Old Wed 12 August 2009, 07:32
Great Results. You must be proud.
Old Thu 13 August 2009, 06:45
gorantec
Just call me: gorantec #59
bitola
Macedonia
Very well done Gorantec!
How many other CNC routers are in Bitola? I am sure that you will get nice work for your new machine.
I hope theat i will have work i dont know how much have cnc router but have
Old Thu 13 August 2009, 06:46
gorantec
bitola
Macedonia
Originally Posted by javeria View Post
great sir, how are the drives performing???
Drivers for now working perfect ?
Old Thu 13 August 2009, 06:47
gorantec
bitola
Macedonia
Originally Posted by jhiggins7 View Post
Gorantec,
Congratulations. Great work.
Okay now, just some logo's and you are ready for a Serial Number.
yes this days i will put logo
Old Sat 29 August 2009, 12:07
gorantec
bitola
Macedonia
Wellllllll i have problem with my MechMate
i have notice today i was like to making some mdf door but on the long distance i have see theat my mechamate dont work like need to work i dont have correct square on Y - axis on the X axis is everything ok but on Y please check the pic and some advice how to fix .
My thinking is to correect with Y rails to unweld and make to 90 degree angle .
Old Sat 29 August 2009, 13:28
Well, off-hand, it appears that your table in not square.
You show that the "y" out of square travel is 10 mm. How far does the bit have to travel in the "y" direction to get to be 10 mm out of square?
Are your X cross bearers welded or bolted? If bolted you can loosen the bolts of the cross bearers, loosen the bolts in the MDF and use a "come-along" diagonally across the table to square up the table.
I don't have experience with welded cross bearers, but I believe you can do the same thing on a welded table.
Old Sat 29 August 2009, 13:40
gorantec
bitola
Macedonia
Y travel 1100 mm to go -10mm my x rail is bolted so you think to make work totry with x rail ?
Old Sat 29 August 2009, 13:43
Gorantec, relax, no need to cut the gantry and weld again!
Read this thread: Setting the Y-axis square to the X-axis
Okay, that thread is not so easy to read....sorry. But, also look at drawing M1 20 100 A, where it says: "THIS DIMENSION IS ADJUSTED TO MAKE THE CARS RUN SQUARE AND TRUE". You need to adjust the washers between the V-rollers and the frame so that the y-gantry is square to the table when the motors are dropped down and the gantry is completely free.
Old Sat 29 August 2009, 13:45
John, the square of the table makes no difference. The cutting squareness is all decided by the gantry being square to one x-rail.
Old Sat 29 August 2009, 13:49
Looking back at your posts, those cross bearers definitely look like they are welded. If you are out-of-square and you can't change the table, you may have to adjust the X-rails...or at least your stops. The most important measurement for the X-rails is that they are parallel. I used a tape measure to check them after having used a measured rod to set them initially.
Or your Y Gantry may be out-of-square. You can check this by making sure that your X-stops are square and rolling the Y Gantry against the X-stops. I used the method of measuring from corner to corner diagonally across the table...both diagonals. I made sure theses measurements were within 1 mm. Once you've done this, the Gantry should hit the X-stops at the same time. If not, your Y Gantry is out-of-square.
Old Sat 29 August 2009, 13:56
I see your point, Gerald. I bow to the expert. Sorry, I was typing while Gerald was posting.
Old Sat 29 August 2009, 14:00
No problem John...I appreciate your willingness to help.
A lot of people don't understand the value of the adjustable stoppers at the ends of the x-rails - they are actually the key to the whole squareness issue.
Old Thu 13 May 2010, 11:01
gorantec
bitola
Macedonia
here me again :)
Since my project was paused now again starting to work with my great Mechmate machine here is some photos what i made for one customer and i will post some videos .
Old Thu 13 May 2010, 11:23
Serial number time! Nice to see you back Gorantec.
Old Thu 13 May 2010, 11:27
Nicely Done Gorantec!
Old Thu 13 May 2010, 15:25
gorantec
bitola
Macedonia
ooo yes im even forget for the serial number
Old Thu 13 May 2010, 16:01
gorantec
bitola
Macedonia
Ok here some videos
this video show how im finding home position :
http://www.youtube.com/watch?v=Fwq-4gLZAgs
and this is machine in work :
http://www.youtube.com/watch?v=I-5Aw2e8Fh4
more when i made some other project
Old Thu 13 May 2010, 16:27
mikefoged
Just call me: Mike #27
Randers
Denmark
Looks good, but the first video doesn’t work, I'll love to see how you numpad works.
Old Thu 13 May 2010, 16:32
gorantec
bitola
Macedonia
i will post tomorow again
Old Thu 13 May 2010, 16:45
jessyjames
Just call me: James
Reno, Nevada
Gorantec looks good. I was not able to see the first video of it cutting but had a program that downloaded the video anyways and was able to see what youtube wasn't showing. Looks like you are cutting what you posted in those pictures of some type of grid pattern. Nice to see you have the dust collection up and running too. I noticed that you should be able to push that baby a little bit faster but of course you are probably working out the bugs.
Congrats on the serial number...
James
Last edited by jessyjames; Thu 13 May 2010 at 16:46.. Reason: Spelled Gorantec's name wrong.. Sorry
Old Thu 13 May 2010, 21:13
Congrats - Looks like you get #59 !!!
Old Fri 14 May 2010, 02:02
Gorantec,
Congratulations! Welcome to the club.
Old Fri 14 May 2010, 05:35
myozman
Just call me: Mike #16
Demotte,IN
Congratulations on #59
Old Fri 14 May 2010, 10:14
gorantec
bitola
Macedonia
James
thanks but when i go faster with the machine bit's will broke when i test my machine it can go up to 15 m/min but bits and my router of 1200 W it can not fallow the machine becouse theat is cheap router and i use 8 mm bits in theat video MechMate go with 3 m/min
Old Mon 17 May 2010, 18:16
Builder's Log Update
Gorantec,
Congratulations on completing your MechMate and Serial #59. Great job!
Please provide the Y dimension for the Builder's Log.
Also, please review your Builder's Log entry and let me know any changes you want to make.
Old Mon 24 May 2010, 04:40
gorantec
bitola
Macedonia
Gorantec,
hi
the Y dimension is 1100 mm and please also update date completed 11-aug-2009 becouse since then machine is fully functional
Old Fri 11 October 2013, 03:33
gorantec
bitola
Macedonia
Finialy i decide to buy Spindle :D
After couple year of working with this excelent machine i decide to buy Spindle and here is
Now to make mount for spindle and teak inverter
Old Thu 17 October 2013, 03:46
gorantec
bitola
Macedonia
inverter
Can someone please let me know i found inverter RATTM are this is good for my spindle or ?The price is very good but please some one if have expirience with this let me know
Becouse for ABB or Scneider i need to wait one month
Old Thu 17 October 2013, 08:34
gorantec
bitola
Macedonia
anyone ?
Old Fri 18 October 2013, 06:24
gorantec
bitola
Macedonia
Finaly i found inverter
MechTorch! The First Mechmate Plasma #58 - Winston-Salem, US uncsamococlass MechMates already cutting 116 Sun 29 December 2013 08:23
How do you edit your video for Youtube KenC Test Area for this forum 9 Fri 15 January 2010 20:28
3D Elk cutting (video) #13 - Hagerman, New Mexico Greg J MechMates already cutting 415 Sat 05 September 2009 21:28
Need help with rack dimensions :( - Bitola, Macedonia gorantec Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 4 Fri 10 April 2009 08:19
It is cutting! Angle motor drives, pumpable gasspring #14 -Soderhamn, Sweden hans.arnell MechMates already cutting 31 Mon 05 January 2009 15:25
