Old Mon 23 February 2009, 23:29
MariusL
Just call me: Marius #22
Centurion
Sorry for the delay but the MM webserver or ISP blocked my IP from connecting to the forum.
Well here goes, we completed the machine last week and have done some cutting. I now find the biggest problem is to obtain the tools we need to do the cutting jobs that we have. I have a 8mm and a 12mm collet with the bosch router but found out that those are not the popular sizes for tools. I also need longer tools to cut the 3d plugs from foam. I guess this will be an ongoing battle.
The dust collection system works very well, almost to well. It leaves nothing behind.
I opted for a 4:1 reduction on all motors. See pics.
Thanks Gerald your effort made it possible for us to have a good working machine in under two months.
Also thanks to Greg from CncDirect for all his help.
Old Mon 23 February 2009, 23:47
Wow, now you see thats why I dont like Joburg, you guys are just too fast for us laid back Capies... Very nice looking machine, lets have some more details on those reduction drives - they look interesting, I want to add them to my machine as well as I am not happy with the direct drive chatter.
Contact Bosch for either replacement collets or to purchase 1/4" and 1/2" collets, I find I use all 4 sizes (I still want to get the 6mm and 10mm collets, then there is very little that I wont be able to hold in the router)
For the cutters, try Austro, Leitz, Leuco and engineering supplies for milling cutters, Another good source could be Wood Finish Management, they bring in a range of cutters for the machines they sell 011 907 3982 - Trevor Williams
Old Tue 24 February 2009, 00:08
Marius, that's a beauty!
Even your dust hose is a matching colour!
Those belt drives are very interesting, it looks like you got standard flanged bearing unit somewhere . . . . . . (some car engine water pumps are similar . . . old merc. . . )
Old Tue 24 February 2009, 00:50
MariusL
Centurion
Geared motor details
Allan,
I attached the drawings. Take note that the Z axis has a problem. I had to lift the motor plate by 40mm on order for the plate not to snag on the spider plate bolts. I took one of the large spacers and welded a 40x10 flat bar with a hole onto it and therby lifting the motor plate. I also had to extend the rack in order to achieve the correct travel that I wanted.
Old Tue 24 February 2009, 00:53
MariusL
Centurion
Thanks Gerald I am also very chaffed with the colour it looks really good.
I had the flanged bearing housings cut. I attached the details in the previous post.
Old Tue 24 February 2009, 00:54
Lex
Just call me: Johan #56
Empangeni KwaZuluNatal
Geluk met die masjien Maruis!
Good professional looking - enjoy!
Old Tue 24 February 2009, 01:39
Jis maar hy is MOOI!!!!!!! Baie geluk en ek hoop jy maak nou jou miljoene met hom.
Old Tue 24 February 2009, 02:54
MariusL
Centurion
Thanks Kobus, ek hou van die miljoene idee.
Old Tue 24 February 2009, 05:11
kaartman
Just call me: Koning #20
Abu Dhabi
United Arab Emirates
Nice Marius. congratulations on a job welldone
Old Tue 24 February 2009, 06:35
Good Job Marius - especially the belt drives.
where's the video?
Old Tue 24 February 2009, 06:48
Wow, what a nice machine - and petite
The 80/20 Bosch style extrusion for the main beams is very nice feature for the bolt up of the rails.
Do you plan on using the extrusion for "other accessories" mounting or just for the convenience of the build.
I trust you will have a prosperous year with your new machine.
Sean #5
Old Tue 24 February 2009, 07:40
Marius,
Congratulations on Serial #22. A magnificient machine!
The updated Builder's Log is here.
Regards,
John
Old Tue 24 February 2009, 10:53
gmessler
Just call me: Greg #15
Chicago IL
Beautiful job Marius!
How about some detail on your dust foot / collection.
Old Tue 24 February 2009, 12:34
Marius,
Congratulations on #22.
Old Tue 24 February 2009, 15:18
MariusL
Centurion
Thanks to all for wishing me well and thanks for the compliments. Sean I only used the extrusion to give me a very true level to mount the rail onto. No extras will be fitted to them .
Greg, I have attached the dxf file and the sheetcam files. The material must be 25mm of anything that you have. I had a piece of Vesconite and hence the low feed rate. I think nylon or perspex will work fine. I stuck some self adhesive velcro to the edge and made a dust skirt with 4 layers of PVC that are glued on top of each other. I made slits at about 25mm apart but this will depend on the suction that you have available. Notice that there are two sets of mounting holes. The outer set was meant to be mounted on sliding rods in order to be able to lower the foot as close as possible to the job. The inner set is to bolt the foot to the bottom of the router bracket with wing nuts.
I will make avideo as soon as the pressure to perform is has gone off a bit.
Old Tue 24 February 2009, 15:38
MariusL
Centurion
I meant to include these two pic to clarify the reduction assymbly. What is not shown on the drawings is that you must counter sink the bearing flange mounting holes and mount with m6 x 12 CSK cap screws from the front.
Take note of the hand of the motor plates. They only mount one way after you counter sink them. The Z axis plate only fits one way as well.
Old Tue 24 February 2009, 15:59
Marius,
Okay, I want blue dust collection hose. Where does that come from? or did you paint it?
Old Tue 24 February 2009, 19:34
gmessler
Chicago IL
Thanks Marius!
Old Tue 24 February 2009, 23:18
MariusL
Centurion
Greg, just check the sutting depth on the outside pass to make sure that it is 25.5mm deep. I might have changed some things there.
The hose is a standard 100mm hose that was supplied by a local company , Chick Henderson. I have a feeling it should be available eslewhere as well.
Old Wed 25 February 2009, 06:19
Geluk op 22
Old Fri 27 February 2009, 14:00
MariusL
Centurion
I am very impressed with the performance of the machine. I have attached some pic of the first attempts at a 3D mould cut from foam.
I have a small issue with the overhead dust collector tube. It seems to get snagged on it self from time to time. We have to change the sliding mechanisms a bit. Other than that, pure magic.
Old Fri 27 February 2009, 14:10
That's a nice and dusty foam job . . . . a good test for clogging of v-rollers and racks . . . . .
Well, what is your impression about any clogging?
Old Fri 27 February 2009, 14:35
MariusL
Centurion
The racks had no problem at all and there was some deposit on the rails. In my case it might be worse as I am using Ertalite wheels. They are a bit softer that the steel. I am going to fit a small brush on both side of the car and the gantry. Even so it was not enough to cause any concern. The machine had cut from 11h00 this mornig and just stopped while I am writing this, at 22h30.
The dust collector suffered much and might be gone. The dust is very fine and causes the cloth bags to clog up. I might still speak to you about that cyclone soon.
Old Fri 27 February 2009, 22:05
Curious about the life of those Ertalyte wheels - sometimes I wonder if we can dump the wheels and replace them with solid plastic slide blocks, still on the v-rail, (like a lathe bed) . . . . .
Old Sat 28 February 2009, 00:14
MariusL
Centurion
Gerald, So you picked up on the spelling. I sometimes do that. Personally I would not give up on the wheels. The added friction that the slide block give will not be practical especially on larger machines. What I would look at is to increase the contact area. I am looking at designing an extrustion that will give about 10mm contact area on each side.
I am monitoring the Ertalyte wheels closely to see how they hold up. So far not a sign of wear. Also the machine runs very quite so it will be a bonus if they last.
Old Sat 28 February 2009, 00:28
Have you seen this thread: Guards for the V-rollers and oilers for the rails? and the links from there?
Old Sat 28 February 2009, 00:54
MariusL
Centurion
Has anyone made some of those blocks with the felt in them?
Old Sat 28 February 2009, 02:22
I only know of this one in the UK:
. . . . uses standard felt holders from the Hepco wheel supplier.
Old Wed 08 April 2009, 06:10
MariusL
Centurion
Ertalyte wheels
The machine has been working non-stop for many weeks now and the ertalyte wheels dont show any signs of decay yet. They have not yet bedded and I think it might be a good alternative. The machine noise is also very low. Kobus came round the other day and commented on the low noise level so I take it must be a lot better than the metal wheels.
Old Wed 08 April 2009, 07:04
Marius, that is great news on the Ertalyte wheels.
Kobus's machine has direct drive motors, which makes a machine sound quite rough. I guess his comment was based on this aspect. I don't think that steel/plastic wheels will make a big difference on noise, but I may still be proved wrong. :-)
Reduction Drive by belt - a collection of various designs and how to build your own. Mike Richards Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 449 Sat 09 March 2019 18:32
Mike's dust foot myozman 55. Dust Management 2 Mon 30 March 2009 22:07
Dust collector foot Marc Shlaes Dxf Library 7 Sun 27 April 2008 20:18
Dust Collector Foot Doug_Ford 55. Dust Management 34 Fri 04 April 2008 11:01
