#31
Another positive is the speed control. Having the ability to match bit rotational speed to the material being cut is nice. Sounds like your having fun. |
#32
Greg,
I am having fun and I think I will be having more fun once I get it all assembled. |
#33
At last! A volunteer! I am fairly confident it will work very well. Where are you sourcing the aluminum angle with the "sharp" inside corner?
#34
The local steel supplier has Architectural Aluminum but it was not the right size. Sean thinks he has a source that will have what I will need. The V Rail with the holes drilled is not cheap so I will be drilling the holes.
I just didn't want to deal with the dust. It will take about a week for the supplier to ship the rails. I will be taking lots of pictures so I will post them and my progress. Sean is my local expert. I am happy to see if this works. Last edited by sailfl; Sat 12 July 2008 at 15:41.. |
#35
Funny,
"at last a volunteer". I feel guilty not being the one who built the first one since I was the bloke who pressured you into a redesign in the first place. But that darn skate challenge from you and JR made me hop on that band wagon last year. This build should be pretty easy. I have a model MM to work from about 10 feet away while I am helping him build his table. Fun to be had next week in the shop. |
#36
I am greatful that there is room in Sean's shop to build my machine and that he is taking the time to do this. I think part of the reason he is doing this is because it is so much fun.
#37
Sure is better than the day job
#38
i guest i will need some help soon any one want to drive a bit south to miami lol i sure will need help i am alon here no MM 10' way
#39
Manny,
Sean is moving his shop and machine ( I think because it will be further for me to drive) but for now it is only a 15 min drive for me. Currently, I need Sean's help, other owners and builders and the information contained on this site. I hope that when I am done, I will be able to pass on some of what I have learned. I will be happy to help. It would be great if you could make a trip to Orlando and see Sean's MM. |
#40
i send him a pm but no answer i don't mynd driving to get a hands on idea and be able to get tips
#41
Manny,
Sean will respond. Let me know when you are coming and I will plan on being there also if I am not already there. If it is this next week, I will be there a lot working on my table. |
#42
cool let me see how my weeck looks like and ill let you know it showl be a fund drive
#43
Steel arrived and steel was cut. Used Sean's Delta 14" chop cutter. Worked great. Cut all the table channel cross bearers and parts for the side of the table.
#44
Yeepie,
Laser parts to arrive on Wed. |
#45
Progress continues.
All the cross bearers are drilled and ready for taping and paint. The X axis beams have been cut to size and await drilling. The laser parts have been upacked and the 4 items have been counter sinked. VWheels arrived today along with some other parts. |
#46
Pictures Please.
#47
Nils sounds like a happy man!
#48
Nils is having fun and Sean is also. Laser parts from Joe. Last edited by sailfl; Fri 18 July 2008 at 00:53.. |
#49
Nah, Sean only posed for the picture - his wife would kill him if he was really working steel in a white shirt.
#50
...and I had no idea Nils took this picture. See how messy the warehouse is, we're in the middle of moving to a bigger facility. The only thing left at this location is finance, me and a Mechmate.
#51
Table starting to come together. I have also received the ground rails and they are sweet. Picture of rails tomorrow.
#52
Today, I drilled preholes in the Superior Bearing Guide Wheel Track. I decided not to buy the predrilled ones.
#53
Looking good!
#54
Nils, how straight are those rails when you lay them side to side? It might be interesting to you that during their production, the last step after hardening, is to bend them straight. They are not machined straight.
Are you keeping to the 3" hole spacing? Or have you stretched them a little? |
#55
I will check the straightness but while working on them they seemed very straight. We talked about spreading the holes further apart but decided that it would be better to follow the manufacturer's spec so the holes are 3" apart. But we are thinking of taping the holes. It will be interesting to see what operating difference these rails make over grinding the rails. I will keep you posted. |
#56
Fresh rack out of the packing tube.
#57
Nils,
What did the rail end up costing you for the whole machine? Are you doing the Z slide as well, like Ed did? Seems like you are steaming along nicely! ![]() |
#58
Things are moving along at a nice clip and Yes, I am doing all X, Y and Z with the V-Rails. If you are going to do it, might as well do them all.
I sent you a PM with the price. |
#59
Update....
Took the Gantry tube to have them gaged cut so they would be the same length. Will lay the holes out and drill and tape them next. I have Z Slide Plate and the Slide Tube. They have been machined and taped. I also drilled and taped the rails. I have included a test assembly of the Z. Enjoy. |
#60
Great Stuff, you must be on a natural high with this project coming along !
![]() ![]() Keep those nice pics coming, it is motivating. Robert ![]() |
| Z-slide Limit Stops | Gerald_D | 40. Z-Slide | 3 | Fri 23 January 2015 14:45 |
| New Z-Slide or Prefab Rail Ideas! | carcan | 40. Z-Slide | 17 | Thu 06 June 2013 01:08 |
| Winter season in Bucharest !!! | gixi | Miscellaneous / General / Whatever / Catchall | 18 | Thu 11 February 2010 08:26 |
| Z-Slide - width allowance for V-Cap rails on edges of slide plate | YRD | 40. Z-Slide | 5 | Tue 11 November 2008 12:20 |
| Hello Everyone - Lake Park, MN | r56554 | Introduce yourself and start planning | 1 | Mon 25 February 2008 03:17 |
