacobs drill chuck for a milling machine. You could find one with a 1/2" straight arbor and use your 1/2" collet. You would have to turn you router to it's slowest speed.
Dave
Closed Thread
Reduction Drive by belt - a collection of various designs and how to build your own. Mike Richards Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 449 Sat 09 March 2019 17:32
Belt reduction box build T5 16 to 60 linus1 Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 3 Sun 25 July 2010 08:26
Has dust foot, belt reduction and plastic wheels #22 - Midrand, S. Africa MariusL MechMates already cutting 124 Fri 23 October 2009 03:33
Trying smaller motors with belt reduction #17 - Sao Caetano do Sul, SP, Brasil YRD MechMates already cutting 178 Sat 04 July 2009 08:59
Hello Everyone - Lake Park, MN r56554 Introduce yourself and start planning 1 Mon 25 February 2008 02:17
