Old Fri 25 November 2005, 09:20
Drawing problems and revisions required, considered and intended . . . . .
This thread is the only list of changes needed to the drawings. When I sit down to do drawing revisions, this is the sole source of input.
I have each drawing sheet in a separate file, and the file names are my gospel. Sometimes I do loose concentration and forget to fix the title blocks, etc.
But let me know what else appears odd and I'll either fix or explain it.
This thread was archived 28 June 2008 link At that point all the changes were included in a new drawing set, and this thread was reset for comments against the latest drawing set.
Old Tue 01 July 2008, 01:52
Had a quick look through the drawings and they are impressive as usual, I like all the "refinements".
The only error I could find was the last page of Part1 (10 20 450 WA) needs to be deleted - wrong section and redundant.
The Y car assembly drawings (part 3, pg 1 & 2) does not show the added tab for the switch box.
minor points I know, but the rest of it is so good...
Old Tue 01 July 2008, 02:28
Those are major points! - I cringed when I spotted them last night
Another snag is that the page sequence is incorrect in some places. (The index shows the correct sequence). It is a schlep to combine 153 .pdf files into 5 .pdf files and still get them in the right sequence. Especially when you have a cold, the PC is new and the pdfcombine program wasn't installed yet.
I'll wait for some more reports before I fix those glitches.
Old Tue 01 July 2008, 02:35
PS. The lip not showing on the assembly drawing is not a big one for me. At one stage I had it not showing on the bending drawing, and your comment made me think I had done it again!
For most of the revisions I don't reflect the changes all the way through to the assembly level. I only change the higher levels when there is a real risk that this thread will be filled up.
Old Wed 02 July 2008, 23:30
1010247DA - the 46.4 dimension needs changing to 46 mm (not critical to one decimal)
Old Wed 02 July 2008, 23:42
1010302DA & 1010123DA - That hole spacing pitch of 350 to 400 [14-16"] is maybe a bit too wide. Checked this week that our existing two tables are just under 300mm [12"] spacing. There isn't much point in making this spacing closer than the spread between the cross supports indicated at the top of 1010123DA, and there I am comfortable with the 300-400 [14-16"] interval.
The spacing very much depends on the strength of the table surface, and the resistance to the bolt heads tearing out,.....and how you are going to abuse the table by trying to pull curved stuff down flat.
The outer perimeter of our tables take strain with the G-clamping we do. Maybe we should only increase the number of screws on the perimeter?
Old Thu 03 July 2008, 22:47
1040432D: The approximate hole spacing of 132[5.2"] is incorrect. Actually quite a bit wider. Nearer to 139 for those with 100mm slide plates and 5.54" for those with 4" slide plates. The lasered "wings" near the middle rollers need spreading in next revision.
Old Fri 04 July 2008, 00:02
M120220T: Remove the big bevel from the part . . . . the seals of the Superior V-rollers are slightly recessed and there is no chance that this part will rub against the seal. The bevel is not required.
Old Sat 05 July 2008, 09:03
Change sequence of spider processes to reflect method in thread:
http://www.mechmate.com/forums/showthread.php?t=878
Old Fri 01 August 2008, 22:09
William McGuire
Just call me: Bill
Weiser, Idaho
Gerald...
I may have found an error in drawing 10 10 247. You have listed [0.25"] inch rack under your rail drawing. I found it while looking for the distance between the 0.50 inch rack and the mail beam...
Old Fri 01 August 2008, 22:40
Bill, drawing 10 10 247 only shows a Drilling process, nothing more. It is indicated by the D in the "Process" block on bottom right. Thus you must read any information on that sheet as it relates to Drilling. . . .
I think the above area is where you got the impression of "1/4 rack". My poor choice of words . . .
What I should have said there, is that the dimension for the drilling, when using 1/2" rack, is 1/4" from the edge.
For the 15mm rack, the dimension is 7.5mm.
Old Fri 01 August 2008, 22:47
Originally Posted by William McGuire View Post
. . . while looking for the distance between the 0.50 inch rack and the rail beam...
The racks are flush with the outside of the rail, to get the pinion gears as far onto the motor/gearbox shafts as possible.
The inch rack guys could have a space of around 1/4" between the rack and the beams. . . . . depends how straight your beams are
Old Sat 02 August 2008, 08:51
William McGuire
Just call me: Bill
Weiser, Idaho
Thanks much, Gerald...
Old Sat 02 August 2008, 11:33
No need to blush Bill. I need to do more to make the drawings clearer, and inputs like yours tells me where the potential problems are. Thanks.
Old Sun 10 August 2008, 02:36
Ok, one more thing, Now that I see your Y-Car with the cable chain bracket....make sure you either have a halfnut on the bottom, or countersink it from the bottom and put the nut on the top. In my build the nut on the bottom caught on the nut from the V-Wheel if I remember correctly..
Old Sun 10 August 2008, 05:16
Maybe I need to move that screw hole a bit . . . .
Old Thu 14 August 2008, 07:43
In the last set of profiles and bends, 1020456 is supplied as revA for cutting (dxf) but the bend pdf lists the drawing as a rev B. Should the cut file be a rev B?
Old Thu 14 August 2008, 09:03
10 20 456 P A is the latest revision of the Profile cut drawing for that part
10 20 456 B B is the latest revision of the Bend drawing for that part
The reason for the Bend drawing having a higher revision than the Profile drawing is stated at the top of the title block: "Corrected error caused by scale view". That error only appeared on the Bend drawing - there was no need to make any changes to the Profile drawing for that part.
Old Thu 14 August 2008, 10:13
Sorry for the confusion, I thought the revs would track.
Old Thu 14 August 2008, 10:23
It is plain coincidence that most of the MM drawings have the revs of the P and B drawings tracking each other. The rev only gets changed when the older drawing can cause a mistake. For example, if a hole is added to a profile drawing, there is normally no need to formally revise the bend drawing - in my "day job" I most often see the P drawings with higher revisions than the B drawings.
Old Fri 22 August 2008, 13:15
A small thing, in the options schedule, part 10 40 434, the description says x motor plate lug. Shouldnt this read Z Motor plate lug? In the actual drawings, it is only described as Motor Plate Lug.
Old Sat 23 August 2008, 00:23
Old Tue 16 September 2008, 17:00
PEU
Just call me: Pablo
Buenos Aires
Minor details in drawings
While converting bends DXF's (June30/2008 set) to Solidworks I found these small details, not sure if they are errors or are intended to be this way, just in case here they go:
in 10.60.315 sheet tickness is specified at 4mm but in inches it says 3/16". IMHO 3/16" is closer to 5mm (IE. in 10.40.432 3/16" is specified as 5mm)
this also happens in 1030455PB
in 10.4.387 the hole in the bend and the bending mark are included in the dimensions layer, so if you remove this layer for any reason these features are lost.
There are some outlines that needed minor corrections, for example open outlines, not sure if this is an importing problem or with the native files.
So far these are the only details I found
Pablo
Old Wed 26 November 2008, 05:02
hutchcj
Just call me: Colin
Sydney
Converting DXF to Solidworks
1030455PB.DXF - Open contour, on small step, upper right (on inside edge). Horizontal needs extending.
1040432PF.DXF - Contours overlap, both sides, lower squigly side cuts.
M610116PB.DXF - Open contour, very bottom line on the right, just where there is a small fillet.
These are small errors, less that 0.5mm
If you need more info (or a picture) let me know.
Old Wed 26 November 2008, 05:19
Thanks hutchcj
I don't find the first one (my AutoCad draws hatch or boundary happily)
Second one has 0.56mm overlaps
Last one has 0.14 gap
Old Thu 18 December 2008, 16:06
@all,
I am preparing the sheets and a USB stick for laser cutting my parts.
According to the DXF the spinder plate (10 40 432 ) should be 5mm thick. Yet the XLS document suggested a preferred thickness of 4mm. Which one is right?
Looking at the XLS part 10 30 455 also suggests 4mm, but part 10 20 451/452 suggest 5mm so I couldn't make a decision yet... Reading the above thread suggest 4mm is bare minimum, so best is 5mm steel. Would that be correct and teh XLS is wrong??
Regards,
Ries van Twisk
Old Thu 18 December 2008, 18:52
Ries,
I think the excel sheet did NOT get updated with the last updates to the plans. I would go with the 5mm as called for in the current drawing set.
Old Thu 18 December 2008, 19:27
5mm is better. I must change the xls sheet.
Old Tue 23 December 2008, 13:01
From a PM received:
Hi, on drawings 1030422BD and 1030422PD the higher drawing number must be 1030's not 1020's.
Old Thu 08 January 2009, 12:45
jeffa
Just call me: Jeff
Iowa
We're getting close to welding up the gantry and we have assembled (bolted) correctly (I think) the Near Gantry End Sub-weldment and the Far Gantry End Sub-weldment. However, drawings 10 20 451WA and 10 20 452WA have us scratching our heads just a little. Is it possible that the Right side views of these parts in both drawings are actually the Left side views placed on the right side of the Front view? If this is the case, we've got everything placed correctly and we can weld away, if not, we've got some more head scratching to do.
Thanks for your help,
Jeff and Erick
Jeff and Erick, you spotted some errors there. ....452W's right view can only be correct if it is a section cut. (Similar on 400W). Looking from middle out.
