#301
With something that nice, was it cheaper than purchasing the geared steppers from OM? |
#302
It is beeeeyooootiiiiiifuuuul!
Do you have the N.C.I.A.M.T.S.F. engraved into the plate? ![]() |
#303
Impressed by the parts quality, nice job. ... i'm waiting for your impression (quality of cut improvement) after first trials. Maybe, could we hope a PDF plan set to try the same ...
Bye, Pierre. Last edited by grandpi; Tue 06 May 2008 at 05:08.. |
#304
Thanks everyone. We designed it so it works with the existing motor mounts therefore it works on all axis without any modifications. The picture is for Sean, it's a vertical mill attachment for my atlas lathe.
#305
JR and Marc,
Very nice. Look forward to hearing how it works. Now we know who to contact for parts. |
#306
Nice to have all the tools AND knowledge. Nice job.
#307
Okay JR, what title do you want for this thread? .......
"Done! Setting up dust foot & table top" ........seems to be in the distant past already. ![]() PS. like the inclinometer indexer! |
#308
You must be proud of this result. What gears specs did you guys use ?
Congratulation to you & Marc, verrryyy nice work. |
#309
jr. I thought you might have that attachment. I knew you had a lathe, but never heard mention of the mill. Bravo. By the way, I have the same wixey incline gauge, I couldn't live without now that I own it.
#310
JR,
Great photos, cannot wait to hear how the gearing improves your cutting. Keep us informed and some more photos. ![]() |
#311
JR and Marc,
Y'all are amazing. That is some truly beautiful work. |
#312
Truly Professional work. Even OM guys will envy
#314
J.R. and Marc,
Very impressive design and fabrication work. |
#315
Thanks guys! I can tell you this...
When I look at the work and 15 odd cuts in MDF to get it how we like it, I am more and more impressed with Gerald getting this whole machine designed. Regarding the question of cheaper than buying geared motors... Hmmm. Probably not on a one-off basis. But, JR had the motors and wanted to use them. In the end, this might work out better because of the ability to adjust resolution to suit one's needs by varying the ratios possible in the belt drive. I am certainly no expert and until they have been cutting for a while, it is too soon to tell. Even though we designed it, Gerald is much more qualified to comment. It still is simply toooo cool to draw something and then see the Mechmate cut it EXACTLY. I am sure that I will eventually get used to it but right now it is very exciting. Thanks again Gerald! |
#316
Fabulous work folks! culmination of creativity engineering and beauty combined !
RGDS Irfan |
#317
Robert,
The drive pulley is 15 tooth and the driven pulley is 45. They came from SDP-SI as did the belts. The belt width is .375 and the pitch of the components is .200. If you need anything else, just ask. |
#318
Marc or JR,
I am interested as well as Gerald, as to the engraving on the motor plate in the picture that Gerald has posted. What is that? ![]() |
#319
Marc,
Can you put in the drawing for these with bearing mounts and the bearings you used on these. Think G can make this a standard option for people who want to go on with a reduction belt drive. also the SDP-SI part numbers. Or is it very soon to ask for? RGDS IRfan |
#320
I love the enthusiasm here. (Gerald, I now feel a tiny, tiny bit of what motivates you.) However, before we publish anything, let us try it out first. It might look really nice and yet not perform at all. Hopefully not!
#321
Aaa, It’s humor not for all but with a smile intended… ![]() Marc, thanks a lot for these infos. Will help others & me a lot. I to have the firm intension making my own reductions, looks better, fun & more versatile than those enclosed expensive gearboxes! You & JR, Fabio & others have convince me it’s the way to go ! Great forum & place to be. Looking forward to share at my turn some of my future built ! ![]() I may take you up on that latter, never purchase for this need/purpose, any parts No. handy so I can compare ? Seen so many choices & option on the SDP/SI online store !!! Merci, Robert ![]() |
#322
Oh... By the way. The engraving says www.cnc-nc.com. We built the website in preparation of actually finding ways to make money with this CNC thing. As we get further (and test the belt drives) we might put completed transmissions for sale there for those that don't feel up to cutting 1/2" aluminum on their machines.
We will post the DXFs for personal use for all you adventurous folk as soon as we know they are right. Marc and J.R. |
#323
May cnc-nc grow from strength to strength!
#324
Thanks Gerald.
And for all those who have, in the past, asked about cutting aluminum. Even a direct drive machine will do it if you are patient!. As soon as the transmissions are installed, we will cut a second set and surely report on the difference. Oh and for David. I obviously like the collaboration thing. We each bring different strengths to the party. That is what makes this so great! I couldn't do any of this without you guys and I am sincerely grateful. I love pictures. Last edited by Marc Shlaes; Wed 07 May 2008 at 06:48.. |
#325
Marc and J.R.,
Best of luck with CNC-NC !! I'm sure I'll be using your services in the future. Don't have to worry about the quality with that group. ![]() |
#326
Want to wish JR a Happy Birthday! one week early, because I won't be here next week. One year ago you started this thread with:
I'll say an amen to that and a happy birthday
![]() Paul |
#328
Happy Birthday JR.
I hope all our machines turn out half as nice as yours! ![]() |
#329
The transmissions work great it makes all the difference in the world, in speed and the way it cuts. Here they are on the MechMate.
#330
JR,
Stunning achievement. It would appear that you used the MM to machine the aluminum gearbox plates. Just another point to prove to all the others that aluminum is just fine on the MM. I have had no problems cutting 3/8" plate with the correct bits and feed rates. You will notice the biggest changes in cut quality on plastic. Keep up the great work.... Sean |
| JR's rail grinding skate in a Lasered & Bent format for 4.5" grinders | Gerald D | Rails & Rollers | 198 | Mon 13 April 2015 20:59 |
| Add one more CNC addict - North Carolina | rodom | Introduce yourself and start planning | 0 | Tue 01 December 2009 06:54 |
| She makes dusty MOVES! - North Carolina, USA | Jeffn11 | Construction started, but not cutting yet | 23 | Sat 01 August 2009 20:36 |
| Plasma burner started - Albemarle, North Carolina | subman | Construction started, but not cutting yet | 8 | Sat 27 September 2008 19:25 |
| One more MechMate starting - North Carolina, USA | Bernhard | Construction started, but not cutting yet | 5 | Fri 28 December 2007 16:11 |
