Old Sun 10 August 2008, 02:16
No, it is a De Walt Last much longer! I try to keep the el cheepo`s on display for affirmative shopping purposes,You know what I mean. I have a Bosch for the bevel grinding on my laser cut gadget.Reason why I made the funny wooden block is that my angle iron is 60 x 60 and you have experiance in using the grinding skate ,hight is a problem and I wasnt prepaired to pay more for other angle iron.
Would like to do some more but I am baby sitting today.
Old Sun 10 August 2008, 03:36
Ok, one more thing, Now that I see your Y-Car with the cable chain bracket....make sure you either have a halfnut on the bottom, or countersink it from the bottom and put the nut on the top. In my build the nut on the bottom caught on the nut from the V-Wheel if I remember correctly..
Old Mon 11 August 2008, 13:54
Did some more cutting on the y-rails (second one ).It is not such a bad job,dirty yes!I did manage to cut both rails down from one side. wil post pic`s tomorrow,will try and do the x-rails also.
Old Tue 12 August 2008, 09:34
rails
Pic 1 shows what was left of the disk for the back rail did not even finished the disk only used that one disk.
pic2 &3 shows rails back to back cut from one side
Old Sat 16 August 2008, 02:19
Grinding Of 45 Deg Angle
This is what I came up with tried it and it worked.used the same flat surface as what I used to cut the rails down.I did the one side 60 mm wide then moved to the other 60 mm side I then losened the one rail finished the other side of the first rail.I am quite impressed with the way the rails came out with considering that I did use a verry low tech way of doing it.
Old Sat 16 August 2008, 03:11
I think the big lesson out of Hennie's (and Alan's) methods are to screw the rails to a "reference" board.
Mooi gedoen jong seun!
Old Sat 16 August 2008, 03:40
Dankie oom!
Old Sat 16 August 2008, 03:49
rails after grinding
Rail done on both sides.Note to Geralds remark make sure that the table or surface that the grinding is to be done on is level , flat , straight.
Old Sat 16 August 2008, 14:09
Mooi so, jy kom aan, I still have to do my x-rails, have you done all the rails?
Old Sun 17 August 2008, 01:32
No, still have to do them this week.
Old Sun 17 August 2008, 03:08
Nice going....it's time you finish up and start cutting, I am sure we can exchange cutting files one of these day's.
Old Wed 27 August 2008, 00:25
Gerald on drawing m1 20 220 ( bearing support base)
can one use 16 mm rod as supplied and then dril the hole in the centre rather then using 20 mm?
Old Wed 27 August 2008, 01:00
That would be okay if you welded it to the spider, to give it a firm footing.
Old Wed 27 August 2008, 02:35
Johan I will cut some for you over the weekend.I have made myne according to the drawing.
Old Wed 27 August 2008, 05:53
Lex
Just call me: Johan #56
Empangeni KwaZuluNatal
Thanks Boet! I will send you my electrical diagram soon, as promised. Bit busy here at work. I am in the process of adding the last finishing touches.
Old Fri 12 September 2008, 16:32
Played with the motors tonight getting the kitchen/study table project together.PLayed with mach inputs & outputs and got to a stage where I need to look at the wires coming out of the motors 8 wires fine,next opened the Fulling pdf file and starting to sort it out but for some reason some "poepol" in the east changed the colours of the wires.can someone direct me to a thread or advise me how to test so I can wire it up.?(please).Only colours that does mach to make a coil is black & white.
Old Fri 12 September 2008, 21:38
Hennie, what wire colours are coming out of your motor? Photo?
What are the markings on the motor? At minimum: model number. At best: small wiring diagram.
What does your supplier have to say about it?
Edited to add:
Are you saying that your multimeter only finds one coil? The other 6 wires must make 3 more identical coils.
This 7MB pdf from Fulling, updated Jan 2007, shows a couple of the diagrams they use. I couldn't spot your ST86ST125 3508 AG3 in there, but your colours may match of of the other models?
Old Fri 12 September 2008, 22:09
Okay, your motor is on page 31, but the wiring diagram is not shown for that model?
Old Fri 12 September 2008, 22:33
Gerald I mailed you the pdf and I presume that the black and white makes a coil .I will check it later this morning.There is one diagram of an 8 wire connection.
Old Sat 13 September 2008, 00:10
Ok, managed to get the coils right for every solid colour there is a white wire with the corresponding colour on it. Now only to figure out which coils go with each other .
Does anybody have the colour codes for resistors ( colour rings around the resistors)had it written down many moons ago .LIke to sharpen the knife in the drawer
Old Sat 13 September 2008, 00:37
Hennie, I havn't got any mail from you yet. I think the diagram on page 29 of the PDF linked above will apply for you:
blue/white
blue
red/white
red
..................................green/white_____green.............................. black/white_____black
Don't trust the colours on the resistors - only trust what a multimeter tells you. Many people (myself included) have gotten those colours wrong for the only 10 minutes in the project when you need to pick the value for the drives. Not worth scrambling the old brain cells for an hour to shorten those 10 minutes
What is your power supply voltage? That is going to decide the 8 wires and the resistor.
Old Sat 13 September 2008, 01:59
Problem !
black/black white
pink / pink white
orange/orange white
yellow/yellow white
not the same colour wires as on the diagram.
42 volts
Old Sat 13 September 2008, 02:42
Are you sure you aren't a bit colour blind? Get a second opinion from the boss
Do you know anyone else using these motors?
Old Sat 13 September 2008, 03:57
Would you ask someone who dyes their hair what colour it is
Will post pic`s of the motors later.
Old Sat 13 September 2008, 05:24
That's the person you would ask. they can see the difference in the smallest amount of shade change, not to mention a completely different color.
Old Sat 13 September 2008, 07:22
...but the heck we receive from the boss if we don't notice their color change when they come home from the salon!
Old Sat 13 September 2008, 11:57
If Hennie is like me, he was forced to buy a bag with several hundred resistors in it. I used the color codes to identify the likely suspects and then verified them with a multimeter. Here is a link:
http://wiki.xtronics.com/index.php/Resistor_Codes
Old Sat 13 September 2008, 12:25
Thanks Doug!
For the okes in the east red suddenly became pink and the BOSS agree I am not colour blind.Open the purse and see the colours vanish for that colour change.at the Hair Dresser.
Old Sat 13 September 2008, 12:35
Have anybody Thought about convertng the MM into a foam cutter for making cornices?
Had sleapless nights about this, watch this space it is going to get interresting.what I did thought of is keep the main table 1 meter long,gantry stays the same length as what we are using for our 1830 mm wide board and have the z-axis fixed with steel wires running from one side to the other.
a 2 axis machine.
Old Sun 14 September 2008, 04:00
Fulling motors with 3:1 gearbox For peaple thats colour blind.
Gerald managed to figure out what goes where ( look at the colour wires )
Another Mechmate in Progress - Atlanta GA Jay Waters Construction started, but not cutting yet 33 Fri 22 April 2011 08:35
cnc wood lathe javeria Miscellaneous / General / Whatever / Catchall 5 Fri 11 March 2011 09:12
Starting to make progress peter__jackson Construction started, but not cutting yet 7 Wed 27 October 2010 11:28
Lathe cabinet lumberjack_jeff The Show Room 2 Sun 26 September 2010 21:41
Website/ Forum for homemade/conversion cnc lathe? jgc2521 Miscellaneous / General / Whatever / Catchall 1 Sun 28 February 2010 01:31
