Old Sat 28 March 2009, 21:00
rocky2889
Just call me: Rocky
San Jose
Setting up E-Stop and Limit Switches in Mach3
I try to understand E-stop and limit switches. Yes, I finish wire a small machine and installed limit switches.
Every time the gantry trips the limit switch and it also trigger the E-stop LED on the Mach3, is this normal?
I will check into the wiring tomorrow but if trigger the E-stop that meant it cuts all power to the drives and how can you do auto home?
thanks
Old Sun 29 March 2009, 05:35
My head is a bit muggy after a 13hour flight, but the e-stop should be wired independent of the limit/home switches.
Old Sun 29 March 2009, 21:58
rocky2889
Just call me: Rocky
San Jose
I check out the limit switches today, all the switches are installed independent. I also checkout the Machsupport video on the subject of input and homing/limit.
Old Fri 03 April 2009, 11:27
rocky2889
Just call me: Rocky
San Jose
Ok, after recheck again the wiring and everything is should be. EXCEPT one thing I revere the pin number from X-- and X++ in the setup.
Also I have to lower the home reference speed to 15% of home/limiting setting.
Now everything run as it should but need more tuning.
