Old Sat 03 May 2008, 20:18
Kalimero
Any wires that are not being used should be individually insulated and secured against accidental contact.
Old Sat 03 May 2008, 20:26
Kalimero,
Those extra wires were intended for other functions that have not been completely worked out yet.
Old Mon 05 May 2008, 07:48
Kalimero,
As Heath wrote, you need to individually tape the ends of each unused wire (or use a wire nut on each unused wire) to keep them from shorting together.
An eight lead motor can be used in Half-Coil mode when you don't have adequate Amps available from the power supply, otherwise, I would suggest that you use all eight leads to take full advantage of the motor. The wiring diagram that Gerald posted at the top of this thread shows the correct method to use to connect an eight wire motor.
Old Tue 06 May 2008, 14:49
kalimero
Just call me: kalimero
buffalo
Kalimero,
Thanks..
Old Sun 01 June 2008, 17:23
shaperx
Just call me: Mark
San Diego,Ca
6 wire half coil?
I have the PK296A2A SG7.2 with 58 Volt PS
6 wire
With a 6-wire motor you can wire them either:
- UNIpolar (use half the motor), or
- BIpolar series (UNIvoltage X 1.4 and UNIcurrent ÷ 1.4) ?
(only 4 wires will be connected - 2 wires will not be connected)
diagram C Using Trem #3 Black ,Trem #4 green , Trem #5 red and Trem #6 blue. As shown in
The wires which are not connected, are separately(individually) insulated.
Hooked a motor this way and get a green light on the 203v. green lights on J1 PMDX 122 motor will not move. Has holding torque
#20 Mike uses-
For half-coil connections with a Gecko G202 or G203, I use the Black wire and the Yellow wire for the A coil and the Red wire and the White wire for the B coil. i.e. Term #3 = Black wire, Term #4 = Yellow wire, Term #5 = Red wire, and Term #6 = White wire.
Hooked a motor this way and get a green light on the 203v and green lights on J1 Pmdx 122 motor will not move. Has no holding torque.
In diagram B what do you mean center taps?
Old Sun 01 June 2008, 20:28
dmoore
I have the same setup with 58v, Geckos, OMs. Here is my setup:
Gecko = Motor
A- = Green
A = Black
B- = Red
B = Blue
White and Yellow are not connected.
Geckos all have 33K resistors (Orange/Orange/Orange).
Everything on mine works fine.
Old Sun 01 June 2008, 20:29
dmoore
Kalimero
A good solution here is to just trim off the two extra wires at slightly different lengths, then shrink wrap the entire bundle of wires.
Old Sun 01 June 2008, 21:20
shaperx
Just call me: Mark
San Diego,Ca
Ill check the resistors tomorrow.
Old Mon 02 June 2008, 08:11
Be sure to jumper the PMDX-122 correctly for the G203v. You MUST connect terminal #10 on the G203v (Common) to Ground on the PMDX-122. The PMDX-122 must pull the step and the direction signals High when it sends step pulses to the motor.
(My PMDX-122 came jumpered from the factory ready for use with the G201 and the G202 stepper drivers, not for the G203V stepper driver. JP1 is the jumper to check.) Rest of PMDX discussion moved to:
http://www.mechmate.com/forums/showthread.php?t=346
When wired half-coil (Black/Yellow, Red/White), the maximum voltage for the PK296A2A-SGxx motor is about 38V. If you're using a 58V power supply, you will need to wire the motors using the Black/Green, Red/Blue wires, otherwise the motors will get too hot.
Old Wed 28 October 2009, 20:36
Travish
Just call me: Travis #75
Wa
Gecko = Motor
A- = Green
A = Black
B- = Red
B = Blue
I'm looking over the manual here, and wiring the 7.2 geared OM's bipolar from the Oriental Motor site and I'm seeing-
A- = Green
A = Black
B- = Blue
B = red
I swapped the red and blue on the coils. Does this just change the direction? So on the X axis one motor will have swapped wires?
Old Fri 26 February 2010, 04:13
sprayhead
Just call me: Francis
sydney
Same holding torque but different number of leads...
hi,
Suppose we have 2 motors with the same specs, but one has 6 wires and the other has 8.
Would there be a difference in torque between the two motors when running them half-coil? Will both of them theorically have exacltly 1.4x less holding torque than if they were to be wired "full coils"?
thanks,
francis
Old Fri 26 February 2010, 04:39
Theoretically speaking, yes, as long as the construction of the coils are the same.
Again, 1.4X is only an approximate/general number, there are many other factors involve too, i.e. the corner frequency, the coil internal resistance... etc etc... Just to confuse you further
Old Fri 26 February 2010, 05:22
sprayhead
sydney
thanks ken,
I have another question,
I have only a 56VDC power supply. Can I alter the amperage feed to the motor instead of the voltage to find a "perfect balance" between performance and overheating?
Richards posted earlier on this thread that he runs his PK299-F4.5a at 35VDC and 6.3 amps, bipolar paralell, and the motor runs much smoother than at 60VDC, as he first tested.
Could I run the same motor at 60VDC, for example, and lower the amperage instead of the voltage, and get a better balance, just like Richard got, using 35VDC?
Thanks again,
F
Old Fri 26 February 2010, 05:28
Francis-
Mike (Richards) and others are actively discussing that sort of question starting around post #40 here.
Old Fri 26 February 2010, 05:53
Francis,
I'll leave a post in the other thread that Brad highlighted to respond to your question.
Old Fri 26 February 2010, 09:34
Francis, a very common misconception is that the published holding torque of a motor is the important criteria for a router.
The important torque is the one at higher speeds, when the machine is cutting.
Old Fri 26 February 2010, 10:02
Fransic, like all other electrical machine, you cannot just alter the current of the motor, electric motors draw current when they need it even if it means self-destruction & the only thing we can do is to LIMIT the max supply current, just like restricting the fuel line of an engine. AND it is almost impossible to have a "perfect balance" all the time, due to the vast variate operating condition of stepper motors in an CNC machine (speed change, accelerare, decelerate....etc etc). You can only work within a safe operating "ZONE" at best.
To confuse you even further, the other factor which contributes to load current are voltage, frequency, coil inductance, coil internal resistance, coil capacitance, magnetic flux of the magnet & external loads such as friction... etc etc etc... not all necessary to know to operate a motor properly...
Old Fri 26 February 2010, 20:16
sprayhead
sydney
Thank all,
It's really worth it having a look here (same link bradm showed me) on the posts about motors electrical characteristics and playing with what you have to keep the heat down and have enough power available...
f.
