Old Tue 07 October 2008, 05:30
I started out about 9 months ago with a 3/4" spoil board. Today because of resurfacing, the spoil board is 1/2". I normally take 1/16" or less during a resurface. The main reason I resurface the spoil board is for better vacuum hold down, the better the surface, the better the hold down, particularly smaller pieces. If it were not for that I could go twice as long without a resurface.
Old Wed 08 October 2008, 18:49
cncb
Just call me: Brian
Connecticut
Er, Brian, JR said: "Next time I resurface the table, I will video."
Re-surfacing of tables does not happen that often.
I know he did, but was hoping he might give in and surface for the sake of a video
Old Tue 21 October 2008, 05:50
Would someone give me some pointers on setting up mach for the laser offsets.
Old Fri 24 October 2008, 07:36
JR
If you don't have the link this should help.
http://www.cnczone.com/forums/showthread.php?t=48752
Old Sun 26 October 2008, 05:43
Thanks Nils, it did help.
Old Sun 26 October 2008, 17:55
Greolt
Just call me: Greg
Victoria
JR you sent me a PM and I did not realise. Sorry. Check your inbox.
Greg
Old Thu 30 October 2008, 19:11
Who is using 'Sheetcam'?
Old Thu 30 October 2008, 22:02
J.R. do you want to do board processing?
Try (Cutlist) also, I have been using it now for 7 years.
Old Fri 31 October 2008, 00:11
JR, we have Sheetcam. We aquired it purely because it placed tabs so easily and Les Newell (the writer of Sheetcam) was willing to give us a special tab shape and a dxf output. We didn't use it to produce G-code as such.
Old Mon 03 November 2008, 19:49
Resurfaced the table today, and as promised here is the video. Before I ran the machine 1000 ipm. This time I decided not to run it at that speed. I am cutting .050" deep, .75 path. Sorry about the picture quality but it's all I got.
http://www.youtube.com/watch?v=EwO_KL1GRww
Old Mon 03 November 2008, 20:39
lunaj76
Just call me: Justin #24
Littleton, (Colorado)
JR,
That is great! Thanks for the motivation.
Old Mon 03 November 2008, 21:09
Now at 1150 ipm ...... Was wondering about the dust extraction getting switched on .....
Old Mon 03 November 2008, 22:51
gmessler
Just call me: Greg #15
Chicago IL
GREAT video J.R.
Old Mon 03 November 2008, 23:13
JR mentioned before that he is using "soft limits" for that surfacing program, and one can see how Mach ramps the speed down before the gantry reaches the end of the table.
The first thing I did with watching that video was to time the "strokes" against my watch and verify the 1150 ipm . . . . it looks right if the table is 8' long. Not that I doubted JR's word, but because we have had some funnies with indicated speed vs true speed. (In Mach3 r1.84 we had our y-axis running at half indicated speed, In ShopBot we had all axes running slower than indicated).
Another thing to remember is that JR is using "big" motors and belt-drives. Can be considered as "non-standard" for the typical MechMate builder.
And then it must also be realised that 1150 ipm is on the limits. For table surfacing, a lost step is not the end of the world (except for hitting the hard stop on the backstroke). Not a recommended speed for general pupose work. But nice to know that Mach can get it there, and that mechanically it is okay without jumping off the rails or pinions jumping out or anything else nasty like that.
Old Tue 04 November 2008, 05:41
cncb
Just call me: Brian
Connecticut
Love the video JR your machine is outstanding. ANd to think most commercial high end machines for the most part cut at or below that speed!
Old Tue 04 November 2008, 06:30
My spoil board is 49" X 97". The jog speed G00 on my machine is 1175 (so I can go faster if I need to). I have soft limits set at G53 X0 X101 and Y0 Y53. The soft limit ramp up and down is 11.5". It was only running 1150 ipm for 6' the rest of the time it was either ramping up or down .
The machine gave no indications at all that it was under the least amount of strain, everything sounded normal, smooth and under control. I don't think it missed any steps at all. Next time I'll check for that.
The dust collector was on, it comes on with G-code/software. I had been working on the pipe system and did not have the MechMate reconnected, human error . I thought the last job (1/8" bit 1/4" material) was a little dusty . After connecting the pipe it did an excellent job even at that speed and volume.
Old Wed 05 November 2008, 15:16
I made a mistake in my last post. The jog speed on my machine is 1375 ipm not 1175 ipm.
Old Wed 05 November 2008, 16:02
Show off.
Old Wed 05 November 2008, 16:57
Heath that will be next time when I surface @ 1375 ipm . Maybe I'll even use a sharp cutter. The one I'm using now is dull from when I cutting under the sound barrier.
Old Wed 05 November 2008, 20:20
JR,
Have you looked into the table surfacing cutters available that have the replaceable carbide inserts? When you get dull, you just turn the cutter to another fresh face or replace it. Whiteside has a couple of different sizes and so do a few others.
Old Thu 06 November 2008, 05:16
Yea I did, they are a little pricey for me right now. They use the carbide cutters like metal lathe tool holders use. I think it's a good idea and in the long run I would come out a lot better. All in time . Thanks for the suggestion.
Old Thu 06 November 2008, 07:00
I wish I could turn another fresh face when I get dull!
Old Sun 09 November 2008, 19:27
Life needs to be convenient . This is why I made changes in the dust foot.
Dust foot 5th gen:
Most of time I had to raise the Z so I could drop the dust foot to do a bit change ..... no more .
The black knob is spring loaded and keeps the front half in place until pulled about 1/4", to replace the front you just push it back in until it clicks .
Dust foot 4th gen here:
http://www.mechmate.com/forums/showt...&postcount=258
Vacuum hold down system here:
http://www.mechmate.com/forums/showt...&postcount=281
I also added another blower to create more vacuum for hold down.
Didn't cut anything yet so I'm not sure how much more it sucks, will report later. 1 was working good so I know 2 is going to be even better .
Thanks Gerald for recommending that I keep all the blowers.
Old Mon 10 November 2008, 06:46
Nice work J.R.,
It's interesting to see the different methods/styles individuals come up with for the dust foot.
At one time, I was all excited about the Z zero device. With the Shuttle Pro and a piece of paper, I can zero the Z in under 20 seconds. It's all personal preference.
Old Mon 10 November 2008, 08:28
Yea, it is interesting to see how many ways there are to accomplish the same objective. I like the way yours works. How did you make the hinge? Are you a skype member?
Old Mon 10 November 2008, 20:10
cncb
Just call me: Brian
Connecticut
Yeah the hinged one reminds me of that truecnc one (do I dare mention that here?) JR great work what material is the foot made out of?
Old Mon 10 November 2008, 20:46
Brian I made it from PVC 1 X 8 fascia board like Lowe's or Home depot sells. It cuts good and it's light weight.
Old Tue 11 November 2008, 07:16
The hinge is a round outer profile with a step cut into it. A hole is drill thru the two half's for a #10 screw.
Yes, I'm a skype member.
I meant to respond last night, but I was playing with some inlay work. This MM is amazing. The detail is phenomenal and the ease with fabricating inlays is almost too easy.
Old Sun 16 November 2008, 08:17
My machine is doing a lot better, it's not making near the number of mistakes it did when it was younger. Several months ago it was making moves that were totally unexplainable. I tried not to place blame. I reasoned that G-code is a new language to it and it will eventually understand it. Well after several months it seems it has pulled itself together and is acting much more responsible, remarkably fewer mistakes. I think it just needed some time to sort things out, or perhaps ... it ... has ... finally ... learned ... G-code.
Old Sun 16 November 2008, 12:36
It is amazing how these machines learn by themselves as times go by...
JR's rail grinding skate in a Lasered & Bent format for 4.5" grinders Gerald D Rails & Rollers 198 Mon 13 April 2015 20:59
Add one more CNC addict - North Carolina rodom Introduce yourself and start planning 0 Tue 01 December 2009 06:54
She makes dusty MOVES! - North Carolina, USA Jeffn11 Construction started, but not cutting yet 23 Sat 01 August 2009 20:36
Plasma burner started - Albemarle, North Carolina subman Construction started, but not cutting yet 8 Sat 27 September 2008 19:25
One more MechMate starting - North Carolina, USA Bernhard Construction started, but not cutting yet 5 Fri 28 December 2007 16:11
