Old Sun 22 March 2009, 08:32
Wayne - real impressive!
Old Sun 22 March 2009, 10:26
Rad Racer
Just call me: Wayne #25
Minnesota
Thanks Irfan....appreciate the comment.
Old Sun 22 March 2009, 10:29
Rad Racer
Minnesota
Assembly continues.
Carriage idler wheel is installed. Amazing how tightly the spring assembly holds the carriage to the rails.
Old Sun 22 March 2009, 10:36
Rad Racer
Minnesota
The Z assembly is installed and adjusted. The slide rolls through all 6 wheels very smoothly, can't even feel the transition
I made the z-up and down stops ajustable. Thought a little flexablity might be useful in the future. As you can see the stops are currently set to the middle of the range.
The last photo shows the spindle / router head mounting pins.
Old Sun 22 March 2009, 11:15
The last machine which was finished like this was may be JR's - How I hope my brush would get me that finish
think you are a day away to movement!
Have fun - and the next serial
RGDS
IRfan
Old Sun 22 March 2009, 13:16
gmessler
Just call me: Greg #15
Chicago IL
BEAUTIFUL machine Wayne
Old Sun 22 March 2009, 20:14
Rad Racer
Minnesota
Irfan - I had hoped to have it running today, but found I was short a couple of nuts and bolts so it will have to be tomorrow.
Glad you like the machine Greg, appreciate the comment.
Old Sun 22 March 2009, 20:24
Rad Racer
Minnesota
Almost done.
After almost 30 hours of work this weekend ....my Mechmate is nearly complete, just need a few more nuts and bolts. I believe the electronics will go quick, since the control box is already built and tested.
Old Sun 22 March 2009, 20:43
myozman
Just call me: Mike #16
Demotte,IN
Wayne,
Awesome looking finish, the black really looks good. Take lotsa picture before you get it dusty. Congrats.
Old Mon 23 March 2009, 06:33
...I want to see lot's of pictures of it dusty!
Old Mon 23 March 2009, 12:58
I agree it doesn`t stay clean that long
Old Mon 23 March 2009, 15:47
Rad Racer
Minnesota
No problem, I look forward to getting it dusty......that's the fun part
Old Fri 27 March 2009, 22:17
Rad Racer
Minnesota
Machine wiring is complete
I completed the wiring of the machine today. All that is left is to connect the machine to the control box
I made a special effort to run as much of the wiring through the machine as I could, this should prevent wiring damage once the Mechmate is put into service. I also ran a 1/4" air line to the Y-car, thought I might have a use for it in the future.
The control boxes were ordered from DigiKey....I like them,they fit perfectly. The buttons were removed from some surplus equipment that I aquired a couple of years ago. The start stop engraving was done on my small mill.
Old Sat 28 March 2009, 02:49
Truly impressive machine Wayne, nice attention to detail. I see J.R.'s idea of black rails is catching on, it makes a nice contrast.
I see your motors have shafts out the back, are you going to add encoders or were they just conveniantly available?
You may want to bend the anchor plate for the Z spring up a bit, (or mount it with the short tab on the Y-car and the long end attached to the spring) that spring angle is a bit steep and you will not be getting the optimum pressure of the pinion into the rack. Yor spring is pulling "down" instead of "across".
Old Sat 28 March 2009, 04:45
Nice detail work Wayne. I am a little concerned at the apparent lack of screening on the pushbutton wires?
Old Sat 28 March 2009, 07:59
Rad Racer
Minnesota
Alan,
The motors are new (old stock) that I bought cheap, the shafts serve no purpose on this machine. Good call on the spring bracket, I did not notice the angle until you pointed it out. I will flip the bracket as you suggest. Agree, J.R.'s idea of black rails is great....it adds a nice "factory made" feel to the machine.
Not sure I understand what you mean by screening, do you mean electrical shielding? If so, all the wire used in the machine is shielded (except the EMO). The pushbutton wiring is actually twisted pair w/shielding.
Old Sat 28 March 2009, 08:30
That's fine then Wayne!
(It appeared to me to be discrete wires, and that's why i said "apparent")
Old Sat 28 March 2009, 08:43
Rad Racer
Minnesota
Ok, I see it now.
There are a lot of functions in the control box, that's why there is so many wires. I also wanted to have extra conductors for future functions like air solenoids and lighting.
Old Sat 28 March 2009, 22:21
Rad Racer
Minnesota
TaDa - it's moving.
After completing the controller connections this afternooon....I threw the power switch and made the MechMate move
I still need to clean up a few wires and finish building the router mount.....before it's truly complete.
Here's a couple of short clips of the machine in action.
http://www.youtube.com/watch?v=46mir5E6iNM
http://www.youtube.com/watch?v=zHvUkAbT5Uo
Old Sun 29 March 2009, 05:29
Well done Wayne!
Old Sun 29 March 2009, 11:03
gmessler
Chicago IL
Great job Wayne!
Now start making some dust to cover that overly clean floor
Old Sun 29 March 2009, 22:16
Rad Racer
Minnesota
Thanks Gerald. I appreciate all the effort you put into the design and plans....it's an extremely well designed machine that was a pleasure to build.
Greg, it will be making dust soon....just need to fabricate the router mount. I spend this afternoon playing around with the machine.....tuning and testing. The machine runs super smooth after nulling out the Gecko's
I am currently uploading another YouTube video that simulates the highspeed cutting of 32 holes (bolt-hole pattern) at 300ipm and a triangle at 500ipm. Even at that speed the machine runs very smooth. I will post the link once the load is complete.
Old Sun 29 March 2009, 23:31
Rad Racer
Minnesota
Youtube link to highspeed cutting video (simulated cut)
http://www.youtube.com/watch?v=NOWbhc7-8gw
Old Mon 30 March 2009, 01:07
Nice video, thanks
Old Tue 31 March 2009, 21:47
Rad Racer
Minnesota
The first part has been cut!
I cut my first part night It's an RC dragcar chassis that was to big to be cut on my small mill.....but not a problem for the MechMate
I mounted the laminate router from my other mill.....not a lot of power but it cut well. I will use this router for making smaller items, because I have 1/8",3/16" and 1/4" collets for it, so it's perfect for those small endmills. My larger router will be used when I need big bits and more horsepower.
I have a couple of short videos, I will post the link once they are uploaded.
Old Tue 31 March 2009, 22:22
Nice going Wayne,
Looks like another serial number is coming up.
Old Tue 31 March 2009, 22:56
Rad Racer
Minnesota
Thanks Heath, I hope it passes inspection
Here's the finished chassis....since it's a prototype, I cut it from pressboard. The final version will be cut from composite material.
Old Tue 31 March 2009, 23:49
Nice work Wayne, I hope the non- symmetrical holes are planned and not something loose on your machine
Old Wed 01 April 2009, 01:55
1 st April,April fools number for you Nice going!
Old Wed 01 April 2009, 06:35
Well done Wayne!
(Hennie, his local time was still 31 March)
Wayne's Custom Pendant Rad Racer Human Interface Devices (HID's) 17 Tue 14 December 2010 20:15
Hello from Minnesota! Rook3 Introduce yourself and start planning 13 Mon 17 May 2010 23:52
7 core cable to junction boxes riesvantwisk 60. Wiring & Cable Management 12 Sat 14 November 2009 10:08
Keyboard/pendant solution Art Human Interface Devices (HID's) 7 Fri 19 June 2009 07:41
Gantry & Car Control Boxes, switch info ? kanankeban 70. Control Systems 0 Sat 21 February 2009 12:01
