Old Fri 16 March 2007, 14:24
John
Pls check here for stepper motor
www.kelinginc.net
Old Fri 16 March 2007, 14:50
John, which of your stepper motors do you recommend for the MechMate?
Old Fri 16 March 2007, 20:13
Jay Waters
Also, would you ever consider putting a recommended Mechmate package together? ie- steppers/servos, drivers, power supply, etc. Just food for thought....
Old Fri 16 March 2007, 20:53
bugmenot dillbert
I've already asked...
I was recommended the http://www.kelinginc.net/KL34H295-43-8B.pdf, it has the same holding torque as the vextras in unipolar. And for drivers, surprise surprise, geckos...
Old Sat 17 March 2007, 12:08
Jay Waters
Glad to know bugmenot, I'll probably stick with the Vextras anyhow. I feel more comfortable going with something that's already been out there and working.
Old Thu 11 October 2007, 10:09
Goin to order 3pcs KL34H280_60_4A for X and Y and KL34H260-60-4A for Z on the mechmate. This one's gonna be a true mechmate not the one with servos. but with steppers and gecko's 203v and a break out board from CandCNC.com
What say all!
Old Fri 24 October 2008, 20:47
Conrado_Navarro
Just call me: CONRADO NAVARRO #55
OBREGON
Mexico
Send a message via MSN to Conrado_Navarro Send a message via Yahoo to Conrado_Navarro
Hi :
I dont know if is correct to ask in this post
Please correct me if Im Wrong
Im planning to use these package (from http://kelinginc.net/CNCNEMA34Package.html) for the MECHMATE, using the steppers direct to the rail
I will apreciatte any coments
2: NEMA 34 Steppper Motors 4 Axis CNC Kit:
A: 4 PCS KL-8078 80V, 7.8A Driver
B: 4 PCS EMA 34-1200 oz-in Stepper Motors
C: 1 PCS KL-7020, 72V/ 20A,Unregulated Power Supply
D:1 PCS C10 Breakout board, E-Stop or Limit Switch can be wired
Old Fri 24 October 2008, 23:52
you should be ok - getting a package will save you lot of headache.
Old Sat 25 October 2008, 00:19
Conrado, who will give you support if it does not work?
Old Sat 25 October 2008, 07:07
Conrado,
Those are really large stepper motors. Large stepper motors have lots of resonance, meaning that they run rough (hard to tune). Four motors @ 7.8A = 31.2A, so the 20A power supply will not fully meet your needs.
Most CNC router operators prefer a geared (mechanical or belt-driven gearbox/transmission) to reduce the amount of "chatter". I've used both a 3:1 belt-drive and a 7.2:1 mechanical gearbox on my CNC router. Both are vastly superior to running a 1:1 (non-geared) stepper.
If I were you, I would look at a more moderate sized stepper motor that produces between 400 and 600 oz*in holding torque. For the fastest response, pick a motor with a low inductance rating. 1.5mH to 3mH motors are better than motors with a higher inductance rating. Motors with a 1.5mH rating would require a power supply with 40V maximum. (32 X SQRT(inductance)) = MAXIMUM voltage. I would also consider using Gecko stepper drivers (G203v). Finally, if the motors that you select aren't available with a gearbox, I would absolutely build a belt-drive transmission (3:1 or 3.6:1).
Your costs might be about 20% higher for the steppers and the stepper drivers, but you would have something that others have used successfully.
Old Sat 25 October 2008, 11:00
Conrado_Navarro
OBREGON
Mexico
Gerald:
That why I asked for opinions, I`m new to this, but I`m sure that this is the right forum, for taking this great adventure
Mike :
Yeah I saw that answer comig, I read it about it in this forum.
do you know any package like this, that meet your recomendations
or a detailed list to make the combo, with information of the stores.?
I look for it, and saw only recomendation for parts, not the all combo.
may be i need to look fort it harder
Old Sat 25 October 2008, 11:27
Conrad,
You can get all the items you need from just a few suppliers.
Gecko G203V Stepper Drivers
order from www.geckodrive.com Very good company that stands behind their products.
Oriental Motor PK296a2a-sg7.2 Geared stepper motors
order from oriental motor direct www.orientalmotor.com Great stepper motors
Power Supply parts. Try www.partsexpress.com, they have all the transformers,
capacitors and bridges you will need to do the power supply.
PMDX122 breakout board Order from www.pmdx.com Great guys fast turnaround.
I hope this helps a little.?
Old Sat 25 October 2008, 11:36
Conrado_Navarro
OBREGON
Mexico
not help a little
Help a lot!!!
Thanks guys for your support!!!
Old Sat 25 October 2008, 20:12
Conrado,
Also start a personal thread and then you can post questions related to your build there and we can add posts there when you have other specific questions. Like power supply voltages and gearing and .....
Old Mon 27 October 2008, 11:39
Conrado_Navarro
OBREGON
Mexico
Ok
IŽll Do That
