Old Fri 21 August 2009, 01:30
I like the bookshelve, see you next week, will be in town from Wednesday.
Old Fri 21 August 2009, 07:39
Nice work Alan, thanks for sharing.
Old Fri 04 September 2009, 04:28
A quick job for one of my suppliers (My first export order...)
Base is of African Mahogany (I think )
3D engraved text
close up of the text - still with direct drive motors
Old Fri 04 September 2009, 04:39
I see you also went and visited PTR in Woodstock.Better watch Kobus don`t like it when we do small cutting.What was your feeding speed?
Old Fri 04 September 2009, 06:18
Actually I used a ProTech 30deg V groove I picked up at Hardware Centre CT. Feed speed was 1000mm/min, time to machine about 8 min. I also machined the bevel base with the MechMate. Clamped the block upside down at an angle and ran the head up and down across the block feeding Z down a little bit at a time manually - like one would do on a milling machine, writing the code would have taken me longer .
Old Fri 04 September 2009, 13:26
Hey you guys, what about RETURN on INVESTMENT...you are not suppose to have FUN
Pragtig
Old Fri 04 September 2009, 18:12
Beautiful work Alan.
Old Mon 21 September 2009, 19:39
Copy from another thread :
I have just returned from Johannesburg where I was offered a position at a very large fruniture manufacturer managing the maintenance at two plants (turned it down even though the salary offered was astranomical by my standards - all the money in the world cant justify an abusive boss!)
Alan ….. Felicitation on your values
Money helps making MM and pay important bills. But values & principals make a person. He's one of those not their yet !
Old Tue 22 September 2009, 03:33
Khalid
Just call me: khalid
Sadiqabad
Pakistan
very nice work on the trophy..
Old Tue 13 October 2009, 16:52
Now for some return on the investment...
Challenge for the week (actually it will take about a month at 8 hours per day). Machine a steak board from material supplied; outside cut to shape and a 3D ramp with groove to catch the juices without costing too much?
Finished steakboard before oiling (the client is doing the round over and sanding)
The original sample as supplied had a ramp machined with a ball nose cutter. the ramp runs along the length of the board from the surface down to a depth of about 10mm with a 30mm border around the edge of the board. Initial estimates of the cost to machine 900 of these was quite high as the 3D machining would be a slooow process, so I had to come up with another solution.
I decided to do the job in two stages, stage one would be the outside and groove at the end (actually the groove first of course) and stage two would be the ramp.
Left: Blank in position on Jig1, Centre: Slot and outside cut, Right: ramp cutting jig
To machine stage one required a fairly simple jig that held the board at the bottom edge and at the two corners that would be cut off. A vacuum would have been easier, but I don't have a sufficiently powerful pump. There are three cuts, #1 for the groove in two passes, #2 for the right side of the board from the bottom edge up to the handle and #3 for the left edge up to the handle both in two passes with an 8mm tungsten slot drill - speed 2000mm/min. Doing it this way in seperate paths prevents the corners breaking out as the grain changes direction. its a little slower but with a better end result. The hold down clamps are 20 x 5 mild steel flat held down by furniture screws attached to rumper nuts fixed in the jig from below. Cycle time about 4 min (I could shorten that if I make a better clamp system that locks down faster but there is a height restriction because of my dust foot)
To cut the ramp required a slightly more complicated jig. I decided to hold the work at an angle and just do a straight pocket cut in the area required. The ramp angles were calculated by doing a drawing in CAD of the section and then cut on the machine. Slots were also cut in the jig base for location purposes. There are two ramp supports and one edge locating fence. At the end of the ramps are hold down fingers as part of the jig and two toggle clamps with modified feet to hold the bottom edge down. Cycle time is also about 4 min but most of that is actual cutting as the toggle clamps make for very fast change overs. This is cut with a 12mm slot drill also at 2000m/min.
Ramp angle jig with edge locating fence in the background
Hold down fingers at the bottom of the ramps
Cutting the ramp with a pocket cut (this one is just trimming a mistake in depth setting, it is usually cut in one pass to full depth of 10mm)
The machine is running from 08:00 to 16:45 everyday with breaks at tea time and lunch time. What a pleasure to watch it racking up the Rands at every pass.
The Bosch router that I was a little concerned about at the start regarding heat is cool to the touch at the end of the day (hardly above ambient). The cooling fan produces an extremely strong blast of air that obviously aids in cooling. A cool tool means longer bearing life - I like it.
When cutting the ramp the X motors get quite hot to the touch, (not too painfull to hold but still within reason) the other two are only just slightly warm.
The dust extraction system is working very nicely, it does not put any strain on the Y car that I can see and follows the machine around like an obedient dog. I had to take it apart at the main pivot to remove a plug of wood slivers and fluffy offcuts this afternoon so I think I may have to change that elbow for one with a clean out panel. This is the first time it has happened but I think it is because of the pocket cutting of the ramp, it produces quite long wooly bits that get sucked up by the foot.
Old Tue 13 October 2009, 17:37
cncb
Just call me: Brian
Connecticut
Sweet fixture Alan. The thing I've always loved about these machines is they are so raw and simple to the point that there are very few boundaries and the only limit usually is ones creativity in the process. While simple it shows if you can't find a reasonable program for the part think out side the box to find a simpler, better way to achieve the same results in less time.
Old Tue 13 October 2009, 18:58
Alan,
Nice work. Thanks for sharing. So how many steak boards can you cut in an 8 hour day...if it's not proprietary?
Old Tue 13 October 2009, 19:07
Alan,
Excellent job. So how many are you able to do in a day? Im surprised the customer did not want a name or logo engraved in the board as well.
Old Tue 13 October 2009, 23:02
Gee, I didn`t know the MM can eat and have tea !Nice going
Old Tue 13 October 2009, 23:35
900, this sounds like 'WORK' Nice going
Old Wed 14 October 2009, 00:23
CAM Craft
Just call me: Sean D
Nice order congrats. pity about all the clamping on off (painful). Job like that with my Makita 3612c (MM1) the bearings will need a change after 30-40 days wear and tear. After time the housing for base and topside for both bearings need replacement to reduce play and vibrations (6months). We keep a full spare armature, top bearing housing/locator and brushes on the shelf for a quick 20min change over before sending the old armature for a +-2week service.
Old Wed 14 October 2009, 01:17
I can do about 100 loadings a day which equates to 50 complete units per day. 900 units = 18 days without any holdups.
Hennie, thankfully the MechMate does not eat or drink but the operator seems to insist on it...can't understand why
Old Wed 14 October 2009, 02:30
Alan, something that I have done the other day with the same thing of having to load and then restart is that I had the machine cut 3 of the same items along the y-axis.I had it cut 3 items and as the machine were at no 2 I reloaded the first one thus when it got to finish no3 and it went back to home I just started it again.It saved a lot of time.Talking about tea?I think it is time.
Old Thu 29 April 2010, 02:31
My business has been keeping me very busy lately (busy trying to get more work!!!) so have not posted much here, but I have managed to get my website up at last - only an interim version but have a look and give some feedback please (visual appeal, loading times etc) tufftoys.co.za
Old Thu 29 April 2010, 03:21
Nice selection there Alan. Speed from my work that is sometimes slow is good...nothing wrong with you server and page setup. I find Hennie's pages very slow from here.
I think your prices are to cheap... You must be buying wood from a oke like me to get things done for those prices.
Old Thu 29 April 2010, 03:23
Site not uploaded yet?:
Old Thu 29 April 2010, 03:24
Second attempt worked okay
Old Thu 29 April 2010, 03:37
Okay, you were probably changing the index.html when I looked.
I think you need pics at the home page and next level . . . . . it took 3 clicks before I could see your products and that is just too many clicks for some people.
Old Thu 29 April 2010, 05:34
Kobus you are used to slow
Old Thu 29 April 2010, 15:58
Thanks for the comments guys, Gerald, the front page is not to my liking yet so will get a make over soon.
To the SA guys, check out the latest issue of the "Home Handyman Magazine" from page 40 onwards - I've been published
Old Fri 30 April 2010, 12:45
dragonfinder1
Just call me: Dave #49
Astoria, Oregon
Alan
You should post a link to the article on your web site, if it's on line, or scan it and put it on your web site if it's allowed. I think it would be good for business.
( second post, first one didn't show up after a couple of hours )
Old Sat 01 May 2010, 11:02
Smile
Been doing some product development - made a collection of side tables and a wine rack system
They are all done with MDF, the coloured ones on the left are basecoated with clear than sprayed with tinted lacquer.
Dave, the article is not business related, but hopefully the start of a new line of income for me, magazine article writer...
Old Wed 09 June 2010, 12:39
A few jobs I have been up to lately
Firstly a presentation shield, machined in Rhodesian Teak (I only did the engraving - the client had already cut the shape by the time the job got to me)
Proyotype media shelf sized to accept cd's and dvd's
Tabbed joints - all knock down
Landed a nice job to replace existing indoor benches at the local casino complex - the originals had been made with MDF but have not fared very well in a very demanding environment - very high traffic.
They are a modified version of Lutyens bench without the extra curve that it usually has in the back rail - again to match the ones they are replacing, I would have preferred to make them accurate to the traditional design but the customer who pays gets to make the decisions
Besides the obvious cutting of the complex shapes I tried to do as many of the mortises on the MM as possible (all the simple one were done on a horizontal mortiser) In total there are nearly 100 joints in this bench (200 mortises - using loose tennons) The seat slats are attached with pocket hole screws from below so no visible screws or plugged holes anywhere to be seen from above.
Front legs with mortises and dowel holes.
Cutting the back rail.
Legs and rails for two benches.
Top rail glue up.
Back sub assembly glue up - starting to get tricky...
Main glue up - not to be attempted without doing a dry run first.
Assembled bench after staining.
Completed bench with AC Lacquer.
Close up of logo engraved into the front legs.
Old Wed 09 June 2010, 13:42
Nice Alan...I like it, pity they wanted it stained that dark.
How many benches are you doing ?
Old Wed 09 June 2010, 13:55
PEU
Just call me: Pablo
Buenos Aires
Alan, amazing job!
Mechmate For Sale Cape Town South Africa Wado The Market Place 1 Mon 14 November 2011 06:44
Built a few more - Cape Town, South Africa Gerald D MechMates already cutting 171 Sun 07 August 2011 05:29
New MM in Cape Town, South Africa anton Construction started, but not cutting yet 24 Thu 03 December 2009 10:13
Alu console frame together and some steel cut - Cape Town, S.Africa maxman Construction started, but not cutting yet 31 Wed 18 March 2009 13:27
The original MechMate - Cape Town, South Africa Gerald_D MechMates already cutting 79 Wed 27 August 2008 23:52
