Old Thu 09 July 2009, 02:31
Can`t wait to come weekend so I can get some sleep.Kobus you know I was joking about the power when we were on the train we were 9 hours late.got carted by bus with a public inspection that expired in 2004 and that after we were dumped in Alicedale.Nooit weer nie!
Old Thu 09 July 2009, 14:11
PEU
Just call me: Pablo
Buenos Aires
Originally Posted by Kobus_Joubert View Post
Well I was a bit distracted the last few weeks. My work is interfering with my hobby
But on my travels I found this old man in Komatipoort making tables from local HARDWOODS....just like I prefer a table....Big and Strong and Beautifull..
Attachment 5170
What a beautifull table! how are the pieces held together? Glue or something else?
Old Thu 09 July 2009, 23:35
Hi Pablo, I also asked that question to the man. What he said is that these pieces of hardwood are so hard that to try and glue and clamp them is impossible. We watched as the did a table...each piece is planed to get a square edge....then they drill a 11,something hole in each piece with the aid of a simple jig. Into these holes a 12 mm round bar is hammered. The table is build lying on it side and each new piece of wood is hammered into position with a BIG block of wood. Once done the top is hand planed and hand sanded. He the uses Cast RESIN to cover all imperfections and to give it that nice shine. He said that when you move the table to different regions it might 'MOVE' a little, but it will not fall apart...
Old Fri 10 July 2009, 00:05
Kobus, this is a brilliant pour-on resin: http://www.kraftex.co.za/pratliglo.htm
Our daughter sticks photos in the bottom of tea-trays and pours/spreads this stuff over to make a flat gloss clear surface that is totally coffee and heat proof.
Old Sat 11 July 2009, 09:35
I started later that hoped, but still managed to give V-Carve Pro V5 a testdrive today.
Made another little Flower Box thing for the wife.
And also used the Vectorize function....this was a normal jpg file....can still tweak it I suppose....Sorry time running out, BBQ is going and a Rum and coke is waiting
Old Sat 11 July 2009, 09:56
Hey ,Kobus that texture looks like a bad sanding job, Nice going !
In my house my wife keeps on begging for things that I have to make on my MM ( old story shoemakers kids don`t have shoes ).That is why I am building her ,her own Machine.(will start thread soon )
Old Sun 12 July 2009, 07:42
Just something to mention when using new software.
I loaded V-Carve Pro and could not wait to testdrive it on old BBB. I did some checks, but overlooked the SAFE-Z height setup. The program defaulted to 1mm and as I was working with 6mm MDF that tends to LIFT a little when lying on the table...I got a few EXTRA slots on my piece that I was cutting...nothing serious but somethng to look out for.
Also what happened is when old BBB started up after a bit of a holiday, I could not get the E-Stop to reset on Mach-3....but luckily when you build the machine and have the minimum amount of wires on the beast, it was quickly sorted out....OWNER BUILDER---FIXER...What a way to go. VIVA MECHMATE VIVA !!!!
Old Sun 12 July 2009, 09:41
Dough just to show you that the bike now has 2 wheels...
Francois my son and me did a nice run today....2 old bikes in nice condition still attracting attention wherever we went.
Old Sun 12 July 2009, 09:47
Kobus what size cutter did you use on that last item ( sorry for asking and I asked Irfan early on the same question )I am going to do a project soon and I need to get the corners close to square as possable.
Old Sun 12 July 2009, 12:15
Nice Bikes Kobus. I'm envious. Over the years, I've had several Suzukis. One of these days, I'll get another one.
Old Sun 12 July 2009, 12:28
Doug, how do you handle all the times that you are called Dough?
Old Sun 12 July 2009, 12:59
Ha ha. I was just telling Kathryn that somehow, my name has been changed to Dough on this website. I recall that you corrected someone once before.
The only explanation I can come up with is that there must be nude pictures of my soft, fat, pasty white body floating around out there on the internet.
Old Sun 12 July 2009, 23:36
Sorry Doug.....must be because the G and the H are next to each other on the keyboard......and my BIG fingers pressed all of it....I must try and explain my mistakes .....
Hennie this piece is small...about 250 mm across and done with a 3.5mm straight cutter.
The texture was with a 19 mm ballnose.
Old Mon 13 July 2009, 01:13
No big deal. I didn't take offense.
Old Mon 13 July 2009, 08:23
Kobus I managed to find some 3 mm 4 flute endmill cutters at R 95 a pop.
Old Tue 14 July 2009, 00:00
Thanks Hennie, but I can get them for about the same price at a tool centre in Boksburg. I was not impressed with the one I bought...those cheap yellow cutters still giving me miles and miles of cuts
Old Sun 19 July 2009, 12:09
Well I am back from Sabie and this is what I laid my hands on:
The round slab is Camphor ..about 3 years since cut and no movement (cracking) yet.
The ovals are from a pine tree that I helped to cut about 5 years ago in Sabie. I used these to make tables in my Coffee Shop that we had in town.
Anybody interested in these types of things, please contact me and I will see if my contact can cut any more. I know he has a Camphor slice about 1.8 meter in diameter available...at a price.
I was also fortunate to visit the York Plywood plant in town. My friend works in the plant where the plywood is sliced. They have a RAUTE www.raute.com plant. Amazing to see the log go in the one side and on the other side these perfect slices of thin wood emerges.
Old Sun 19 July 2009, 18:53
I'm getting a hernia sitting here looking at those huge chunks of wood. Make sure you show us what you make.
Old Sun 19 July 2009, 22:00
Kobus, are those floor tiles 600x600 [2x2']?
My first impression was that you had toy chairs!
Old Sun 19 July 2009, 23:28
Corrrect 600x600 and that is a normal chair..
Old Mon 20 July 2009, 00:04
The most common reference to camphor trees in South Africa is cinnamomum camphora, from Asia (and a declared weed in Australia)
But it seems the true African timber camphor tree is the Ocotea usambarensis
Old Tue 21 July 2009, 04:51
Another Champhor slab being used at the local Sabie Backpackers. The 'Tree-Doctor' is taking a rest on his table.
Old Sun 26 July 2009, 07:22
MariusL
Just call me: Marius #22
Centurion
Kobus,
Do you know if the York plant makes marine ply? Did the window covers fit OK?
Old Sun 26 July 2009, 08:08
Hi Marius, I bought the flat bar. Must first make the 'wooden frame' before I can put those screens on. The BOSS kept me busy this weekend with flower boxes and tea trays....The Nesting function in V-Carve Pro is MAGIC..
I am working at a sandstone wall. I made a washing room for the wife a while back, but the wall was never painted and finished off. The wall size is 3062 mm wide x 2385 mm high with a door in the middle. Thinking of doing a TEXTURE on the stones, but I will change the cut depth on every other stone to give me the REAL effect.
I don't think they have Marine Ply....they do the waterproof one for construction I know
Old Sun 26 July 2009, 08:40
Maybe something like this...will work on the textures some more
Old Sun 26 July 2009, 10:24
MariusL
Centurion
Kobus,
Yes it is amazing stuff. I don't know why, but I thought that it had some plasma function. I am busy with the headgear of a plasma cutter that will fit in place of the router with very little fuss. So I will be looking for some decent plasma CAM software soon.
Old Mon 27 July 2009, 08:09
Kobus what do you do to get 3d carving on v-carve to be posted on the forum?
Old Mon 27 July 2009, 09:46
After you selected your vectors and tool the program show how it will / should look. Somewhere on that page you can save the image as jpg or bmp..Then you upload the picture like all the others.
Hope this is what you were asking.
Old Mon 27 July 2009, 10:47
Jip!
Old Tue 28 July 2009, 11:19
Hennie I sent you a pm. thanks
Tables of all kinds Kobus_Joubert The Show Room 17 Fri 04 May 2012 09:33
On to parts Ordering - Matthews NC USA qroger Construction started, but not cutting yet 51 Mon 11 October 2010 06:07
