Old Thu 22 October 2009, 01:15
sprayhead
Just call me: Francis
sydney
Considering using modulus 4!! yahoo, rack and pinion
Hi,
I have made some tests with a mod. 4, 13 tooth, 52mm pitch diameter, AISI1045 steel, black oxide finished pinion and a Nylon rack.
The test consisted of myself grabing the pinion by hand and rolling it over the rack forward and back while applying different pressures on the pinion against the rack. Guestimation tells that I have applied 5-15 kilos of pressure on the pinion. Since I was using a shaft through the pinion, it was easy to push it down against the rack.
The primary conclusion is that it runs very smooth and quiet, and it definitely improves as the pinion and rack further adjust. I was impressed. For some reason I thought that it was going to run rough and "vibrate" going up and down.
The rack costs only 25 bucks for 1000mm lengths and the pinion only about 5 dollars each, ordered straight from a factory in china. The rack is made of nylon, injection moulded, it has an internal steel flat bar running length wise for reinforcing and the quality looks nothing short of good. I did not test for pitch discrepance over lenght but I guess that if the mould was properly designed it wont be a problem.
I did extensively try to get a smaller modulus rack with but at this price I couldn't find anything but modulus 4.
If anyone is interested in giving it a try, let me know, I am just about to order 20 pinions.
The rack is very easy to find... It's made for gate automation. The particular rack that I have used was designed here in Australia.
Francis
Old Thu 22 October 2009, 23:57
lunaj76
Just call me: Justin #24
Littleton, (Colorado)
Francis,
Sounds interesting. How much different is the diametric pitch of this rack verses the one that is recommended. I have thought that a nylon rack might give less vibration. Would there be a seam to deal with?
Old Fri 23 October 2009, 00:05
The pitch of module 4 is exactly 4 times greater than module 1
Old Fri 23 October 2009, 02:37
sprayhead
sydney
Hi
Joining the racks looks like it is piece of cake. they come with a little slot on the ends that will probably help to some stage with the alignment. Ultimately the best trick will be to use a small piece of rack and use it to "syncronize" the two lenghts being joined.
The fixing can be done by above, as per MechMate style or by the side of the rack. The racks I got come with 8 holes (about 6mm dia.) for side assembly.
For MachMate style one has to make the holes... there is one catch. The steel in the rack style I got is actually a flat bar, 12x5. It might be a little tricky to get a hole right in the middle of the 5mm face of the flat bar... only trying will let us know how tricky. There is another style of the GateDoor racks that actually has a square bar inside, 10x10. That would make it easyer.
I'll post results... I'm still sorting out the special spur gears at the moment. The stock (48 or 52mm P.D.) spur gears all have 40mm tooth width and 20mm hub width, It's way too much, as this rack is 22mm wide. I'm trying to get some made with 20mm tooth width and 10mm hub width. I might be getting lucky just in a few days.
atb,
Francis
Old Fri 23 October 2009, 18:06
AuS MaDDoG
Just call me: Tony #71
Brisbane
Hi Francis,
Sounds interesting keep us posted, some pics would be nice
Tony.
Old Fri 08 January 2010, 05:32
sprayhead
sydney
Gerald
I'd kindly like to ask you to raise my upload .jpeg and .jpg data allowance to 400Kb, if possible.
I've got about 5 pics I'd like to upload.
Francis
Old Fri 08 January 2010, 05:40
Sorry Francis, but you will have to resize your pics. Mail them to me gerald at mechmate dot com and I will do it for you.
Old Fri 08 January 2010, 09:57
Seach through the forum and you can find links to tools to resize the pics. You can also open the PICS in Microsofts Paint program and select images then under "Stretch Skew" you can resize.
Old Fri 08 January 2010, 11:46
lumberjack_jeff
Just call me: Jeff #31
Montesano, WA
... or use photobucket.
Old Fri 08 January 2010, 12:58
On my laptop ( with XP ) I right click on the picture and click on SEND TO..... Mail Recipient. The next window pop up and ask if it can make the picture smaller.... I click YES and the Outlook Express window for generating a new e-mail pops up. I copy this smaller picture file to somewhere and use this on the forum....Brings a 3 Meg file to the 65 k size and quality is good.
Old Fri 08 January 2010, 14:22
sprayhead
sydney
thanks guys!
They way that I did it, when I am not lazy is to do that with IrfanView, it's a great picture viewer. In there you can batch resize and rename, it's very handy and it gives great results keeping image quality as it has a special algorithm for Jpegs.
Anyway, there is the rack and the custom pinions that I was talking about, they run quite smooth on the rack. I think that it will already do for me.
Next order I will try the next size smaller pitch diameter pinions (48DP) and ask them to grind the pinion tooths to 3 triangles (~0,8Ra).
As you can see on the picture the surface finish on the tooths is straight from the lamination process. Not bad but not like a ground surface.
Those pinions were cut off of what they call "gear wire" or something like that.
The motors are from MS Motor. I had to look in the gearbox... Posted for the curious minds out there:-)
F.
Rack and Pinion Suppliers: Outside the USA Gerald_D Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 81 Mon 14 May 2018 03:50
Rack and Pinion Suppliers: In the USA fabrica Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 87 Sun 08 March 2015 19:04
Rack and Pinion - understanding Diametral Pitch (DP) vs. module Claudiu Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 23 Sun 18 April 2010 08:19
Making your own rack & pinion Nikonauts Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 28 Thu 25 March 2010 01:29
Lubrication for rack & pinion? J.R. Hatcher Maintenance 14 Thu 09 July 2009 06:14
