Thread Tools |
Home Supply Requirements
I have an electrician coming over Friday to do some work in my fuse box.
How many lines should I run to my Control box/ Spindle/ Computer? I know this was said before, but I can not find it. ![]() Also, recommended Amps per line. |
I don't know what the power requirements are for the spindle, but for the rest I would have one dedicated line for the dust system ( 20 A), one dedicated line for the power supply ( given a choice I would make that one a 220V line ) and a 15 Amp for the computer. If he is going to run new wires anyway, then the cost to run 20 Amp through out over 15 Amp is not much.
Dave |
Thats what I was wanting to know.
![]() Thanks Joe |
Joe,
Yeah 20 amp circuits for a garage are great, you can put in dual format plugs (15 and 20 amp capable) and plug in whatever you want. The other thing is run a 3 wire and then you can split it off to 2 20 amp plugs at the end and use a double breaker (or fuse) in the box. Only a little more expensive but give you an extra circuit at the end. This is the way I wired my garage and it works great. This technique only works for the 120V circuits. |
